Anemometro conectable a telefonos móviles
  • Electrónica Anemometro conectable a telefonos móviles
    Curioso el enganche al conector de auriculares/microfono
    Ever missed an amazing set in spite of your sick surfboard because you packed it in not knowing that the wind was picking up and about to deliver the perfect wave? Or maybe you didn't realize just how hard the breeze was blowing and as a result, your tee shot wound up deep in the rough. Good news, sporting friends, because start-up company Shaka is here to make you more air-aware with a wind meter that plugs into the 3.5mm jack on your smartphone. It's a small, plastic fan, not much bigger than a box of matches, that pairs with the company's app to deliver wind speed and direction wherever you are -- and it works by simply holding the thing up in a stiff breeze. The app then keeps a record of all your measurements and allows you to share them via your favorite social networks. Not only that, it also overlays the results on a map so you can see where the wind is just right for all your favorite wind-reliant activities. It's currently iOS-only, but we're told Android and Windows Phone versions are in the works as well. The price for knowing when wind perfection is upon you? For now Shaka's seeking to sell them for around $59 bucks, but that could change if the powers that be (read: investors) decide otherwise.
    De precio anda por lo de una anemometro de mano completo, pero este permite historicos, usando el GPS publicar la posición, y publicar los datos en redes sociales de internet y para usarlo en regatas ORC.
    Re: Anemometro conectable a telefonos móviles
    Pues no tengo claro si sera practico, pero ingenioso lo es un rato
    Zálata - Dehler 34
    jSDN Software de Diseño Naval
    RaceMate Software de Regatas y Navegación
      La idea no está mal, y ello abre posibilidades de conexion a dispositivos Android via tarjeta de sonido.
      No es algo nuevo. Ya en los 80 usabamos casetes de audio para guardar-cargar software.
      Si alguien ingenia un conversor de datos NMEA a traves de las entradas de audio, conectar nuestros moviles al bus NMEA podria ser bastante sencillo.
      O.... eso creo,.
        Originalmente publicado por Zalata Ver Mensaje
        ¡Hombre, es muy práctico!
        Te sirve para medir la intensidad de la tormenta antes de llamar a tu mujer para disculparte por haber olvidado la fecha del aniversario
        ~EL HILO DEL BOTIQUÍN ~
          Si es que ya no saben qué hacer con los móviles .
          La última en la que he picado es un mando a distancia para la reflex con el Android, usando también la toma de audio: http://www.xatakandroid.com/foto-y-v...sde-tu-android
          De aquí a nada, con el móvil y el frigo ... lo demás nos sobra .
          Salu2. Carmelo ( O L A J E )
          Mi web:
          https://alcorai.net
          https://olaje.com
            hombre ,yo lo veria mas practico si sirviera para recargar la bateria del movil con energia eolica
            He invertido casi toda mi fortuna en mujeres y barcos
            y el resto?...el resto lo he desperdiciado
