Busqueda de velero infelnnalll.....
  • Vela Busqueda de velero infelnnalll.....
    Hola otra vez querida Taberna:
    Os escribo para pedir vuestra opinion,sobre lo que me dice este broker.....no se que se refiere con " DRY BLOWING "
    The boat was sold under reservation. The aspirant buyer has carried out the inspection himself, although he did not have the necessary expertise as a hobby water sportsman. The trial went as desired and both motor and sails met the expectations. Immediately from the water, the hull showed dry blowing. Because no fluid came out, we could see that there was no osmosis. The present examanor and a yachtbuilkder came to the same conclusion. Dry blowing is a more common cosmetic problem in older boats so consulted yacht experts.
    The buyer has pulled out of the sale only based on the blowing. So at this moment we are completely free to offer the boat. Our sharp asking price is based on the overall condition and the motivation of the seller to quickly get a sale.
    In case you have any more specific questions, I would be glad to answer them. The boat is in — (NL) and can only be visited after appointment, which you can make either by calling at the telephone numbers below, or by replying this e-mail.
    Would this yacht be interesting enough to come to the Netherlands?
    El caso es que no se toman en serio el curro y dan muy poca informacion y cuando aparezco a ver el barco, ó está inundado...ó no estan ó lo han vendido....ó la madre que los ,,,,.. a los brokers....perdon por la descarga y solo daros las gracias.
    Un abrazo y unas de un desesperado...
    best regards amiguitos!!!
    Editado por última vez por jolly-roger; 15/07/2017, 23:55:23.
    Navegar...Vivir...Amar...
    Re: Busqueda de velero infelnnalll.....
    No te fíes al 100% de mi inglés, pero, lo que yo he creído entender es que la obra viva tiene burbujas, pero éstas no supuran líquido al pincharlas, por lo que descarta la existencia de ósmosis. Que es un problema básicamente "cosmético"
      Yo entiendo lo mismo, tiene ampollas pero secas. Y por ese motivo descartan que tenga osmosis.
      Pero también te dice que el comprador que había reservado el barco ha resuelto el contrato por ese mismo motivo pese a que la prueba fue bien.
      Buena proa
        Segun mi opinion es que osmosis tiene o la a tenido.
        Hacer un barco con burbujas es mas caro que hacerlo liso, si han salido burbujas tiene osmosis, si las han sellado inyectandoles algo ok de hay a burbujas secas hay un trecho, si no te enseñan fotos del proceso de pelado, secado y nuevo gel coat, en principio tiene osmosis, diga la maquina lo que quiera.
        Broker pues ya sabes, como en botica de todo abra pero no te preocupes que si hay uno bueno no te lo cruzaras tu ni yo ni nadie que te conozca a ti ni a mi y ni que conozcan asu vez a todos estos.... ya me entiendes por no decir que no queda ni uno. Son personas que han de vender para llevar un sueldo a casa punto.
