    145- Hélices de barco
    (Pueden valer para maquetas o para tener como colección de modelos en miniatura no para una embarcación de verdad).
    https://cults3d.com/es/modelo-3d/her...ices-de-bateau
    Editado por última vez por LSV; 19/09/2023, 10:32:40.
    LSV - BARCO KAU-BÉ.
    MMSI: 261000743
    VER Mi canal en YOUTUBE
    VER TODOS MIS DISEÑOS 3D
      Huy! Ese es mío..
        Pasacascos para cables de sonda
        Cover for a Lowrance transducer cable to pass through a fiberglass boat hull.
        EA4YV
        • Reunir ficheros impresión 3d barco
          Buenos días. tabernero, cafés con brandy!
          Que material es mejor para que aguante el ambiente marino, sal, agua etc? Y el que aguanta más fuerza?
          Mil gracias y muy buena iniciativa.
          Peanut.
          Sent from my 21091116UG using Tapatalk
            Soporte de barandilla para motor de proa Minn Kota
            Two various size of rail supports for Minnkota Terrova rig/shaft (33mm diameter).A snap-on claw for 25mm hand rail and the Terrova's 33mm rig.Distance between 160mm or 220mm (two separate files). Please check the actual length and compatibility for your solution before printing.The rail and the shaft should be lined up, atleast almost.The Minnkota logo is just for honoring the great trolling motor and its boost sale purposes, not making my thing popular.Please use with your own risk. The support will not prevent any damage and it's not tested in heavy conditions. Not sure can the support harm the trolling motor or the hand rail.Printed with PLA and 30% infill.
            Soporte para el mando a distancia del Minn Kota iPilot.
            This is a holder for the Minn Kota i-Pilot remote. The remote also fits in updside down (see pictures). You may ask why would I want to use the i-pilot upside down? Well, that way if you press left the boat goes left when sitting in reverse direction.It is recommended to use the reinforced version (ipilot_holder_w_stronger_clips.stl).Mounting:4 screws or 2 cable tiesUpdate 2018-02-26: I added a version with stronger clips.
              Originalmente publicado por Peanut Ver Mensaje
              Peanut.
              Sin duda hay que utilizar ASA.
              El más duro de los disponibles.
              Con la dureza del ABS pero con protección específica para los rayos ultravioleta y la sal.
              Y mayor resistencia al calor. (Yo lo uso para hacer las ASAS y los pomos de las tapas de las cazuelas de la cocina, pese a todo que no le de el fuego directo
              Editado por última vez por LSV; 15/02/2023, 11:35:46.
              LSV - BARCO KAU-BÉ.
              MMSI: 261000743
                Originalmente publicado por bacilococo Ver Mensaje
                https://www.thingiverse.com/thing:755767
                Gracias por el enlace. Añado la foto.
                LSV - BARCO KAU-BÉ.
                MMSI: 261000743
                  Añado las fotos.
                  LSV - BARCO KAU-BÉ.
                  MMSI: 261000743
                    Por si os es útil.
                    Extraer y colocar las fotos de Thingiverse:
                    Para sacar la foto:
                    Dar con el botón derecho del ratón (si usas ratón) y pulsar en "copiar enlace de la imagen".
                    Luego en el Foro se coloca la imagen desde el mismo sitio que el enlace, pero pulsando el recuadrito amarillo con una montañita y un sol.
                    Y ya está.
                    Editado por última vez por LSV; 26/09/2023, 10:30:37.
                    LSV - BARCO KAU-BÉ.
                    MMSI: 261000743
                      Tales of Berseria: COMPÁS DECORATIVO
                      https://www.thingiverse.com/thing:2821911
                      Editado por última vez por LSV; 06/08/2025, 13:09:51.
                      LSV - BARCO KAU-BÉ.
                      MMSI: 261000743
                        Sailboat - ship - decoration
                        https://www.thingiverse.com/thing:5201992
                        Editado por última vez por LSV; 06/08/2025, 13:10:00.
                        LSV - BARCO KAU-BÉ.
                        MMSI: 261000743
                          WINCHE HARKEN UÑA EXTRACTORA
                          https://www.thingiverse.com/thing:4869751
                          Editado por última vez por LSV; 06/08/2025, 13:10:11.
                          LSV - BARCO KAU-BÉ.
                          MMSI: 261000743
                            ANCLA BRUCE ARADO (ENTRADA CON REGISTRO GRATIS)
                            https://grabcad.com/library/anchor-b...uction-sumar-1
                            Editado por última vez por LSV; 06/08/2025, 13:10:22.
                            LSV - BARCO KAU-BÉ.
                            MMSI: 261000743
                              ESTABILIZADOR PARA BEBIDAS (OJO DES-ESTABILIZA AL PATRÓN)
                              https://www.thingiverse.com/thing:3478264
                              Editado por última vez por LSV; 06/08/2025, 13:10:30.
                              LSV - BARCO KAU-BÉ.
                              MMSI: 261000743
                                POR SI ACASO...
                                Beer Bottle Lock: When you have guests over for the holidays, don't cast pearls before swine. Make a 3D-printed bottle lock for the craft beers, and let your friends and family drink the cheap ones. Bah Humbug! If you want to see me 3D model a version of this projec…
                                Editado por última vez por LSV; 06/08/2025, 13:10:44.
                                LSV - BARCO KAU-BÉ.
                                MMSI: 261000743
