LSV - BARCO KAU-BÉ.
MMSI: 261000743
VER Mi canal en YOUTUBE
VER TODOS MIS DISEÑOS 3D
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
Re: Reunir ficheros impresión 3d barco
Casquillo interno Internal bushing for Facnor SD 70 furler
DISEÑO DEL COFRADE Bertie
Internal bushing for SD70 furler. These parts are located inside the tube and act as spacers between the stay and the tube itself.It must be mirrored before printing so you have two symmetrical halves that can be placed around the stay. Usually several sets will be needed.
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
Anillo de la driza y el obenque Halyard Shroud ring cleat
This a ring to attach to 10mm shrouds. In addition to the two parts you'll need to buy 4mm knurled inserts. These are inserted by heating on the end of a soldering iron and sinking the brass bit into the plastic
LSV - BARCO KAU-BÉ.
MMSI: 261000743
TOPE PUERTA Beneteau 31/34/37 Head Door Holder
After being frustrated that there's no way to keep the head door open without swinging, and trying various weighted cushioned doorstops, I decided to make this. The holder keeps the head door in place at anchor or under sail, and can be slid forward along the chart table fiddle when you want to close the door.The angle matches the door / chart table angle on the 2 cabin model 37. The 31 and 34 should be similar - check if the door makes a ~22 degree angle with the chart table edge to confirm.Update: In sporty conditions the door can still push the holder forward. In those conditions put the holder on the fiddle above the microwave cabinet. That fiddle is the same size and the bend in it prevents it from getting pushed out of the way.
LSV - BARCO KAU-BÉ.
MMSI: 261000743
Igualmente puede ir bien para alguien.
¿Puede ser esta bisagra?:
Jabsco or Bemis boat toilet seat hinges
The toilet seat hinges in my boat broke and even though they aren't that expensive the design is such that they don't last for long. made a beefed up design that should last longer.And it is always nice to print things that is actually used and not sitting on a shelf :)My toilet seat is made by Bemis but it is identical to Jabsco which is more widely used.
Editado por última vez por LSV; 05/05/2026, 23:41:53.LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
