Reparacion de timon
    Re: Reparacion de timon
    Interesantísimo hilo. Muchas gracias Itaka y Alakran.
    Alakran, esperamos el final de tu brico-historia.
      Sorry por el idioma foraneo
      FILLERS (ADITIVOS)
      Fillers are additives mixed with activated epoxy resin to increase bulk, prevent sagging and to change color. Many things can be used as fillers including saw dust and sand. However, saw dust is not generally uniform in size and sand is heavy, both may well contain undesirable elements other than wood or sand. An industry has developed to provide predictable fillers for everything from ice cream to concrete.
      SILICA is a "thixotropic agent" added to prevent sagging of thickened POXY-SHIELD® resin, especially on vertical and overhead surfaces. Silica and activated epoxy resin is also used to form high-density filleting materials and putties. Silica is used in combination with our other fillers to give the mix a smoother or creamier consistency.
      MICROSPHERES are microscopic, hollow, gas-filled spheres in a fine powder form of low density and weight. They extend the resin and increase the viscosity, forming what is called a "syntactic foam" in higher volumes, ideal for fairing/filler compounds, putties, for making low-density fillets, and for use as a laminating adhesive where gap filling qualities are desirable. The main advantage of Microspheres is that it makes the cured resin mixture easier to sand; the more Microspheres added, the easier sanding becomes. However, if too much Microspheres is added, the mix becomes unworkable. For laminating work, the activated resin/Microspheres mixture is usually still quite fluid. Order on the basis of 1 lb. per gallon of resin for a creamy consistency, or 2 lbs. per gallon for a more paste-like consistency.
      FIBER is added to activated POXY-SHIELD® as a thickening agent for use as a structural adhesive or glue. lt provides excellent gap filling qualities while retaining necessary wetting and penetration to prevent glue-starved joints, especially in end or edge-grain situations. The amount added varies depending on the gap filling properties desired; if the joint is a close fit, only a small amount (5% to 15% by volume of resin) is required. Larger percentages are necessary for filling larger gaps. Order on the basis of 1 to 1 1/4 lb. per each gallon of resin as an approximation when POXY-SHIELD® is to be used as a glue. Mix with small amounts of our #1 Silica filler to form a smoother, non-sagging consistency.
      WOOD FLOUR is used as a thickening agent in fillets, fairing putties, or glues when the surface is to be finished natural. Not as creamy or easy to work as #1 Silica, but the only one of our fillers that has a wood color. You can add one of our other fillers to adjust color and change the characteristics. Order on the basis of approx. 1 lb. per gallon for a creamy consistency or approximately 2 lbs. for filleting purposes.
      GRAPHITE POWDER is used as a coloring agent and to produce low friction exterior surfaces. Graphite Powder is a fine black powder that can be mixed with activated POXY-SHIELD® to make a low friction coating, commonly used on boat bottoms, rudders and centerboards. Not used where the coating will be exposed to strong sunlight. Graphite/POXY-SHIELD® coatings do not provide any anti-fouling qualities but do offer a tougher, more mar resistant surface. Caution: Graphite is a conductor and can cause electrolysis problems in salt or brackish water. Add up to 10% by volume.
      A NOTE ABOUT TALC: Talc is another material that can serve as a filler. We have done testing with talc in a wide range of bonding situations and have found that it works similarly to Silica or Microspheres, with similar initial bond strength capabilities. However, there is a question about the tendency of talc to absorb moisture, and in some conditions, this may result in questionable results. Hence, we feel that the conservative practice is to avoid its use.
      Editado por última vez por malamar; 09/08/2007, 15:11:37.
      ..la lontananza sai
      é come il vento
      spegne i fuochi piccoli,
      ma accende quelli grandi
        Uff Como He Acabado De Epoxi Este Medio Dia¡¡¡, Le He Dado La Segunda Mano¡ Resulta Que Los Que Me Proporcionaro El Epoxi Me Dijeron Que Masilla No Hay, Como El Rocadur O La Masilla De Fibra, Sino Lo Que Me Venderian Es Silice En Polvo Y Que Dependiendo Y El Uso Asi Deberia Mezclar Sin Mas Instrucciones Y Pidiendome Por El Silice 25 Napos, Ahhhy Al Final Me Va A Salir Igual Que Comprarme Un Halberg Rassy A Plazos¡ Asi Que Lo Dejé Pero El Que Estos No Tengan ,y Te Dieran Un Apaño No Pense Que No Existiria.
        VENENO, VENENO DEL BUENO
        • #34
          YA CON LA MALLA Y LA PRIMERA MANO DE EPOXI (SE VE LA MALLITA Y EL BRILLO)
          ANTES DE LA SEGUNDA MANO Y CON HERRAMIENTAS ADECUADAS, HE VACIADO BURBUJAS DE AIRE INEVITABLES EN ALGUNOS VERTICES,ENFIBRADO LIJADO Y LA SEGUNDA MANO, Y ASI LA TERCERA.
          • #35
            “Ño” Alacrán eso si que es un timón “tuneao” “mimao” y “cambiao”, estupendo el resultado seguro que estara mejor que cuando era nuevo.
            Gomonne
            • #36
              Originalmente publicado por malamar Ver Mensaje
              ¡ ...ole las bricolantas rumbosas y determinadas...!!
              Documento refinitivo...t'has fijao Alk ??
              Jajajaja, pos aqui con un poquito de humor, estooy toa rumbosa con modelito bricolajero.
              Quitando la parte del enfibrado y lijado de la orza, la verdad es que me lo "curre" como las buenas, fué una semana de trabajito duro, contando que vivo a bordo con perrita y todo, pa contar anecdotas las que queraís.
              Shot with u-miniD,Stylus V at 2007-08-09
              En fín, un toque de humor pa estos dias estivales
              En la mar, respeto, prudencia y humildad
              • #37
                tas francamente atracativa , muchacha, ...eso en las noches locas de Ibiza...lo ultimo, ...pero ozuuu ...la calorina que debe de darrrr....
                ..la lontananza sai
                é come il vento
                • #38
                  Extraordinarios, reportajes y trabajos, tomo nota del inox bajo en agua.
                  • #39
                    No, si al final el Abebe Biquilla gana el marathon...veras...
                    y le da en to los morros a este que suscribe por
                    esceptico y descreido
                    ..la lontananza sai
                    é come il vento
                    • #40
                      Muy bien Marcia, eres una bricolera total, las fotos muy bien
                      • #41
                        Ot-tia, ALAKRAN, me parto de risa con tus explicaciones bricolajeras
                        Espero que quede el tema solucionado y puedas navegar bien este verano.
                        Itaca querida, te ha quedado un timón de CINE
                        Un post muy interesante, aunque mi barco no es de fibra,
                        pero siempre se aprende
                        HermanA de la Costa
                        • #42
                          ..la lontananza sai
                          é come il vento
                          • #43
                            Retomo el post por lo que almenos querian ver el timon terminado, resulta que una vez de dado varias capas de epoxi, lije relijé y me re arrasque durante una semana, con la intencion de dejarlo lo mas fino posible, como el culito de un bebe. segundo paso fue relleno de masilla en los vertices, que es zona harta dificil para la manta.
                            Para la terminacion se le aplicó hempatex (imprimacion)
                            y su correspondiente patente quedando el trabajo como se expresa
                            Bueno espero que os haya gustado y por lo menos algo mejor que estaba, seguro que la hemos dejado,
                            Querido malamar quizas los suyo hubiera sido hacerte caso y llegar hasta su raiz pero amigo eso es demasiado curro para agosto y tenia que intentar aprovechar algo las vacas navegando.
                            Y a itaca BRAVISSIMO¡¡¡¡
                            • #44
                              Majestuoso ALK...
                              Si no veo la afoto no te creo nada
                              El bricolahe malahe ya no tiene barreras para ti
                              ..la lontananza sai
                              é come il vento
                              • #45
                                Este hilo va a mis favoritos,
                                Enhorabuena a los bricotimoneros,
                                www.anavre.org
