Grosor patente
  • Grosor patente
    Buenas ha todos que opináis sobre dar la capa fina de patente
    O gruesa para que crié menos vida marina. Gracia s. A todos
    Re: Grosor patente
    Las hojas de datos de las pinturas antifouling, cada una tiene la suya, especifican, el grosor, el número de capas, el método de aplicación y hasta los tiempos de secados entre capas antes de repintar a fin de obtener un resultado óptimo, ademas de sobre qué bases o pinturas previas se pueden aplicar y si es necesario para ello usar alguna imprimación.
    No es necesario para nada elucubrar, ni recurrir a creencias populares, basta con leer. Por ejemplo, Micron 350 de International.
    Other: Antifoulings should only be wet sanded. Never dry sand or burnoff old antifoulings. True colour will develop
    after immersion.
    Some Important Points To prevent premature failure, ensure the correct amount of paint is applied using the coverage as a guide. Product
    temperature should be minimum 5°C/41°F and maximum 35°C/95°F. Ambient temperature should be minimum 5°C/41°F and
    maximum 35°C/95°F. Substrate temperature should be minimum 7°C/45°F and maximum 35°C/95°F.
    If you are regularly travelling at high speed (eg 30 knots) you might experience early wear through. Consult your local
    International Paint Representative for further advice if you are unsure about the suitability of Micron 350 for your specific
    requirements.
    Avoid excessive buildup of aged antifouling layers as solvents in fresh antifouling layer can soften underlying layers,
    contributing to unsightly sling marks.
    Compatibility/Substrates For use over suitably primed GRP, Wood, Steel/Iron and lead.
    Not suitable for use over Aluminium/Alloy substrates or zinc sprayed surfaces.
    Can be applied direct over most types of antifoulings, provided they are in sound condition, with the exception of
    VC17m/PTFE antifoulings. Consult your local International Paint representative for specific overcoating advice if you are
    unsure about compatibility of Micron 350 over your existing coating scheme.
    Number of Coats By Brush/Roller
    Apply 2 coats of 60 microns dry for 12 months (Total DFT of 120 microns)
    Apply 3 coats of 60 microns dry for 24 months (Total DFT is 180 microns)
    By Spray (Professional only)
    Apply 1 coat of 120 microns dry for 12 months (Total DFT of 120 microns)
    Apply 2 coats of 90 microns dry for 24 months (Total DFT of 180 microns)
    In all schemes, apply an extra stripe coat in areas of high wear such as chines, rudders, sterngear and
    any leading edges.
    Coverage By Brush/Roller:
    (Theoretical) 10 m²/L per coat
    (Practical) 9 m²/L per coat
    By Spray (Professional only):
    (Theoretical) 6.67m²/L per coat (for 24 months scheme)
    (Practical) – 4m²/L per coat (for 24 months scheme)
    (Theoretical) – 5.17m²/L per coat (for 12 months scheme)
    (Practical) – 3.1m²/L per coat (for 12 months scheme)
    Recommended DFT per coat 60 microns dry per coat by brush/roller
    90 microns dry per coat by spray (for 24 months scheme)
    120 microns dry per coat by spray (for 12 months scheme)
    Recommended WFT per coat 97 microns wet per coat by brush/roller
    145 microns wet per coat by spray (for 24 months scheme)
    194 microns wet per coat by spray (for 12 months scheme)
    Care must be taken not to overapply and to follow the recommended film thickness.
    Application Methods Airless Spray (Professional only), Brush, Rolle
    Editado por última vez por flipk12; 22/02/2026, 11:37:05.
    No terra sed aquis.
      Re: Grosor patente
      en cuestiones como esta al ultimo que le tienes que creer es al vendedor del producto que siempre te va a decir que su producto es el mejor del mundo y que con aplicar un minimo va a dar un rendimento extraordinario, etc. y si además el prospecto está en ingles eso ya es como la biblia.
      A mi la experiencia me dice que cuanto más le des más te dura y si le das dos manos bien dadas te dura más que una sola mano.
        Re: Grosor patente
        Originalmente publicado por Hortichuelas Ver Mensaje
        A ver...
        Para las hormigas un espolvoreo con hormiguicida basta para matarlas, no necesitas hechar todo el tarro.
        Con lo justo y necesario ya basta.
        Las patentes trabajan de diversa manera, por actividad biocida (las duras) y por desgaste (las autopulimentantes) Todas ellas actúan desde su superficie, por más que la patente tenga 1cm. (exagero) su función actúa desde la superficie.
        Así que si es de matriz dura o fina con dos o tres manos finas bastará.
        La duración dependerá del mar (mares fríos crían menos flora), del uso del barco (barco en pantalán es un "vivero" de flora), de la calidad del producto y de mucho más.
        En condiciones normales una patente dura un año (bien) o dos (no tan bien). Tres... me "parece" imposible por más gruesa que sea.
        https://twitter.com/egis57
