SONAR hasta 100 m BARATO
  • SONAR hasta 100 m BARATO
    Buscando por ahi me encontré esto: (en Ebay precios variados hasta 50 eu)
    This amazing product is especially designed for amateur and professional fishermen alike, to find out the location of fish and depth of water. The unit can be used in ocean, river or lake and is fantastic for detecting schools of fish in any particular area. Using amazing and innovative technology, this portable fish finder is the ideal tool to bring the fish to you!
    Sonar technology is based on sound waves. The system uses sonar to locate and define structure, bottom contour and composition, as well depth directly below the transducer. The transducer sends a sound wave signal and determines distance by measuring the time between the transmission of the sound wave and when the sound wave is reflected off an object; it then uses the reflected signal to interpret location, size, and composition of an object.
    • LCD display with LED backlight
    • Range of depth readout from 0.7 meters up to 100 meters
    • Round transducer sensor with 7.5 m cable, 45-degree beam angle
    • Removable float
    • Determines the location and depth of fish
    • Audible fish alarm
    • Selectable between meter or feet readings
    • Can mount the sonar with the following methods
      A. Fix it to the boat hull
      B. Use a float on the cable to mount the sonar inside the water
      C. Fix it on a pole and push it into the desirable position inside the water
      D. Cut a hole on the ice surface and place the sonar under the water
    • Display the nature or circumstance of bottom of Sea (i.e. grass, rock and sand)
    • Operating Temperature : -20°C to 70°C (-4°F to 158°F)
    • Uses 4 x AAA batteries (not included)
    • 1pc x Fish Finder
    • 1pc x Round Sonar Sensor with 7.5m Cable
    • 1pc x Bolt
    • 1pc x Wing Nut
    • 1pc x Neck Strap
    • 1 booklet of instruction manual
    • Color retail box package
    Editado por última vez por Antonio_Mataelpino; 13/04/2011, 21:03:25.
    NO ESTES TRISTE. TEN GANAS¡¡¡
    Re: SONAR hasta 100 m BARATO
    En deal- extreme (Hong Kong) lo tienes por 30 euros puesto en casa
    Unas
      si
      ademas nuestro distribuidor perpetuo
      Lidl lo saca de vez en cuando por un precio similar
      yo tengo uno
      que les compre en esas ferias que hacen cuando les sobran cosas
      con cajas estropeadas y asi, por 10e
      y funciona bien
      lo veo interesante para neumaticas buceo, esas cosas
      repito funcionan bien
        Hola gracias por tu comentario. ¿podrías decirnos que tal lectura hace en movimiento?
          no lo he probado con el barco en movimiento
          si, desde un muelle y desde una zodiac pero parados
          no lo e puesto como instalacion fija....
          ya que el transductor flota con la boya amarilla
          tiene un monton de cable y no me a dado por desmontarlo
          y acortarlo
          (por el riesgo de pillarlo con la helice)
          repito mis pruebas fueron siempre en parado
