Aislador galvánico baratito
    Re: Aislador galvánico baratito
    Originalmente publicado por Itaca2 Ver Mensaje
    Ufff , ATNEM, me has obligado a un esfuerzo superior al de la propia realización del chisme.
    Bebamos algo ....
    , ya he avisado que uno es un tocagaitas... y siempre me gusta preguntar, preguntar y preguntar (que es la única forma de enterarse de algo...).
    Gracias por tus comentarios,
    ¿Hace una Mirinda?
    Buena proa!
      En realidad debe soportar más corriente todavía, porque debe aguantar hasta que salte la protección. Te adjunto esto para que veas que no es sólo mi opinión. Si es preciso te lo explico, pero... NO JUGUEIS CON ESTAS COSAS SIN SABER DÓNDE OS ESTAIS METIENDO.
      HOW IT WORKS:
      The Galvanic Isolator puts two
      silicon diodes in series with the
      ground connection of your shore
      power connection. Each diode
      provides 0.6 volts isolation to
      DC electrolysis currents for a
      total of 1.2 volts. An additional
      set of diodes provides protection
      for the opposite polarity.
      If you get a wiring fault on your
      boat, the voltage from the fault
      will exceed the 1.2 volt threshold
      so the isolator goes into
      conduction and conveys the fault
      current back to the shore power
      outlet, but small voltages are
      insulated.
      Wiring faults can be divided into
      three classes.
      1. High current short circuit.
      In this case, hundreds, or even
      thousands of amps are suddenly
      placed on the ground lead and
      have to be conducted through the
      isolator. These currents will trip
      the circuit breaker very rapidly.
      The isolator diodes will
      withstand these currents long
      enough to trip the breaker.
      2. Medium current short.
      This is usually a wiring error
      where the returning current is
      going through the ground wire
      instead of the neutral. The
      current is coming from a normal
      load so it will be usually limited
      to something less than the circuit
      breaker rating (30 or 50 amps).
      Since the breaker won’t trip on
      this current, the isolator has to be
      able to withstand this current
      c o n t i n u o u s l y . A B YC
      recommendations require a
      capacity of 135% of rated current
      or 67.5 amps for the 50 amp
      circuits. Our isolator is rated for
      70 amps AC continuous.
      Considerable heating will occur
      if it is carrying maximum current
      for an extended period.
      3. Low current short.
      This is typically leakage to
      ground from an appliance or
      device that has got wet. These
      currents are quite small and the
      ground connection prevents the
      device from giving you a shock.
      Although the isolator will carry
      these currents with no problem,
      you should avoid using this
      capability for an extended period
      since the galvanic protection is
      not being provided when it is
      conducting AC current to
      ground.
      Carlos
      (Manny Adan "in memoriam")
        A ver KANE, deduzco que sabes más de lo que dices y que puedes ayudarme a saber un poco más.
        Yo tambie he leido http://www.yandina.com/acrobats/GIDIYAssy.pdf y no me aporta nada.
        ¿Porque seria mejor (del punto de vista de la seguridad) un transformador de aislamiento a "mi" instalación con una masa a la orza y otra al pantalan separadas por el chisme ese?
        No acabo de verlo claro, a ver si nos ayudas.
        Será el cardhu , será la hora ?
        Rondas pa to quisque
          1- Esos diodos se van a fundir en cuanto tengas un cortocircuito a tierra. Ya estás sin protección y con tu tierra a 220V. También lo harán cuando tengas un fallo que haga que una corriente fuerte (capaz de fundir los diodos) retorne por tierra en vez de por el neutro (más fácil de lo que parece, desgraciadamente).
          2.- Tú te refieres a la protección que ofrece el diferencial frente a una fuga a tierra. En efecto, corta. Pero hasta que corta, la corriente de fuga a tierra, si la hay, TODA, pasa por los diodos. Si es grandecita (cientos de amperios)... Puff! Otra vez sin tierra.
          3.- Si en vez de una fuga hay un cortocircuito, el diferencial no va a saltar, al menos por fugas, lo hará el magnetotérmico. Dos casos: fuga franca, cientos de amperios por los diodos hasta que el magnetotérmico corta o ESOS DIODOS se funden, actuando como fusibles. Si es de bajo valor, insuficiente para que salta el MTT, los diodos deben aguantar esa corriente.
          4- Los diodos que se emplean en los separadores galvánicos tienen que ser mucho mayores que los que estás usando, y tienen que ir montados sobre un disipador -vamos a llamarlo eficaz- porque se calientan.
          5- A la más mínima fuga pierdes la protección galvánica/electrolítica.
          Carlos
            Porque te aísla POR COMPLETO del pantalán (ojo, estamos hablando del montaje de Yandina, no una variación casera ) Es la BUENA SOLUCIÓN
            El inconveniente -grossen problem- es que por el trafo pasa toda la corriente consumida, y puedes llegar a necesitar todo un señor transformador, grande, pesado y carísimo, puesto que debe tener un muy buen aislamiento entre primario y secundario.
            Hace muy poco los del Alea comentaban que habían instalado uno. ¡Bien hecho, chicos! ¡Será por pelas...!
            Dices:
            " Yo tambie he leido http://www.yandina.com/acrobats/GIDIYAssy.pdf y no me aporta nada."
            Pues te recomiendo que cambies de opinión. Está muy clarito y, en serio, te va la vida en ello.
            Carlos
              Me parece correcto lo que dices salvo en un punto: si se funden los diodos me queda toda la instalación a "tierra" ya que está conectada a la orza, hélice y ánodos del barco, que son una buena "tierra" a potencial 0 y no como la del pantalán, que vete a saber que tiene como potencial. Ah! y en caso de cortocircuito franco (fase-neutro) efectivamente el diferencial no debería actuar sino que actuaría el magnetotérmico pero por el cable de tierra ni un miliamperio.
              Sigo creyendo que es un debate enriquecedor.
              Un saludo y hasta mañana
                Practicando el deporte de escribir entre líneas:
                A ver... Piensa en el concepto de "tierra" como lo que es: un cable verde amarillo que viene del neutro de tu central de suministro y entra a tu instalación.
                También puedes considerar que tu central suministradora es el transformador aislador que has instalado, cuyo secundario está completamente aislado del resto del mundo, mar incluído (esta es la parte difícil de entender). Por consiguiente, en este segundo caso, el hilo de tierra debe salir del neutro del secundario del transformador. Y te olvidas de lo que hay en el pantalán. En efecto, ¿Qué pasa si pones una bombilla entre TU fase y la tierra (o el neutro, me da igual) DEL PANTALÁN? Nada. No se enciende. La tierra del pantalán NO te está protegiendo. Ahora ponla entre tu fase y tu neutro o tierra, los que salen del transformador. Se enciende en ambos casos. Ponla entre tu fase y la orza metálica desnuda y metida en agua salada. Te aseguro, y me juego una mariscada, que NO se enciende (todavía no hemos conectado la tierra del transformador a ningún sitio). Ergo, el agua y la orza no te protegen. Estarás protegido sólo cuando conectes TU tierra, de tu transformador, a tus puntos que deben ser equipotenciales y al potencial de tierra. O sea, las carcasas de los electrodomésticos, el casco si procede, el bloque del motor, la orza, el palo, la jarcia, etc, etc. Ahora, cuando tu nene meta el dedito en un enchufe apoyado en el fregadero, saltará el diferencial por corriente de defecto a tierra salvándole la vida, y cuando el cable pelado de la estufa toque la carcasa hará que salte el MTT por cortocircuito entre fase Y TIERRA. Incluso aunque no haya diferencial, que saltará también en caso de existir (como debe ser). Pero dime: ¿Cuánta intensidad está circulando por el hilo de tierra en este caso hasta que abre el MTT? Toda. Toda la que sea capaz de dar la instalación. ¿Cómo se quedan tus diodos? Fritos. ¿Qué pasa cuando subas el MTT? Todos los puntos conectados a tierra están a 220 V, ya que los diodos han cortado la línea justo en la conexión del hilo de tierra al transformador. Sin embargo, el neutro está a 0 V...mala cosa... Hay que evitar que los diodos se fundan, sea por lo que sea. O si no, pasar de ellos.
                Lo del transformador aislador lo he puesto para tener todos los elementos dentro del barco y no perdernos en el largo, recóndito y complicado camino del hilo de tierra del pantalán hasta su punto de conexión al neutro sabe Dios dónde (si es que está conectado, que lo mismo no). Sería absolutamente igual.
                Totalmente de acuerdo. Aquí no hay problema, pero te falta el caso que he expuesto arriba cuando el corto se produce entre fase y tierra, que es el peligroso (excepto cuando el hilo de tierra cumple adecuadamente su función, sin diodos raros ni manipulaciones estrambóticas).
                Luego tenemos que considerar a Murphy y sus teorías, porque estamos hablando de una instalación correcta y en perfecto estado, pero eso a veces no ocurre.
                Resumiendo: lo guay es tener pasta a espuertas, comprarse un buen transformador de aislamiento, poner ánodos a go-go y conectar todo lo que toque el agua y sea metálico con una conexión equipotencial a tierra y más ánodos. Si son de magnesio, mejor protegidos. Y los demás que se devoren entre sí.
                Para los valientes que se atrevan, la cosa se puede solucionar de forma algo más barata, pero con menos rendimiento, con DOS transformadores aislados (no autotransformadores), iguales, comerciales (por ejemplo 125/220) puestos uno detrás del otro (que no en serie): (entrada) 220-125-125-220 (salida)
                OK, pero todo eso ya está inventado, y viene en los "papeles"
                ¡Nooooooo! ¡Mañana más, no! Mira la hora que es...
                Editado por última vez por Kane; 22/01/2010, 06:16:29.
                Carlos
                  Joder si que sabéis de esto.
                  Itaca II, no me achicharres, a ver si me voy a tener que buscar un amarre más lejos de ti .
                  Itaca II tiene razón en nuestro puerto existen graves problemas de corrosion galvanica, y varios barcos han perdido su cola, y no solo veleros, incluso motoras.
                  Yo tengo instalado un transformador de aislamiento, concretamente este http://www.victronenergy.com.es/isol...3600va-7000va/ de 3600W.
                  La pregunta es ¿con esto estoy suficientemente protegido o me preparo un chisme de los que se muestran en el post? La toma de tierra de salida del trafo está conectada al motor, evidentemente sin contacto con el pantalán ¿es correcto?
                  Unas cervezas virtuales y otras no virtuales si pasáis por nuestro puerto.
                  La palabra filibustero proviene del holandés "Vrij Buiter" ("el que va a la captura de botín"), en inglés "freebooter".
                  Acostumbrados a vivir con absoluta independencia, no permitieron que les rigeran superiores, leyes o códigos. Nacía así "La Cofradía de los Hermanos de la Costa".Los filibusteros atacaban barcos de cualquier nacionalidad, aunque una vez más serían los españoles sus presas las más de las veces.
                    ¡Acongojado me he quedado!
                    Ya lo tengo clarísimo: hoy voy y corto el cable de 220 en redondo, así no tendré más la tentación de enchufarlo...
                    Y cuando me quede sin baterías y no pueda poner el motor en marcha, saco al nene del amarre a remo...
                    Buena proa!
                      Acabo de comprender lo que me pasó el otro día.
                      Un GC se bajó de la patrullera y se fue a tomar un café.
                      Vi que se le caía un papel del bolsillo, y antes de devolvérselo me dio tiempo a leer la lista que llevaba.
                      Chalecos...bengalas...espejo de señales... ¡Era una chuleta!
                      Pero lo más terrrorífico es que a mano, al final de la lista poniía...
                      ¡CAJITAS DE PLÁSTICO JUNTO AL CABLE DE TOMA DE ELECTRICIDAD!
                      Ojo. Ponedle por fuera una pegatina que diga: DGMM-Homol-3p0-955 (p.ej.)
                      ~EL HILO DEL BOTIQUÍN ~
                        Atnem, tienes una solución intermedia, menos drástica
                        Compra un transformador 220 V/24 V, barato, en los chinos. La potencia, se verá luego.
                        Lo dejas en el pantalán, lo más escondido que puedas (y protegido, no se vaya a mear un perro encima).
                        Al barco tiras un cable gordote, más de lo habitual, con 24 V.
                        Ahí enchufas el cargador. Si no hay más eggs, con otro trafo 24/220. Ya puedes cargar las baterías y prescindir de tomas de tierra y gaitas. Tienes una instalación de seguridad a 24 V, tan segura como lo sea el transformador, pero vale para lo que es. Eso sí, el núcleo del trafo conectado a la tierra del pantalán. El secundario, libre.
                        A esos 24 V puedes conectar luces, cargadores, cositas así que en total no superen la potencia del bicho. Si te viene mejor que sea de 12 V en vez de 24, mejor aún a cambio de cables más gordos.
                        Ya no necesitas aisladores galvánicos ni electrolíticos (no estás conectado al pantalán). Ni tampoco tomas de tierra. Ánodos, si, claro. No tendrás corrosiones asesinas. Como comprobación, de vez en cuando, mide la resistencia entre tu instalación y la del pantalán (esto puede ser objeto de otro tocho) y si es muy alta, todo va bien.
                        Edito, se me olvidó. Si quieres neveras, acondicionadores, cocinas eléctricas, etc, es otro mundo. Necesitas una instalación homologada (maldito palabro...). Hablamos.
                        Editado por última vez por Kane; 22/01/2010, 17:47:03.
                        Carlos
                          Gracies Kane, de verdad.
                          Pero ya que estamos, hago una reflexión en público:
                          En el barco actual (dejemos de momento los anteriores) que hace unos 6-7 años que lo tengo, siempre lo dejo enchufadito al pantalán. Tengo un cargador inteligentísimo (), que además es inverter de 1800 W.
                          Mis baterías de servicios (4X120A) tienen 6 años y de momento siguen rindiendo.
                          Los ánodos tienen un desgaste digamos que mínimo (solamente se me gasta el pequeñito del final de la Gori y poquito más.
                          No he tenido nunca un problema de corrosión galvánica.
                          En invierno, cuando puedo me escapo a verlo y tengo una estufita de aceite de 1000 W que me da calorcita.
                          ¿Crees que realmente (teniendo en cuenta lo anterior) conviene liarme con aisladores, cables de 24/12 V, cajas con diodos, etc?
                          Ojo!, aunque a menudo me guste utilizar un cierto tono jocoso, la pregunta anterior es totalmente seria y absolutamente exenta de recochineo o maldad. Simplemente es situar el problema (si lo hay) o ver si es mejor aquéllo de que "lo que funciona, no lo toques".
                          Gracias.
                          Buena proa!
                            [QUOTE=Atnem;746391]
                            QUOTE]
                            Mira Atmen,
                            Entiendo que no lo entiendas, yo tampoco lo entendía (joer que lio de entendimiento ), hasta que me enteré de un Hanse 470 del 2007 que hay en mi puerto (Port Segur Calafell) al que le han tenido que cambiar 2 veces el sail drive por este problema. Justo en ese mismo pantalán hay un cata, un Privilege que le cambiaron los 2 sail drives por el mismo problema. En frente mio una motora (no me acuerdo marca ni modelo) las 2 colas volvo. El último este invierno, un velero precioso y super rapido, llamado "sais light" ha estado fuera del agua unos 3 meses, por lo mismo corrosion en el sail drive. Y así hay unos cuantos más.
                            Si en tu puerto no tienes el problema de fugas de corriente, no hace falta que lo hagas. Pero te aseguro que lo primero que hice al comprar el barco, fue ponerle el trafo,no quiero tener un barco nuevo con el sail drive comido, y te aseguro, que no me ha hecho ninguna gracia el gastarme la pasta en esto, hubiese preferido una gennaker o una helice plegable.
                            Es así de jodido, pero es como es. Si alguien tiene una solución más barata y rápida pues mejor. Ojalá no lo hubiese tenido que hacer.
                            La otra solución es ponerse a pleitear contra el puerto para que arreglen las fugas de corriente, pero de momento y por temas específicos del propio puerto me parece un tema un "poco" complicado.
                            Apa, para celebrar la explicación te invito a unas cervecitas, bueno a ti y a toda la Taberna.
                              Muy buen nivel de conceptos en este hilo. Hay que tener cuidado con estos temas, felicito a Carlos por sus "ideas" claras.
                              En mi caso el tema es vital ya que mi barco es de acero, con sus anodos de sacrificio repartidos por el casco que he de cambiar cada dos o tres años.
                              Origen del problema es la corriente de fuga que se produce por la toma de corriente en la toma de tierra del barco al pantalan cerrandose un circuito electrico por la derivación electrica de barcos vecinos efectuada por la lamina de agua.
                              Si estoy en lo cierto, con un tester podia tomar lectura entre la entrada de tierra (cable amarillo-verde) y cualquier masa de acero del barco y ver su potencial. Si es cero no problem, si hay potencial Es así?
                              LORDRAKE
                              El GRAN AZUL
                                Hola, quiero dar mi opinión sobre el aparatito de marras:
                                En principio, funcionar debe funcionar. El problema que dice Atnen no debe existir si se dimensionan bien los diodos y las cosas se hacen bien. El problema se presenta cuando hay un cortocircuito fase-tierra. En este caso la corriente por el cable de tierra se dispara, pero no va a llegar a cientos de amperios, ya que esa misma corriente es la que pasa por el cable de fase y el magneto cortará a su corriente nominal. Así pues, el chisme funcionará siempre y cuando soporte corrientes mayores que las de corte de los magnetos. Otra cuestión es que los magnetos son lentos, por lo que antes de que corten la corriente puede elevarse por encima de su valor de corte, pero no a miles de amperios, ni cientos. Para el caso de un magneto de 25 A, por ejemplo, creo que poner diodos que soporten 100 A de corriente directa es suficiente, porque, además, por regla general, un diodo que soporta 100 A de corriente directa llega a soportar pulsos de corriente no mantenida bastante más altos.
                                El siguiente problema es conseguir que un diodo soporte lo que dicen las hojas características. Me explico:
                                He usado diodos o transistores que deberían soportar 50 A y se han fundido con corrientes de no más de 10 A. Las características de corriente hay que sobredimensionarlas al menos en tres veces, por la dispersión de características de los semiconductores propia de sus procesos de fabricación, pero además, los valores máximos que da el fabricante son en unas condiciones muy óptimas de refrigeración.
                                Conclusión:
                                No me parece mal el invento, pero yo emplearía diodos con corrientes directas al menos 5 veces superior a la corriente de corte del magnetotérmico. Además, compraría diodos con cápsula metálica y los montaría sobre un disipador (posiblemente habría que usar micas aisladoras ya que las cápsulas metálicas suelen estar unidas a uno de los polos del diodo). Finalmente, probaría el chisme, provocando un cortocircuito fase-tierra y comprobando que no ha muerto. Si resiste cuatro o cinco intentos, daría por pasado el control de calidad.
                                Perdonad por el ladrillo pero me ha parecido que ciertas cuestiones requerían aclaración.
