Limpiar Teka Exterior Con Karcher????
  • #46
    Re: Limpiar Teka Exterior Con Karcher????
    Salud cofrades
    La madera tiene en principio dos componentes.
    La albura- patre blanda
    El duramen- parte dura o resinosa
    Con el tiempo la parte blanda se desgasta y la madera envejece produciendo hondas. La albura es la que absorbe y florece los hongos producidos por el agua dulce ( menos manguerita los fines de semana ) generando el color gris tradicional.
    El uso del BORACOL es extrahordinario, nosotros conocemos el producto.
    Se aplica con la cubierta limpia y lijada Grano 240-360.
    No asustarse si aparentemente aparece manchada, desaparece el efecto quedando una superficie bella y clara, uniformemente.
    Los escandinavos lo usan y ellos entienden de lluvia e inclemencias en la teka.
    Que sea una ronda para todos
    • #47
      Os paso el contacto del importador de Boracol para España.
      Buen fin de semana a todos.
      • #48
        Extracto del manual de Hallberg Russ
        The teak deck
        The teak deck is a part of your boats character. After a few weeks the teak will turn greyish, and a
        smooth silvery grey deck is probably what most people like to see. The reality is often something quite
        different.
        You have probably already seen dark, dirty, sometimes mildewy teak decks. Mildew is something that is
        more frequent today than some decades ago. You will find it not only on teak decks. It can be found on
        concrete, piers, painted surfaces and so on. The presence might differ very locally, some areas suffer a lot
        from mildew, and others are not hit at all. In the long run the best way to treat the teak deck against
        mildew is to use Boracol. Boracol is a liquid that is uncoloured and thin like water. It is sold in normal
        chemist shops and hardware dealers. It is marketed as a treatment against mildew for garden furniture.
        Use a normal paintbrush and paint the deck with Boracol. Never use a normal brush on the teak! Do
        the work on a dry dray. If it rains too much Boracol will be washed away. It does not matter if it is
        drizzling the next day but if it rains the complete day or over splashing waves washes over the deck, the
        Boracol will make no effect. That would flush the Boracol way too early. If it does not rain, spray the
        deck a little with water. This little amount of water only helps the Boracol to penetrate into the teak.
        After three to seven days you wash the deck with a sponge and cleaner, for example green soap. Please
        do not be afraid if you do not see any positive result immediately. On the contrary, the deck looks
        worse than it did before the treatment. After about ten days things will start to happen. The mildew has
        disappeared and the deck is clean. The mildew will not recur for some time. Do not be afraid to repeat
        the treatment now and then.
        Environment protection
        Don’t use abrasive detergents and avoid using more than necessary.
        Our recommendation is:
        Wash regularly , if needed, once in a while with oxalic acid or sodium hypochlorite. Use a rag on the
        brush or a sponge to spare the soft part of the wood fibres, to minimise the wear.
        You can also use fine-grained sandpaper. This will, if used lightly, only take off the tops. The brown
        areas that appear will soon fade, bleached by the sun. The amount of wood removed by light hand
        sanding is so small that it hardly matters.
        The worst thing that can happen to a teak deck is cleaning it with a high pressure water jet. Every
        marina or yacht yard has such an equipment and there are definite reasons to strongly advise against
        the use of this on your teak deck. It’s only a matter of seconds before deep grooves are made, or even
        splitting the teak.
        At every boat show we meet people claiming that their high pressure cleaner with the right setting will
        clean a teak deck without damaging the wood. Do not believe them.
        • #49
          Como lo aplicais ??????, con la tecka mojada ????, seca ???? como ????, gracias
          www.kailoa.blogspot.es[/URL]
          ESP-9429
          Socio Fundador de ANAVRE
          • #50
            Yo la limpio así y queda como nueva (se lo dijiste tú Kailoa?)
            Iván
            Editado por última vez por Invitado; 25/02/2013, 00:06:38.
            • #51
              Si, pero este producto es para matar los hongos de la madera y que no se deteriore, la usan en contruccion, protegiendo la madera, y querria saber como se aplica ya que las instrucciones estan en aleman y ?????? ja ja ja
              ESP-9429
              • #52
                Nadie sabe como se aplica ?????????????????
                ESP-9429
                • #53
                  Re: Limpiar Teka Exterior Con Karcher????uiq
                  Rondas para todos , que ya me tocaba...
                  La karcher es muy útil para muchas tareas de limpieza ...lo que pasa es que hay que usarla correctamente , cosa que en el mundo náutico no se hace....para lo que nos ocupa , limpiar la teca , va muy bien ...adelantas mucho el trabajo es mi opinión .eso si , únicamente con Boquilla plana de 25 grados , una distancia constante del chorro de proyección proporcional a la sensibilidad de la teca y después de secar ....(distancia solo para sacar suciedad ) algo de aceite de teka hasta el próximo año...espectacular resultado si la teca está muy sucia.
                  He utilizado de todo para limpiar la teca....ya van unos cuantos años viendo resultados....lijado , producto 1 , producto 2 , etc...
                  Curioso que los verdaderos profesionales , que me imagino que habrán probado muchos productos , sólo baldeen con agua de mar la teka...
                  • #54
                    Lo mejor para la teca es agua de mar. Todo lo demás es destrozarla
