LSV - BARCO KAU-BÉ.
MMSI: 261000743
VER Mi canal en YOUTUBE
VER TODOS MIS DISEÑOS 3D
Re: Reunir ficheros impresión 3d barco
CARRO VARADA Kayak, Cart
Kayak, Cart, Printable3 Sizes for structure depending on your printer small size will fit on a 150mm x150mm bed. Med and large will fit on respective beds 10" and 14". Wider is more stable. Boat Supports have cut outs for up to a 1-1/2" strap for stability, And the Ends will fit most pool noodles when cut for extra padding. Was given an idea for no slip padding cut up a yoga mat or mouse pad glue or zip tie to mounts.Check Print for needed Hardware. Get 10" pneumatic wheels from Harbor Freight for $6 a piece. https://www.harborfreight.com/10-inch-pneumatic-tire-30900.html?cid=paid_google|*PLA+-+Top+SKUs+-+All+%28Branded%29|Shop+Press|30900&utm_source=google&utm_medium=cpc&utm_campaign=*PLA+-+Top+SKUs+-+All+%28Branded%29&utm_content=Shop+Press&gclid=CjwKCAjwtJ2FBhAuEiwAIKu19sAWuZ5IrMNvV3LtFeuKwvtpLerHnKB7HFIXPWbf5Ak2gfKfGt8QERoC3DwQAvD_BwEIf you would like a different axel size PM me it's an easy change. Can also do special intermediate if you have a size you'd like that specific.Cart support v.2 added due to interference with axle (thx "cwiltgen86" for finding that
LSV - BARCO KAU-BÉ.
MMSI: 261000743
Editado por última vez por LSV; 26/05/2023, 11:00:15.LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
ANCLAJES BACA COCHE Rack Mount, Pelican Kayak, 100x series
Rack Mount, Pelican Kayak, 100x seriesThis fits the Pelican 100x series & a std, 1-1/4 x 7/8" Load bar, Designed to be low profile, vertical mount. I haven't had any wind noise on mine yet, but someone will probably prove me wrong. I'd suggest using a rag in-between cradle and boat just so it doesn't scratch it up, Things rubbing in the wind can do all sorts of things to a boat. Print out of a stronger material ABS, PC, Nylon, ect....Make sure your boat is secured properly in case of failure, these are only designed to hold boat upright. Tie off to bumpers for safety, as well as lashing to roof rack. I've seen roof racks fail, it's not pretty.Be safe, you assume all responsibility if you print them.
LSV - BARCO KAU-BÉ.
MMSI: 261000743
MAQUETA Sailing Lugger "Storm Petrel" - 1:87 scale
LSV - BARCO KAU-BÉ.
MMSI: 261000743
SOPORTE BOTELLAS BUCEO Smaco 0.5L Dive tank Dual holder
I needed a holder to carry both dive/snorkel bottles together and store easily in the back of the car or on the boat. should fit most 0.5L mini dive bottles. The handle has slots to thread through allowing it to be strapped to larger bottle for home storage and easier fillingHaven't tested extensively yet - increase infill if worried about strength https://www.printables.com/social/305484-cluu/prints
LSV - BARCO KAU-BÉ.
MMSI: 261000743
computer stand
LSV - BARCO KAU-BÉ.
MMSI: 261000743
TAPA Raymarine Cranchi Cover
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
MÁSCARA BUCEO adaptor for air compressor Face mask snuba/hookah
A little background: "Hookah diving", sometimes called "snuba", is when you use an air hose instead of a tank and stay close to the surface. A lot of DIY rigs have become popular for cleaning boat bottoms or reef diving using typical oil-free air compressors. It's also sometimes called "kayak diving" if you use a scuba tank like an air compressor and leave it on the kayak. The regulators (2nd stage, i.e the mouthpieces) use much lower pressures than SCUBA and are inexpensive. This idea takes it a step further and interfaces a cheap full-face mask to take the place of a regulator! The masks have several check valves so they are basically cheap regulators already. It works great and its super fun, but with that much air attached you will need some dive weights to get below the surface.The mask I used was the cheapest one on Amazon at $16: https://www.amazon.com/gp/product/B0859S6C9G/ The snorkel has a twist lock that I duplicated. It might work with some other generic brands. A standard 1/4" NPT air compressor quick-release attachment is then threaded into the hole in the cap. Heat the inside of the hole with a lighter for a few seconds and use pliers to twist it in. Here's a link to a 1/4" attachment: https://www.amazon.com/WYNNsky-Coupler-Fittings-Industrial-Storage/dp/B06W51VW9B I use a Dewalt D55146 compressor but only because I already had it. You can get away with much less but what I've read on diving websites is don't go below 3 SCFM airflow since you need at least 30 psi in a pool or shallow waters and double that if you go near 30'. If you are going below 30' then you shouldn't be doing this with cheapo DIY equipment. You're going to want an in-line filter. There are also purpose-built compressors but they can be pricey: https://www.amazon.com/s?k=hookah+air+compressor .. the one that keeps coming up in suggestions is the Puma Industries PD1006: https://www.amazon.com/Puma-Industries-PD1006-Compressor-Professional/dp/B00VNIB7CI
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
MOLDE SEÑUELO BLANDO ModCity Soft Plastics mold (THEJORDANSCOMPANY.COM)
LSV - BARCO KAU-BÉ.
MMSI: 261000743
CAJA PARA MOSCAS Fly Case
LSV - BARCO KAU-BÉ.
MMSI: 261000743
