Viento real sin corredera con GMI10 o i70?
  • #76
    Re: Viento real sin corredera con GMI10 o i70?
    Me parecen muy bien todas vuestras opiniones. Cada uno lleva su punto de razón... y vicios tenemos todos.
    Pero no quiero volver a leer que el aparente generado por la velocidad del barco sirve para navegar o ayuda a ello o mantiene la velocidad del barco o retarda su parada. Creo que quedó claro.
    Esto último tiene el propósito de constituir una referencia clara para cuando se vuelva a suscitar el problema -que volverá- . Citaré este post y punto.
    Cuidaros.
    Carlos
    (Manny Adan "in memoriam")
    • #77
      Ya falta menos para llegar a Mach 1
      The boat that FLIES: Exhilarating images of the world's fastest yacht racing at speeds to up to
      60mph
      Hydroptere can reach speeds of 60mph using its giant 'wings' to lift most of its frame above the
      water
      Mast is 28m high - almost as tall as the Christ the Redeemer statue in Rio de Janeiro, Brazil
      It can reach 50mph in ten seconds and has broken world records with its aeronautic design
      By Anna Edwards
      PUBLISHED: 09:29 GMT, 30 April 2013 | UPDATED: 11:44 GMT, 30 April 2013
      With its wings skimming across the water, this super yacht soars above the competition.
      Its state-of-the-art design means the world's fastest yacht can clock an amazing 60 miles an hour -
      and reach 50mph in just ten seconds.
      The Hydroptere, which uses marine and aeronautic technology, relies on giant wings to almost fly
      across the water.
      Pictured in these gorgeous photos taken off of the French coast the yacht, which weighs 7.5 tons, it's
      easy to see why the powerful boat has broken so many world records.
      The super yacht is an experimental sailing hydrofoil designed by French yachtsman Alain Thibault
      and in full flight only 2.5 square metres of the boat are in contact with the water.
      This means that it can shoot from 20 to 45 knots (23mph to 51.5 mph) in just 10 seconds.
      Named after the Greek words for water and wing (hydros and ptere) the yacht uses the same
      principles as an aircraft to give it flight.
      To take off, Hydroptere has 'marine wings', the foils, which are placed under each of the floats of the
      trimaran.
      Once the boat reaches 10 knots, these immersed 'wings' deploy at 45 degrees in the water and
      generate an upward thrust which raises the boat like the wing of a plane.
      Then the hull and the floats of Hydroptere fly five metres above the sea surface and as in the air, the
      higher the speed, the greater the lift.
      When fully extended, its carbon fibre sails and mast reach 28m high - the same height as the Christ
      the Redeemer statue (minus the feet) in Rio de Janeiro, Brazil.
      Over years of trial and error the designers came up with a unique shape to optimise the sail
      efficiency and minimise air friction.
      The boat is made strong by the use of carbon fibre impregnanted with epoxy and titanium parts.
      It's overall length is 74.7ft - three times longer than the average one bedroom British flat.
      It's sail area in flight measures 560 m² - much bigger than new UK one bedroom flats, which
      measure on average 76m.
      They also installed a hundred sensors which measure the pressures, the twisting or the speed which
      is analysed in a flight simulator to make minute adjustments.
      Carlos
      • #78
        Preguntate porque siempre tiene el aparente de proa y a pesar de eso, va vas rapido con reales por la aleta, si el aparente lo frenase, iria mas rapido de traves o de popa cerrada.
        • #79
          The apparent wind increases in these examples as the board points closer to the wind. Also the apparent wind angle gets smaller as the apparent wind increases. It is interesting how headed upwind in fig 5c the apparent wind is over 27 knots so it feels like you are going very fast, even though your board speed is only 17 knots. Conversely on a broad reach in fig 5a, the apparent wind is 20 kts, less than the apparent wind on a beam reach in fig 5b, but the board speed is higher. So even though the apparent wind that drives the sailboard is lower the board speed can be higher. This is why when you bear off on a reach to broad reach it can feel like you are slowing down because the apparent wind slows down but when you check your GPS your board speed is actually faster.
          Editado por última vez por Kane; 07/08/2013, 23:50:26.
          Carlos
          • #80
            He dicho en popa cerrada o traves!!, no ceñida.
            1. Hay menos aparente en popa cerrada que a 1 largo, no?
            2. Si el aparente frenase iriamos mas rapido en popa cerrada segun tu discutible teoría.
            • #81
              TWS 15 Vb 15 Tack Angle 180 Va 0,0 AWA NaN Vb máx 15 a T. A. 180
              TWS 15 Vb 30 Tack Angle 180 Va 15,0 AWA 0,0 Aparente por proa 0º tabla se frena a Vb 15
              TWS 15 Vb 10 Tack Angle 180 Va 5,0 AWA 180 Aparente por popa, puede acelerar hasta máx Vb 15
              TWS 15 Vb 15 Tack Angle 160 Va 5,2 AWA 80 Empieza a frenar
              TWS 15 Vb 20 Tack Angle 160 Va 7,8 AWA 41 Frena
              TWS 15 Vb 30 Tack Angle 160 Va 16,7 AWA 17,9 Frena más. La tabla NO puede llegar a Vb 30
              TWS 15 Vb 40 Tack Angle 160 Va 26,4 AWA 11,2 Frenada a tope. Imposible.
              Carlos
              • #82
                Los gráficos que he adjuntado son por la aleta, por el través y de ceñida. 120º, 90º, 60º
                De popa cerrada (defíneme popa cerrada. Para mí son 180º De todas formas te he puesto ejemplos numéricos para 180º y 160º) Vb no puede exceder Vt.
                Editado por última vez por Kane; 08/08/2013, 00:37:36.
                Carlos
                • #83
                  Lo dicho: diálogo de besugos. Para tí la perra gorda. El aparente no frena ni aunque sean 50 nudos a 0º Edito: en una motora
                  Editado por última vez por Kane; 08/08/2013, 10:32:20.
                  Carlos
                  • #84
                    Pues vale, tienes razón, mi Gps, y los Gps y correderas de todos los Minis, Imocas, hydroptere, banque populaire V, y los AC45 y AC 72 mienten.
                    • #85
                      Re: Respuesta: Re: Viento real sin corredera con GMI10 o i70?
                      No, no vale para ir más rápido. De hecho, ese aparente le frena. Si no existiera ese aparente, iría a muuuucha más velocidad.
                      Edito: Con la suficiente reducción de las resistencias al avance, del casco por el agua, de la obra muerta por el aire, de las velas por su resistencia al arrastre (drag), como en las alas de avión, de la jarcia y otras que no indico, usando velas como hojas de afeitar ligerísimamente curvadas (como las alas de un caza supersónico), sin orza (no quiero enrollarme en este momento por qué cosa se podría sustituir, pero no es imposible), con unos hidrofoils como cuchillas de canto, etc, etc, el primer límite sería la barrera del sonido (como en los cazas). Y luego... Mach 2, 3, 4....
                      Qué, ¿cómo te sientes?
                      Saludos Kane, como bien decías en otro mensaje, el viento aparente es la suma vectorial de la velocidad del real y la opuesta a la del barco.
                      En popa cerrada esos vectores son paralelos de sentidos opuestos y el límite está en cuando se anulan.
                      Pero si el viento entra por la aleta, la suma puede ser mayor que el real, con lo cual las velas empujan más, lo que hace ir más rapido y llevan el aparente más a proa, con lo que vuelven a empujar más en un circulo virtuoso hasta llegar a la máxima ceñida del aparente.
                      Por esto, los multicascos hacen bordos en la empopada.
                      Realmente, el aparente no lo frena por que lo que hace es llevar el real a proa.
                      taedet me quinque aut decem
                      Oh it's a disgrace to see the
                      You got your horse race
                      You got your dog race
                      You got the human race
                      • #86
                        Originalmente publicado por hibrido Ver Mensaje
                        Muy bueno... Me rindo. Me ha gustado lo de círculo virtuoso.
                        Carlos
                        • #87
                          No creía que fuera tan divertido
                          • #88
                            Pues despues de releerme bien el post me atreveria a afirmar que KANE y Jiauka estan deacuerdo en el fondo, solo discrepan en la forma de exponerlo.
                            Por si acaso me lo guardo en el cajon de la sabiduria, espero se aclare mas adelante
                            • #89
                              No escarmiento... Voy a hacer otro intento. Aún no he perdido (totalmente) la confianza en mis dotes pedagógicas.
                              El viento aparente tiene dos efectos. Uno perverso -ofrece resistencia al avance, frena- "gracias" a su componente de proa (0º). Otro, beneficioso y buscado: es, a la vez, motor del velero gracias (esta vez sin comillas) a su componente de través. Supongo que todo el mundo admitirá esta descomposición vectorial del vector "viento aparente", Va.
                              Esos dos efectos son antagonistas. Uno, motor, "empuja" al velero y lo hace avanzar. Otro, tiende a pararlo, lo frena. Como siempre, llegaremos a un equilibrio tipificado por la velocidad del barco, Vb, que dependerá de su rumbo y por tanto, de las características del vector Va.
                              Lo que ocurre es que el efecto motor disminuye al aproarse e incrementar su módulo el vector Va cuando orzamos (viramos hacia el viento), al hacerse más pequeña su componente de través, mientras que el efecto perjudicial aumenta al incrementarse su componente de proa. El freno. Así, el equilibrio se conseguirá a una velocidad Vb más baja que haga que disminuya la componente de proa de Va y aumente la componente motora de través, gracias a la apertura del vector Va, que ahora forma un ángulo (AWA) mayor con crujía, ha disminuído su componente y efecto frenante y ha aumentado su efecto motor compensando las variaciones inversas al experimentar el movimiento contrario anterior (aproarse).
                              Entonces, la situación es:
                              - Velero más aproado.
                              - Velocidad Vb menor. La de nuevo equilibrio.
                              - Viento Va menor (ha bajado).
                              - AWA mayor (ha subido).
                              Esto ¿nos permite decir que el incremento de viento aparente al orzar ha disminuído la velocidad del barco, equivalente a decir "lo ha frenado"? Yo diría que sí.
                              Por supuesto, todo esto en rumbos NO portantes. Esos (los portantes) ya están suficientemente machacados. O si no, los machacamos otro día.
                              Buena proa
                              Carlos
