El mejor retrete nautico
  • El mejor retrete nautico
    Por si fuese de interes para todos y los mas cag...es especialmente, esto
    es lo que dice mi amiga Peggie Hall junto con la revista "Practical Sailor".
    Para los que no sepan "jinglis" dice que el Raritan Elegance es el mejor
    vater electrico por consumo electrico, silencio y que por su minima cantidad
    de gasto en agua incluso se puede utilizar con agua dulce que como ya se
    sabe es la que evita (mas o menos que el inodoro huela a rayos), todo
    ello despues de probar varias marcas.
    Cita
    I love this toilet!
    have since shortly after Raritan introduced it...and so is Practical
    Sailor. They rated it "best in show" in their comparison of macerating
    toilets in their February 2011 issue. Tecma was the "gold standard" that
    revolutionized high-end marine toilets...the Elegance now holds that
    place. It uses less water, draws less amperage, is incredibly
    QUIET!--and, if you know where to shop, sells for only $600 with the
    optional "Smart Flush" panel added that offers 4 different flush
    options, an option I highly recommend.
    Discharge can any direction, out the rear left, right or straight back
    or down...though you may have to order the appropriate discharge fitting
    if the one in the box isn't the one you need. Also available in two
    sizes, with a choice of straight or angled back to fit against a
    bulkhead or against a sloping hull.
    It's also designed to use pressurized flush water (but can use sea water
    with the installation of a separate remote intake pump), making the
    Elegance an excellent choice for a motor home.
    Peggie
    Peggie Hall
    Specializing in marine sanitation since 1987
    Author "Get Rid of Boat Odors - A Guide To Marine Sanitation Systems and
    Other Sources of Aggravation and Odor"
    Fin cita
    Naturalmente nada que ver con estos, a mi siempre me mandan a la via (Jejeje)
    Que aproveche
    Escatologicamente vuestro
    Miahpaih
    Por favor no arroje nada aqui dentro que no haya comido antes.
    Editado por última vez por Miahpaih; 04/01/2012, 22:11:53.
    Re: El mejor retrete nautico
    Pensáis Vos que deberíamos instalar al menos uno
    Manel - EA3CBQ
    Socio fundador Anavre n° 15
      Hay uno, al menos, en el Dolce Vita at your disposal barón.
      Sidra, fabes, salud y buena mar,... con "elegance"
      Albaid en youtube
        Tengo entendido que tanto Mrs Hall como el resto del equipo de investigacion pasaron cuatro días recluidos en un hotel bajo estricta dieta de fabada
          Y el video:
          Salud y
            Feliz año a todos, querido vecino en mi opinion modesta donde esten los antiguos "jardines" y derivados que se quite lo demas.
              Aqui os muestro mi baño es muy economico y no consume electricidad.
              Recuerda que el pez de tu vida, puede estar solo a unas millas por alli, justo donde has estado pescando todos estos años.
                Juurrr como corre el foro
                Pues no sé de momento estoy investigando la cuestión, yo tengo uno muy
                antiguo (26 años) en el baño de proa que ya necesita ser cambiado pero que
                tiene la grandisima ventaja, (Algo que me gusta mucho) que es electrico y
                quitando un solo tornillo se hace manual.
                El otro es un Atlantes, muy bueno pero que empieza a fallar, asi que ......
                tal vez me decida a cambiar los dos por estos nuevos, no sé, no sé,
                lo meditaré cada vez que vaya al monoplaza.
                Originalmente publicado por Kiro Ver Mensaje
                Kiro si es el mismo, hablanos de sus "bondades" y si el mismo te causa
                doble "satisfacción". Ya nos diras. Jejeje
                Originalmente publicado por vigiadeoccidente Ver Mensaje
                Fabada y sidra a esgalla pues ya se sabe que la sidra rompe la molecula
                Jajajajajajajajajajaja
                Originalmente publicado por Cabot Ver Mensaje
                Apreciadisimo vecino, por muy bien que funcionen estas "moderneces" nada
                supliará el "encanto" de los venerables "jardines" y su imprescindible
                Capitan para pasarte la indispensable china o canto rodado para completar
                la debida higiene que el acto obliga. Ahhhhh y no olvidemos que los mismos
                garantizaban una total ausencia de los nauseabundos olores que acompa-
                ñasen a los del propio navio. Jajajajajajajaja. Un abrazo y mis respetos a
                la Almiranta.
                Originalmente publicado por carraspio Ver Mensaje
                Si, ciertamente es "tecnologicamente avanzado" y muy practico pero tiene
                el peligro (Se ha dado el caso) que en un momento de distracción algun
                tripulante lo use para darse una ducha y se eche el contenido por la cabeza.
                Sigo investigando sobre el asunto, si alguien tiene conocimiento u opinión
                que lo diga ahora y no cuando esté "apretando"
                Miahpaih
                En este sitio vulgar, en este sitio indecente, suele cagar el cobarde y
                tambien el mas valiente.
                  Respuesta: El mejor retrete nautico
                  Venden el asiento,,,
                    Re: Respuesta: El mejor retrete nautico
                    Originalmente publicado por jesusbcn Ver Mensaje
                    Este es para nota !!!!!. QUIERO UNO!!!!
                      Donde .....donde....venden el asiento quiero uno , que si no es muy frio
                        low tech! la venden en West Marine:
                          Puedo dar fe de que es silencioso, pero lo de que gasta poca agua ... no se.
                          Un amigo que ha conectado uno de estos al depósito de agua dulce por aquello del cambio de 'aromas' y el coinsumo de agua se le ha disparado.
                          En cualquier caso, y ahora que todo está hecho una 'merde', es un buen regalo de reyes .
                          Salu2. Carmelo ( O L A J E )
                          Mi web:
                          https://alcorai.net
                          https://olaje.com
