Guarmancebos de dynema
    Re: Guarmancebos de dynema
    Aquí lo he encontrado.
    4.04 Jackstays, Clipping Points and Static Safety Lines
    4.04.1 The following shall be provided:
    a) Jackstays:- MoMu0,1,2,3
    shall be provided-
    i attached to through-bolted or welded deck plates or other suitable and strong anchorage fitted on deck, port and starboard of the yacht's centre line to provide secure attachments for safety harness:- MoMu0,1,2,3
    ii comprising stainless steel 1 x 19 wire of minimum diameter 5 mm (3/16 in), high modulus polyethylene (such as Dyneema/Spectra) rope or webbing of equivalent strength; MoMu0,1,2,3
    iii which, when made from stainless steel wire shall be uncoated and used without any sleeving; MoMu0,1,2,3
    iv 20kN (2,040 kgf or 4,500 lbf) min breaking strain webbing is recommended;
      Lo que esta penalizado es el carbono en candeleros
        Hola Grop, aquí S'Avenc
        Bueno, no hablamos de lo mismo. Tu te refieres al punto 4.0.4 que habla de líneas de vida. Yo al 3.14.6 que habla de guardamancebos. Los guardamancebos deberán ser de cable para regatas clasificadas entre 0 y 3
        La pregunta la hice este lunes. Dejo aquí la conversación completa, primero yo y luego el técnico de la ISAF.
        Good morning.
        We are preparing a boat for an Offshore 2 race.
        Looking at the offshore regulations, in the 3.14.6 Lifeline specifications A) it says: Lifelines of stranded stainless steel wire.
        But then in the Table 8 there are diameters for wire and HMPE rope.
        Is it possible to use dyneema rope for the lifelines? Or Dyneema shall be used only for the lanyard?
        Kind regards.
        Dear Toni,
        For Category 2 the OSR only permit stainless steel wire lifelines.
        Table 8 refers to all Categories, including Category 4, which does permit HMPE.
        Regards
        Simon Forbes
        Technical and Offshore Manager
        +44 (0)23 8063 5111
        sailing.org
        Ariadne House, Town Quay
        Southampton, SO14 2AQ, UK
        Resumiendo, las líneas de vida pueden ser dyneema, cinta o cable descubierto. Los guardamancebos solo en cable descubierto.
        En nuestro caso es bastante importante, pues el barco en cuestión los lleva de dyneema actualmente (no es el mío). Así que hay que hacerlos nuevos.
          No entiendo, para categoria 3, pego textual
          Guardamancebos de cable de acero inoxidable trenzado o cabo Dyneema o
          Spectra o su equivalente, sin recubrimiento. Cabo de unión max 100 mm,
          reemplazado anualmente. Diámetros mínimos: Cables / Cabos para LOA < 8.5 m.
          = 3 mm / 4 mm – LOA > 8.5 y < 13 = 4 mm / 5 mm – LOA > 13 m = 5 mm / 5 m
            Perdona ya lo tengo medio claro,
            Para Categoria 2 solo cable
            Para Categoria 3 sigo investigando
              Para categorías 0, 1, 2 y 3: sólo cable
              Para categoría 4: o cable o dyneema
              3.14.6 Lifeline Specifications
              Mo0,1,2,3 a) Lifelines of stranded stainless steel wire
              Mo4,Mu** Lifelines of either:
              Mo4,Mu** i stranded stainless steel wire
              Mo4,Mu** ii HMPE
              Lo encontraréis en el documento:
              World Sailing Offshore Special Regulations 2016-17 - Updated January 2017
                Yo los llev de dinema de 4mm, los llevo pasados por lo a candeleros. Ni se me han cortado, ni se han desgastado. Los extremos los llevo embutidos, chupado de hacer. No se tarda en poner ni 1 minuto. Es barato y queda muy bonito.
                En cuanto vea que se desgastan, los cambio y ya está, los próximos, en vez de 4mm los pondré de 6mm no por esfuerzos ni desgaste, sino por estética. Para mí quedan finos. Los llevo sin funda en color gris y quedan muy bien.
                  Hola Nalari, me podrías enviar una foto del montaje, gracias!!!
                  Por cierto, cuanto hace que los llevas? Yo tenía pensado ponerlos incluso de 8mm, que te parece?
                    Todo los problemas de reglamentación que aportáis afectan bajo pabellón belga?
                      Los llevo poco más de 1 año. Ahora estoy en valencia y el barco en Denia.
                      Como bien te han apuntado, el problema no es ni el grosor, ni la resistencia, sino que se corte con alguna arista. Los agujeros de mis candeleros, están perfectos y sin aristas. Lo he pasado po estos. Y al llegar al balcón de proa, una Gaza embutidos ida a la orejita se inox.
                      Tengo una salida lateral, ahí, llevo Gaza embutida a la orejita de inox, y en la otra parte Gaza embutida a un mosquetón pequeño.
                      Respecto a la legalidad, ni idea, llevo bandera belga.
                        Originalmente publicado por Cafacu Ver Mensaje
                        Todo lo que estamos comentando se refiere a regatas Offshore reguladas por la federación internacional de vela.
                        Independientemente del país de abanderamiento, o celebración de la regata, se aplican las restricciones de la Federación Internacional. El documento que las regula está un poco más arriba en la intervención de fletxa. Según el tipo de navegación que sea la regata se exigen unos requisitos u otros. En general, los Anuncios de Regatas suelen indicar la categoría de regata Offshore considerada.
                        Editado por última vez por Butxeta; 18/05/2017, 11:15:00.
                          Y en un año no has tenido que volver a tensar?
                          Yo lo he visto en un Solaris de unos 50 pies super moderno y los lleva con tensores, como los que se usan para los de acero pero supongo que con otro sistema de ensamblaje, la verdad es que queda precioso!, también los lleva en gris como tu pero yo creo que serán de unos 8 m/m. Yo también llevo dos entradas laterales y la de popa que van con mosquetones, ahi fácil, pero en el resto me gustaría poner con tensores, pero no averiguo quien los tiene.
                          Te agradezco mucho tu información, yo también llevo bandera Belga.
                            Cambiados, menos mal q no los había tirado, la verdad es q el cable es una M
                              Hola cofrades, podéis poner alguna foto de cómo va montado? Estoy pensando en cambiar los míos... Están algo cuarteados....
