Vendée-Globe 2012-2013...
    -bueno, dicen en la web que el helicóptero llega a las 23:00 h. ( de noche). Eperemos que le localicen y le suban a bordo.
      Lo siento de verdad, se merecía la llegada.
      Buen día
        Maldicion!!!!
        Quedara el consuelo de que ha estado muy muy cerca y solo la fortuna ha impedido el wxito
        Esta localizado y no debe haber problema para el rescate
        Un brondis por el
        Vaea
        S 13° 51' 49 W 171° 46'
        Dig the grave and let me lie.
          :a la puerta de casa....solo quiero pensar en que salga bien el rescate...todos mis respetos para bubi....despues de la magnifica regata que hizo....lastima que termine asi...
            Qué pena, joder !!
            Suerte en el rescate y un abrazo para él
            KUMI
              Que lástima, de piedra nos quedamos aquí.
              Animo resiste hasta el rescate.
              Ya no importa tanto pero no van a penalizar a JPD
              No Penalty for Jean-Pierre Dick
              DECISION of CASE 6 - COMPLAINT OF 2 February 2013 –
              RACE COMMITTEE AGAINST VIRBAC PAPREC 3
              Findings
              After suffering the loss of her keel on January 21, Virbac-Paprec 3 still carried on the race and continues sailing towards the finish line.
              January 30, weather forecasts indicate winds of 30 to 35 knots in the Bay of Biscay. VP3 skipper decided to find shelter and wait for easier conditions for crossing the Bay of Biscay, to avoid capsizing or overturning.
              Approaching the port of San Ciprian, JPD unsealed the engine and anchors, anticipating possible difficulties while he was mooring to a buoy.
              When mooring up in the morning of January 31, JPD usedengine taken for 3-4 minutes to facilitate the maneuver.
              VP3 remain moored until February 3, 7:20 Z deciding to sail again towards the finish in Les Sables d'Olonne.
              Conclusion
              The skipper made ​​all docking maneuvers and starting on his own and did not receive outside aid.
              In breaking the seals then using the engine at its mooring to a buoy, VP3 violated Articles 13.2 and 13.3 of the Notice of Race.
              Using the engine only to secure the docking maneuver and during a very short time (3-4 minutes), the skipper acted as good seaman and did not benefit from his breach of the articles cited above.
              The jury concluded that VP3 is a minor offense.
              Decision
              Under the Notice of Race 11.2.6 (a), the jury decided not to award a penalty to VP3.
              February 3, 2013
              The International Jury
              Bernard Bonneau (FRA), Ana Sanchez (ESP), Trevor Lewis (GBR), Jack Lloyd (NZL; Georges Priol (FRA)
                Es la primera edicion sin abandonos en el indico y pacifico pero el atlantico ha hecho estragos.
                Espero que lo rescaten rapido, no parece 1 rescate dificil.
                  Suerte con el rescate, si simplemente ha volcado y resiste. Por la posición a 500 millas de Madeira no ha tenido mala suerte. De noche será todo más complicado.
                  Animo ACCIONA, Animo Bubi.
                    Al parecer el MRCC de Ponta Delgada ha enviado un avión a la zona y le han localizado en su balsa salvavidas junto al barco volcado. Bubi a utilizado bengalas y señales fumígenas y ha saludado, con lo que es buen indicio de que se encuentra bien físicamente. Esperemos que le rescaten pronto.
                      ¡¡QUE MALA SUERTE!!!!!
                      Ojalá vaya todo bien en el rescate..y ojalá haya tiempo de ponerse el traje seco..
                      Mucho ánimo para Bubi...
                        MIERDA!!!!!!!!! Jod+r, que putada, a una semana de llegar!!!!!!!!
                        Ahora lo prioritario es que salga bien el rescate.
                        Animo Bubi!!!!!!!!!!
                          Qué lástima!!!
                          Me alegra que aparentemente esté bien y espero que sea rescatado en breve.
                          Algo más de info (en castellano) en la Gaceta Náutica
                            J***RRRRRRR.
                            Navegaba en ceñida, en un viento de nordeste de unos 15 nudos. Algunos minutos antes de la activación de los dispositivos, todo iba bien a bordo ya que Javier envió un mail para explicarnos sus condiciones de navegación.
                            Algo gordo ha debido de pasar....
                            Espero que no tenga que estar en la balsa demasiado tiempo y lo rescaten pronto.
                            Si el barco está volcado pero no hundido.....que se hace en estos casos???
                            Animo Bubi!
                              Puf………………………
                              Hosti tú!! Que mala suerte, a una semana de la llegada.
                              Esperemos que el rescate vaya bien, de noche no debe ser fácil.
                              Esta claro que ha perdido la quilla.
                              Ánimo Bubi.
                              Editado por última vez por kailu; 03/02/2013, 22:40:07.
                                Originalmente publicado por jan Ver Mensaje
                                J***RRRRRRR.
                                Animo Bubi!
                                Tiras de la orza si no se ha metido para dentro con fuerza y piedras en los bolsillos para adrizarlo... Lo dice el Glenans. En los Vaurien funciona, a veces se parte y te la quedas en la mano.
