cuantos años dura un barco de fibra?
  • cuantos años dura un barco de fibra?
    Una ronda para los cofrades de lo que esten bebiendo
    Me hago esta pregunta por que sabemos que se pueden hacer tratamientos anti osmosis etc pero debe llegar un momento en el que ya no sea osmosis si no que sencillamente acaba su vida util, perdera sus propiedades, dureza, opacidad, humedad... y sencillamente no valga la pena seguir gastando o luchando contra lo irremediable.
    Que opinais?
    Re: cuantos años dura un barco de fibra?
    Pues lo que dice en un e-book que me leí (Second hand boats, Andrew Simpson) , es que prácticamente son eternos. También comenta lo que se ha dicho aquí, que de todas formas los más modernos son de peor construcción.
    And it did. The end of the 1950s saw the emergence of GRP (glass reinforced plastic) with boatbuilding being its first widespread civilian application. By the mid-sixties the new wonder material had really taken hold and, despite scornful sniffs from the traditionalists, it was greeted rapturously by the general public. The age of the everlasting boat had arrived!
    Well, not quite. As we have since learned, GRP is not without its problems but boats moulded from it haven’t done at all badly, with the vast majority of those ever built still being around today. By contrast, almost all of those boxy plywood creations that got Britons afloat a decade earlier have long since vanished.
    Now, durability is great for the consumer but bad news for manufacturers who find themselves trying to sell their wares in a market awash with used but still perfectly serviceable boats – boats that, infuriatingly, are clearly in no hurry to fall apart and make way for new.
    With the exception of a those ‘quality’ builders who continue to charge bespoke prices for their products, the budget boatbuilding companies have been obliged to pare down their material costs and to adopt automated mass production methods to keep their prices as low as possible.
    Although on the face of it this might seem a good thing, it does raise the question of whether or not strength and toughness has been compromised. Springing directly from this unease is the growing feeling amongst thoughtful sailors that, not only can you get a cheaper boat by buying second-hand, you might actually get a far better one – and one more generously equipped.
    Makes one think, doesn’t it?
      De momento el problema es como destruirlos.
        Mi ex-barco cumple este año 40 y está en buen estado de salud en manos de su actual armador.
          Originalmente publicado por pil pil Ver Mensaje
          Totalmente de acuerdo.
          Existe algún sistema de gestión, reciclaje, etc para los cascos de fibra???
          Enviado desde mi Aquaris E4 mediante Tapatalk
            Mi barco es un Formosa 36 del año 1980, y no esta mejor porque no tengo mas dinero, osea que yo diria que dura, el dinero que tengamos para cuidarlo, incluso los palos son de madera y se encuentran sanos que es lo que mas me importa, feos eso si de cojones porque la ultima vez que se hizo algo en ellos fue sacarlos para lijarlos y barnizarlos, cosa ultima que no hare nunca mas, el barniz en los palos no es buena idea porque para repasarlos o te subes o los sacas.......
            Yo creo que la pregunta adecuada, y doy la respuesta antes de formularla, es SIIIIII
            La pregunta es o seria ........Vive un barco mas que su armador ? por tanto la de arriba es la respusta, y siendo tal, debemos estar tranquilos, por tanto la conclusion es cuidarlos, osea dejarnos la pasta de forma ETERNA y duraran ETERNAMENTE.....
            PONGO UN VIDEO......DE MI POZO SIN FONDO, lo de contestar al hilo era una escusa para enseñarlo........
            Posdata.......alguien sabe de mas hilos para enseñar mas videos ?
              El que yo tengo, un Capeador24, de los primeros que hizo este astillero en fibra(antes construia en madera).
              Tiene mas de 40 años a su espalda y pese a estar bastante maltratado la fibra está en muy buen estado. Este astillero construia los barcos como si fueran de madera, en grosor y peso. El casco tiene un centimetro de grosor!
              En cuanto a destruirlos en menorca hay una empresa de residuos voluminosos que se encargan de ello,eso si cobrando 6€/kg.
              En un reportaje vi como reciclaban bicis de carbono, las troceaban, quitan las partes metalicas y despues pasan por un molino. Esas astillas las meten en un horno al bacio para eliminar la resina. Con las fibras que quedan hacen una tela resinada para construir piezas de carbono otra vez. No se si con la fibra de vidrio se hará lo mismo.
                Yo también me he planteado muchas veces la pregunta.
                Mi arcoa tiene 40 años, y en apariencia está perfecto de estructura. Es cierto que antes se construían muy robustos.
                Me esperan los dias
                que pretendo llenar
                y que me hagan vibrar.
                Y aprendiendo mi vida
                solo quiero sentir
                que no es vida perdida
                  Originalmente publicado por clasico Ver Mensaje
                  Precioso barco si señor.
                    Vaya preciosidad, enhorabuena!
                      Pues yo creo que el tema no es ninguna tontería, es como el casco de ir en moto, estéticamente perfecto, pero con fecha de caducidad
                        Originalmente publicado por Elmecanico Ver Mensaje
                        El tema es saber esa fecha. Si existe.
                        Me esperan los dias
                        que pretendo llenar
                        solo quiero sentir
                          "...despite scornful sniffs from the traditionalists..."
                          No se por qué me ha acordado de Simbad
                          Mario.
                            jjjjj mu chulo tú barco. Con el frio y agua que tenemos por aquí, da ánimo ver esas navegaciones en bañador con un sol resplandeciente
                            Oye, una pregunta, ¿por qué no utilizas la mesana?
                            Hala y así ya tienes excusa para poner otro video con todas las velas
                              Si los edificios de hormigón tienen una vida de 50, 100 años.... y la fibra dura mas, ppr que no se hacen mas cosas de fibra?
                              Creo que en los proximos lustros los primeros barcos de fibra llegaran a los 50 años, sera entonces cuando veamos como va el tema?
