blooper
  • blooper
    Salud cofrades.
    En el guardarropa que acabamos de heredar, figura un saco con la siguiente inscripción: blooper 1,2 onzas.
    He buscado en interné, pero no encuentro cómo se establece este pedazo de trapo. Tampoco en la biblioteca; a lo sumo algún esbozo que no aclara gran cosa. Entiendo que se amura en crujía con un estrobo, se iza bastante suelto y la escota se reenvia a popa, pero no estoy seguro ¿Saben vuestras mercedes de alguna página donde pueda encontrar ayuda?
    thank's.
    Re: blooper
    Hola, me sonaba ese nombre
    y te he encontrado esto en la web de northsails:
    Question: Dear North Sails,
    Last year, we became the lucky owners of the C&C35 MKII. As a former racer, the boat came with a large set of sails, all made by North Sails. One of the sails is a blooper, which, as I understand, is a sail to be flown in addition to the spinnaker. Since our focus at the present time is primarily on cruising and we are usually short-handed, we are interested in flying spinnakers without a pole. We recently tried that with a symmetric chute and an ATN tacker and that worked reasonably well. Here is my question: Can we use the blooper as some kind of asymmetric spinnaker to be rigged the same way, or is the sail shape unsuitable? If the shape doesn't work, can the sail be re-cut to work as an asymmetric?
    Thanks very much,
    Michael Hesse
    Answer: Hi Michael,
    A Blooper is designed to fly as far to leeward of the rig as possible, clear of the mainsail, for square running in concert with a symetrical spinnaker. A modern Asymmetric cruising spinnaker is designed to fly as far to windward of the rig as possible. The sails are very different. A Blooper is not of much use unless you have a spinnaker up and the boat is rolling in a seaway. It will not add any speed to the boat but it will make it more stable. Not many boats carry Bloopers today.
    There is not much you can do in terms of recutting a blooper for use as a cruising sail. You would have much better results recutting a symetrical racing spinnaker for use as a centerline tacked cruising asymetrical.
    Entiendo que parecido en forma a un asimetrico (no lleva tangon), pero se utiliza junto al simetrico para estabilizar el rumbo, a ver que dicen lo sabios ¡¡
    www.cmpo.cat
      Re: blooper
      Hay confusión en la utilización del nombre "blooper".
      Inicialmente se dió ese nombre al Big Boy, que es al que le corresponde. Si tu vela es como un spi, de una forma triangular, entonces has heredado una antigualla buena para hacer una prueba un día que vayas con una tripu numerosa y que sepa lo que se lleva entre manos. Nada más.
      Blooper también se le ha dado (por digamos similitud) a una especie de trinqueta que se establece por debajo de un spi y con un puño de escota alto. En consecuencia, y para diferenciarlo de esta, La velería Hood lo nombró como "shooter".
      Por tanto, habría que ver si estamos ante un auténtico Big boy, lo cual sería casi como un Stradivarius
      Buena proa!
        Re: blooper
        Uy Wichite, nos hemos cruzado, pero me parece que lo que has puesto tú que has encontrado en North Sails, va en el camino de lo que he puesto yo (menos mal!, porque esos de North saben algo de velas ).
        Buena proa!
          Re: blooper
          y trimado con el pujamen a una cuarta del agua...junto al asimétrico arriba...gran estampa ya no vista...
            Re: blooper
            Creo que la portada del libro Patrones de Yate de Simón Quintana será de gran ayuda.
              Re: blooper
              Yo tambien tengo un blooper o big-boy que me vendieron como asimetrico en una estafa de internet.
              Tal como han señalado algunos cofrades, esta totalmente desfasado. Se utilizaba antiguamente para compensar la escora-balanceo producida por el spi, y parece ser que no añade ninguna velocidad al barco. Se larga por el lado opuesto al spi y curiosamente se trima no con la escota si no con la driza.
              Dicen que es una vela muy peligrosa que ha dado muchos sustos, lo cual es imaginable porque es como llevar dos spis largados al mismo tiempo. Actualmente esta prohibido utilizarlo en regatas, con lo cual su uso se ha acabado. Si algun dia tengo oportunidad y una tripulacion experta y numerosa lo izare para hacer una foto, unica utilidad que le veo.
                Re: blooper
                Hola a todos. Tal como dice Butxeta, Te refieres a esto...
                  Re: blooper
                  Yo con un antiguo Big-Boy de un 38 pies, estas manitas y mis abalorios, y cortando casi media vela y usando el puno de driza como de amura (o de escota, no recuerdo) me hice una especie de genaker.
                  Por no tirarlo directamente, no por otra cosa, porque evidentemente el corte deja muuuucho que desear.
                  Pero si hay poco viento por el través...al ser tan ligerito...al menos se hincha!
                  Y es tan fácil de poner y quitar, que en fin, no lo uso, pero lo guardo.
                  Como te han dicho en regatas ya no se usa y en crucero....no se ha usado nunca. Para unas fotos o hacer de velero como yo, o para hacer catavientos para tí y todo el puerto.
                  Edu.
                    Re: blooper
                    Yo nunca he navegado con velas de estas, sólo las conozco de libros antiguos, y algun saco he visto, pero creo que lo que comentas del "shooter" era llamado tambien como "tall boy".
                    Yo siempre he entendido big boy como sinonimo de blopper. Es como ahora que los americanos a cualquier spi le dicen "kite"...
                    Me gustaria algún día probar un big-boy, tiene que ser espectacular, además, el follon que hay que montar para trasluchar tiene que ser divertido...
                    Salu2
                      Re: blooper
                      Es posible lo del shooter. Ya sabes que los yankees tienen una enorme facilidad en inventarse palabros.
                      También me gustaría a mí probar un big boy ... en el barco de otro
                      En cuanto a la trasluchada, no problemo!. El cña sin avisar, dá un golpe de timón y traslucha...
                      ...luego los de la proa ya lo arreglarán todo, que para eso están
                      Buena proa!
                        Re: blooper
                        Hombre, alguna fotillo guapa saldrá ¿no? jejejeje. Es más o menos lo que pensaba. Gracias por las respuestas.
                        Pues también. Es un autentico North Sails (con número de vela y tooo...) en buen estado.
                          Re: blooper
                          Seria un honor tenerte a bordo para ese menester... u otros, claro.
                          Aún tenemos que pasar a recoger todos los cachivaches que se han ido amontonado en este tiempo, así que no es descabellado pensar que puede aparecer alguna otra "antigualla", jajajaja.
                            Re: blooper
                            ¿¿Ahora has encontrado un BigBoy ??
                            Tu lo que te has propuesto es que reviente de envidia de una manera o de otra ¿no?
                              Re: blooper
                              Hola a todos. Yo no lo he usado nunca, pero si lo he visto llevar. Se usaba, según comenta la gente que lo ha navegado, en los barcos antiguos de popa estrecha, pequeña mayor y gran spí. En popa redonda, no existia el vmg, el barco tenia tendencia al balanceo y usado esta vela se paraba bastante este movimiento
                              Ahora no puedo aportar fotos, pero haber si consigo alguna
