Opiniones de un nuevo Fast cruiser
  • Opiniones de un nuevo Fast cruiser
    Como algunos sabréis llevo mucho tiempo buscando barco por todos los rincones. Me ha llegado una oferta de un barco que se está construyendo en Ukrania y lo someto a vuestro juicio, que os parece el juguete?
    Hay que ir hasta Kiev a verlo, el precio son 119000€ con velas, electrónica y transporte incluído, sin impuestos.
    SPECIFICATION
    General
    Builder: The Research and Production Shipyard “Norman Yacht & Pavel Shaposhnikov Design” LTD
    Dimensions:
    LENGHT OVERALL 12.20 m
    BEAM 4.20 m
    DRAFT 2.50 m
    DISPLACEMENT 6400 KG
    BALLAST 3100 KG
    MAINSAIL 51 m2
    GENOA 40 m2
    SYMETRIQUE SPI 134 m2
    P 15.60 m
    E 5.41 m
    J 4.70 m
    FL MAX 16.30 m
    LP MAX 5.25 m
    STL (POLE) 5.25 m
    STL (BOWSPRIT)
    AUXILIARY DIESEL Volvo D1-30/130S
    CE APPROUVAL A, 9 PERSONS
    CONSTRUCTION
    WHITE HULL POLYESTER RESIN, HAND LAY UP,
    Monolithic GRP hull hand-laid into a 2-part opening mould.
    Barrier coat used to guard against osmosis.
    Isophtalic NG gelcoats used to ensure bright and lasting finish.
    then Cristic 489PA - Isophthalic Polyester Resin for Matched Performance, is approved by Lloyd’s Register of Shipping for use in the construction of craft under their survey.
    Follow up - Scott Bader Polyester resins used throughout
    Hull structure glued and laminated to hull for strength.
    BULKHEADS are bonded to both the hull and deck using special high-performance polyurethane adhesives and fixed by glass fiber
    BILGE AREAS finished with a gelcoat paint
    Under water part - two lay Epifanes Westwind Antifouling
    WHITE DECK POLYESTER RESIN, HAND LAY UP,
    WHITE INTERIOR MOULDING,
    MARINE PLYWOOD MAIN BULKHEAD,
    LEAD T-BULB KEEL
    POLYESTER RUDDER WITH STAINLESS F16 PH SOLID STOCK ON SELF ALIGNING BEARINGS
    DECK EQUIPMENT
    TWO Wheels Steering System
    OPEN STAINLESS STEEL PULPIT
    ANCHOR CHAIN WELL IN BOW DECKING
    8 REINFORCED STANCHIONS WITH TWO WIRE LINES
    STAINLESS STEEL AFT PUSHPIT
    4 ALUMINIUM MOORING CLEATS
    2 GENOA TRACKS
    1 MAINSAIL TRACK
    2 PRIMARIES WINCHES 50 AST
    2 HALYARDS WINCHES 46 AST
    2 MAINSHEET WINCHES 48 AST
    7 SPINLOCK DECKSTOPPERS
    3 WINCHES HANDLE HOLDERS
    3 LOCK-IN WINCHES HANDLES
    1 COMPASS
    TWIN TITANIUM WHEELS 950 MM FITTED ON CUSTOM MOLDED PEDESTALS
    EMERGENCY TILLER
    GAZ BOTTLE STORAGE
    SPARS AND RIGGING
    Allspars 9/10°TAPERED ANODISED ALUMINIUM MAST WITH 2 SETS OF AFT-SWEPT STEPPED SPREADERS MAST STEP WITH
    IRC/IMS CONNECTION
    ANODISED ALUMINIUM BOOM
    DYFORM RIGGING ROD KICKER
    WIRE BACKSTAY ADJUSTER
    ALUMINIUM POLE DIAM 90MM LG 5.25 MM
    1 SPECTRA MAINSAIL HALYARD WITH SNAPSHACKLE
    2 SPECTRA JIB HALYARDS WITH SNAPSHACKLES
    1 SPI HALYARD WITH SNAPSHACKLE
    1 OUTHAUL MAINSAIL
    2 REEF LINES
    1 MAINSHEET
    1 MAINSAIL TRAVELLER LINE
    2 JIB SHEETS
    2 JIB TRAVELLER LINES
    SAILS
    Standard Mainsail 3Di 780M (Dyneema/Carbon) 14,700 Dpi
    Jib Light/Medium 3Di 780M (Dyneema/Carbon) 10,850 Dpi
    Jib Medium/Heavy 3Di 780M (Dyneema/Carbon) 16,800 Dpi
    Jib Heavy 3Di 780M (Dyneema/Carbon) 19,600 Dpi
    A1.5 MH Asymmetric SuperLite/Kote SK 75/60
    S4 MH Spinnaker SuperLite/Kote SK 90 / A3 Fractional Asymmetric SuperLite/Kote SK 130
    ELECTRICITY
    12 VOLTS CIRCUIT 2 X 100 AH BATTERY WITH SWITCHES
    12 V ELECTRICAL PANEL WITH 12 SWITCHES AND VOLTMETER
    ENGINE & EQUIPMENT
    ENGINE Volvo D1-30/130S SAIL DRIVE
    75 L PLASTIC OR ST/STEEL FUEL TANK AND FUEL GAUGE SOUND INSULATED COMPARTMENT
    2 BLADED PROPELLER
    ENGINE PANEL RECESSED IN THE COCKPIT
    ELECTRONICS
    H3000 Hydra Base Pack
    213 Masthead Unit - Standart Pack
    Speed Sensor Pack
    Depth Sensor Pack
    H3000 20/20 HVision display pack
    B&G Halcyon 2000 Compass Sensor
    BandG ZEUS 8 inch
    ADDITIONAL
    El. switchboard with at least 16 switches,
    battery meter, (water meter as option)
    12V socket etc.
    Topping lift and downhaul for spinaker,
    Boom lift,
    Deck stoppers on mainsheet
    Water heater
    INTERIOR LAYOUT
    ALL JOINERY WORK IN OAK WHITE
    VINYL LINED OR ALUMINIUM WHITE COATED CELLINGS
    MICROFIBRE UPHOLSTERY
    FORWARD CABIN
    LARGE DOUBLE BERTH
    COMPANIONWAY COVER
    2 SPOTLIGHTS
    LARGE HANGING LOCKER
    FORWARD HEAD ON STARBOARD SIDE
    CHART TABLE
    LARGE CHART TABLE FACING FORWARD
    LARGE HINGED INSTRUMENTS PANEL WITH ELECTRICAL PANEL
    NAVIGATOR SEAT WITH LOCKER
    OPENNING HATCH
    GALLEY
    GIMBALLED GAS STOVE WITH OVEN AND 2 BURNERS
    STAINLESS STEEL SINK PRESSURISED COLD WATER
    75 L MOULDED ICEBOX ICEBOX/FRIDGE LARGE
    CLOSED LOCKERS
    OPENNING HATCH
    AFT CABIN ON STARBOARD SIDE
    ACCES DOOR TO SALOON
    LARGE DOUBLE BERTH
    OPENING PORT-LIGHT 2
    SPOTLIGHTS
    HEADROOM : 1,80 M
    AFT CABIN ON PORT SIDE
    LARGE DOUBLE BERTH
    SPOTLIGHTS
    HEADROOM : 1,80 M
    WATER SYSTEM
    ELECTRIC BILGE PUMP INTO SALOON
    HAND-OPERATED BILGE PUMP IN COCKPIT
    2 FLEXIBLE OR ST/STEEL100L WATER TANKS
    PRESSURISED WATER YSTEM FLUSH VALVES
    ACCES DOOR TO SALOON CLOSED LOCKERS MARINE TOILET
    SINK RECESSED IN SYNTHETIC RESIN COLORED OR ST/STEEL
    WORKTOP PRESSURISED COLD WATER SHOWER WITH PUMP
    OPENING HATCH
    SPOTLIGHT
    HEADROOM : 1,80 M
    SALOON
    SETTEE/BERTHS TO STARBOARD AND PORT
    SIDE TABLE WITH DROP LEAFS LOCKER
    STAINLESS STEEL OR OAK HANDRAILS
    2 FIXED COACH-ROOF PORT-LIGHTS
    2 SPOTLIGHTS
    HEADROOM : 2 M
    Que es mi barco mi tesoro,
    que es mi dios la libertad,
    mi ley, la fuerza y el viento,
    mi única patria, la mar.
    https://www.facebook.com/pages/Juriola/214037382001173
    Documentación y fotos de la construcción:
    https://www.dropbox.com/sh/u7ktl11am...uOakJ4Y3a?dl=0
    Re: Opiniones de un nuevo Fast cruiser
    Originalmente publicado por Juriola Ver Mensaje
    SPECIFICATION
    General
    Dimensions:
    BEAM 4.20 m
    DRAFT 2.50 m
    BALLAST 3100 KG
    MAINSAIL 51 m2
    GENOA 40 m2
    P 15.60 m
    E 5.41 m
    J 4.70 m
    FL MAX 16.30 m
    LP MAX 5.25 m
    STL (POLE) 5.25 m
    STL (BOWSPRIT)
    CONSTRUCTION
    LEAD T-BULB KEEL
    DECK EQUIPMENT
    2 GENOA TRACKS
    1 MAINSAIL TRACK
    1 COMPASS
    EMERGENCY TILLER
    GAZ BOTTLE STORAGE
    SPARS AND RIGGING
    IRC/IMS CONNECTION
    1 OUTHAUL MAINSAIL
    2 REEF LINES
    1 MAINSHEET
    2 JIB SHEETS
    SAILS
    ELECTRICITY
    ENGINE & EQUIPMENT
    2 BLADED PROPELLER
    ELECTRONICS
    Speed Sensor Pack
    Depth Sensor Pack
    BandG ZEUS 8 inch
    ADDITIONAL
    12V socket etc.
    Boom lift,
    Water heater
    INTERIOR LAYOUT
    FORWARD CABIN
    LARGE DOUBLE BERTH
    COMPANIONWAY COVER
    2 SPOTLIGHTS
    CHART TABLE
    OPENNING HATCH
    GALLEY
    CLOSED LOCKERS
    OPENNING HATCH
    LARGE DOUBLE BERTH
    SPOTLIGHTS
    HEADROOM : 1,80 M
    LARGE DOUBLE BERTH
    SPOTLIGHTS
    HEADROOM : 1,80 M
    WATER SYSTEM
    OPENING HATCH
    SPOTLIGHT
    HEADROOM : 1,80 M
    SALOON
    2 SPOTLIGHTS
    HEADROOM : 2 M
    Hombre yo que sigo tus hilos y comentarios , creo que por ese precio, no vas aconseguir nada mejor.
    Asi que animo con el.( el Astillero se ve un poco ???)
    Pero si te lo construyen desde el principio, es cuestion de seguir la tuya.
    Lo dicho duro con el.
      Respuesta: Opiniones de un nuevo Fast cruiser
      No idea, hay alguno ya en el agua?
      Este lo viste, no? http://www.jpk.fr/?titre=jpk-38-fast...ier_jpk&id=440
        Si el JPK 38 sería perfecto si lo pudiera pagar
          Re: Respuesta: Opiniones de un nuevo Fast cruiser
          Originalmente publicado por Salat Ver Mensaje
          Pues en esta web, en "OCCASIONS", aparecen algunos más asequibles, de segunda mano, claro.
          Y la pregunta del ignorante, ¿que es un Fast cruise?
            Un fast cruiser, traducido literalmente del inglés es un "crucero rápido" en varias marcas abreviado como FC (igual que los fabricantes de coches, les llamaban GT a los gran turismo) Suelen ser barcos ligeros, planeadores, para largas travesías con vientos portantes, mayores muy grandes y completos juegos de velas de proa, asequibles para tripulaciones reducidas y capaces de hacer 300 millas en un día.
              Eeeehhhh... Ucrania es un país en guerra, y el tal Pavel Shaposhnikov puede que te reciba de esta guisa:
              https://www.linkedin.com/pub/pavel-s...kov/1b/557/4a5
              Y es él, no un homónimo.
                Jja! pues si es él, que miedo!!!
                  Procura llevar el dinero en efectivo y no regatearle. Si este es él, no me quiero imaginar al jefe del departamento de reclamaciones.
                  "Al marinero cuando le dan de beber, es que está jodido ó lo quieren joder". Saber popular
                    No me gusta. Sobre el papel parece todo correcto, pero esas fotos no me gustan. Las líneas de trancanil son extrañas, no parecen corresponder mucho con las de los dibujos.
                    Parece que le falta volumen a proa, sobre todo en la amura. Los volúmenes no se aprecian bien, pero no me parecen líneas muy armoniosas.
                    Los portillos de la cabina son distintos a los de los dibujos, y no son nada bonitos..
                      en busca del barco rápido
                      je je
                      Pavel tiene varios barcos rápidos de varios tamaños
                      desde 1981 construye y diseña
                      cuando salió el pogo40 hace unos años hizo una copia
                      muy parecida, a un precio muy inferior
                      del tema del certificado CE, no se comenta
                      (para ponerlo en bandera belga etc creo que te lo pedirán)
                      Editado por última vez por maka; 14/09/2015, 00:15:39.
                        La verdad es que si , fijandose bien en las fotos !!!!!
                          Le pedí fotos de interiores y si existía la posibilidad de quilla abatible, me ha mandado fotos del interior de un pogo y un dibujo de perfil que no se a que barco pertenece y unos layouts alternativos, que tampoco se si son correctos
                            Tu mismo.
                            Como one-off, poco mas o menos.????
                              E-mails de hoy con Pavel:
                              Hi Pavel
                              The photos you sent me are from a Pogo and also the upgrade lifting keel 3d.
                              Ukraine is not now a very safe place, there is a war up there!
                              You should change your profile photo in Linkedin, it looks a litle scary.
                              So the boat, wit CE mark, with lifting keel , sails, electronics, transport to Spain, is 145.000€ ?
                              regards
                              su respuesta:
                              yes, correct with photos
                              I change my photo, I Adviser to the Governor on matters of defense and my many contacts abroad were related to the organization of defense, weapons and new developments.
                              But now the war is almost over, it was a local conflict, a far cry from Sumy and real people here knew about the war only from the reports on TV, just like you
                              Thank you for your remarks
                              So the boat, wit CE mark, with lifting keel , sails, electronics, transport to Spain, is 145.000€ ? Yes, correct
                              kr
                              Pavel
