Por que los arneses sujetan solo arriba ?...algunos.
  • #46
    Re: Por que los arneses sujetan solo arriba ?...algunos.
    sí, era este!!! Esto es a lo que me refería:
    His report concludes that James Meaby probably survived the initial incident and remained alive, floating in a survival mode, for a period in the region of at least 12 hours. It continues that it was not possible to deduce how long Rupert Saunders or Jason Downer could have survived after initially entering the water. Importantly, however, the expert concludes that they would have had little beneficial support from their lifejackets because they were both poorly fitted. Despite this, it is possible they would still have been capable of surviving at least 3 hours
    It appears that James Meaby survived much longer than his two fellow crewmen because his lifejacket was fitted properly. The report further concludes that simply fitting crotch straps to the lifejackets, which are normally sold as a cheap optional extra, would have enabled them to have stayed in the correct donning position, irrespective of how tight they had been fitted. Had crotch straps been fitted to their lifejackets, it is possible that all three crew would have survived for longer than 12 hours.
    Crotch straps son las cinchas entrepiernas que suelen venderse como "extra opcional"
    O sea, los que no llevaban cincha entrepiernas en el chaleco solo aguantaron 3 horas vivos y el que llevaba cincha entrepiernas aguantó 12 horas!
    Gracias por la ayuda meteoro
    Salud y libertad
    scipio
    Editado por última vez por cónsul scipio; 07/01/2014, 11:45:57.
