un daimio 24
  • un daimio 24
    Lo tengo con problemas de motor Farymann L30 M , en concreto la bomba de inyección de gasoil, me dicen que ya no existe "Farymann", también no encuentro el deflector de goma entre la reductora y el eje de la hélice. Si alguien tiene alguna idea o información se lo agradecería.
    Re: un daimio 24
    como quieres decir? existe ?
    Greaves Farymann Diesel GmbH, Engines with a future, manufacturer from diesel engines for industrial and marine application, sophisticated, leading-edge engineering, reliability and flexible application options, presence are of course guaranteed: we help you worldwide, through our sales and customer service network, technological market trends and customized requirements, Farymann Diesel excels particularly in terms of lengthy experience in developing and manufacturing engines that incorporate the very latest technical advances, specialized applications, for instance drive pumps, compressors, high-pressure cleaners and generators, thanks to continual design enhancement, Greaves Farymann is able to meet the stringent American EPA limit values, Farymann engines series excel in terms of their salient characteristics: they are compact, sturdy, long lived, and meet the stringet emission requirements of the USA EPA standard, Greves Farymann is particularly proud of it: after all, the 15W/18W is the world`s smallest water-cooled diesel engine, 15/18W engines are used in marine and industrial application, with a height of just 360 mm, the Farymann diesel engine 43F is precisely the right air-cooled engine when only a particularly flat installation space is available, all Greaves Farymann engines meet the toughest of requirements in terms of material, precision, reliability and long life times.
    Si puedes explicar mejor al igual la cofradia te puede ayudar...digo puede...
    birrad
      Re: un daimio 24
      Muchas gracias la casa que normalmente recurro AKERINGENIERIA SL me comento que no existe supongo equivocada ya me puse en contacto con
      la dirección que me distes espero contestación repito muchas gracias.
