Buscando una pieza de repuesto para mi raymarine C90W -el botón cursor que gira- he encontrado esta tienda que fabrica en impresión 3D piezas que el fabricante original ya no vende
algunas son caras, otras más razonables, pero si no queda más remedio puede ser una solución
Venden incluso un mando a distancia para los autopilot de raymarine, tanto los antiguos, como los modernos evolution, pero cuesta casi 300 dólares
Raymarine ya no repara la pieza ni la vende
Lo más que te dan es instrucciones de cómo hacerlo si encuentras la pieza por tu cuenta:
UniController's rotary/trackpad membrane part (R62185)
Raymarine does not typically supply disassembly/repair/assembly instructions for its products. Raymarine recommends that products which are in need of repair instead be sent to Raymarine’s Product Repair Center to be serviced. However, in this case, replacement of the UniController's rotary/trackbad button membrane is relatively simple. The MFD's bezel must first be removed to access the two phillips head screws the UniController rotary/trackpad button membrane to the MFD. The MFD's bezel is snapped into place over the MFD's frame. Care must be exercised when unsnapping the MFD's bezel from the MFD's frame to prevent cracking it. It is generally recommend to begin unsnapping the MFD's bezel along it's outer edge starting at the top center and then working one's way around the bezel's perimeter. After removing the MFD's bezel, one will find two phillips head screws securing the UniController's rotary/trackbad button to the UniController. These two screws will be removed, the UniController's rotary/trackbad button membrane lifted off the shaft of the UniController, the replacement UniController's rotary/trackbad button membrane will be placed onto the UniController's shaft, the screws will be re-installed, and then finally, the MFD's bezel will be snapped into place.
One of the functions of a C/E-Series Widescreen MFD UniController's rotary/trackpad button membrane is for preventing water ingress into the MFD. As such, care should be taken to protect the MFD until such time as the UniController's rotary/trackbad button is replaced. Please note that UniController's rotary/trackpad membrane part is no longer available from Raymarine's Order Services or Raymarine's Product Repair Center.
