    MOLDE SEÑUELO BLANDO CALAMAR Squid Fishing Lure
    I came up with an idea for a squid lure. I wanted something around 3 inches long to throw on a jig and use for inshore saltwater. Flounder, stripers, redfish, Bonita, basically everything eats squid. So I hoped onto fusion 360 and made it myself. This is a mold I made and printed out on my any cubic photon mono x using syriatech sculpt resin. This can also be printed out on an fdm printer too. Oh and did I Mention its FREE! If you have any questions or suggestions on what I should make next leave a comment down below. You can watch the video here too see this mold in action: https://youtu.be/Twqsk-Hka9o WARNING!!: Molten plastisol is very hot and can cause burns. Don’t Touch it Breath it in drink it or do any other stupid idea you may have. Please be careful and follow proper safety procedures. I am not responsible if you hurt yourself.
    LSV - BARCO KAU-BÉ.
    MMSI: 261000743
    VER Mi canal en YOUTUBE
    VER TODOS MIS DISEÑOS 3D
      (MIO) BOTON "cable hombre al agua" YAMAHA 6CV BUTTON PULLER SAFE YAMAHA 6CV
      Editado por última vez por LSV; 31/05/2023, 10:45:37.
      LSV - BARCO KAU-BÉ.
      MMSI: 261000743
        SEÑUELOS PICO CUADRADO Squarebill Crankbait
        This is a squarebill crankbait fishing lure I made. It swims good and is Ready to fish This is printed out of petg on my ender 3 pro. It would be kind of hard to explain how to put this together in text so please watch my assembly guide if you are interested in making this: https://youtu.be/MCzBgQAHFnc Feel Free to check out my other lures. Enjoy and go catch some fish! Tool/Parts List PETG Filament The lure body: https://www.thingiverse.com/thing:5553393/edit Figure 8 Hook hangers size 4: https://lurecomponents.worthco.com/products/wire-forms/figure-8-hook-hangers Quarter Inch Stainless Ball Bearings Stick on eyes 6mm (optional) Your Choice of adhesive Your Choice of paint and clearcoat Hooks( I used size 6) Split rings (I used size 2) Split ring pillars (Highly Recommended)
        LSV - BARCO KAU-BÉ.
        MMSI: 261000743
          Baofeng UV-B5 / UV-B6 battery latch replacement
          Has your Baofeng UV-B5 (or UV-B6) been dropped and now the battery won't lock into place? Are the tiny metal pins holding it in position broken off? Worry not, here's a drop-in replacement part that will do the job and make sure your radio retains it battery, at least for some time.Warning: print multiple of these and familiarize yourself with taking the radio apart and swapping them, because a part this tiny won't be very robust when printed in any common material. Ideally you want a metal spare here, but they are kinda hard to find, so this will do instead.To replace the broken part, take the radio apart as follows:Unscrew the antennaRemove the batteryPull off the channel and volume knobs (just pull up, they are not fixed in place with anything)Use a flat-head screwdriver or another small tool to unscrew the securing nuts on both knobsRemove the two screws below the batteryLift and pull out the metal body inside the case. It remains connected to the second PCB and the speaker inside the case, leave those connections as they are and just rotate the lifted part out of the way to get to the broken latch.Now use a flat-head screwdriver or a fingernail to pull on the middle part of the plastic wall separating the latch from the inside of the radio, towards the inside. This should allow to lift the broken latch out, leaving both springs in place.Take the printed spare, thoroughly remove any support material and insert it in place of the broken latch. Make sure it moves freely up and down, file off some material thickness if necessary. Also ensure the latch ends can freely insert into the recesses in the bottom of the battery, again, file off some material if they have resistance - there needs to be complete freedom of movement there, otherwise the battery will be hard to install and remove, and the printed part will break quickly.After ensuring the replacement part fits and moves properly, re-assemble the radio in reverse order of disassembly. Install the battery as usual.
          LSV - BARCO KAU-BÉ.
          MMSI: 261000743
            TAPON VACIADO Replacement Drain Plug for sailboats
            Replacement parts if you have a sailboat with a 30mm hole but no plug anymore :-)You need a seal with an inner diameter of 20 or 21mm. 2mm thick.(or you print one if you can)The plug needs to be printed with support. Cheers
            LSV - BARCO KAU-BÉ.
            MMSI: 261000743
              buenos dias
              una pregunta tecnica sobre un material
              aguantaria en nuestros barcos con el sol,lluvia ,etc... el siguiente material
              NYLON PA12/MJF
              gracias de antemano
                El NYLON es un material fuerte, resistente a los golpes y la presión y se ha usado prioritariamente para hacer engranajes, por lo que podemos deducir que es mecanicamente muy resistente.
                Así que , en principio, no tiene que dar problemas en un barco.
                No obstante, de momento no encuentro indicaciones sobre su resistencia a los ultravioletas del sol (UV).
                El NYLON PA12/MJF se ha formulado especialmente para impresoras de gran volumen multijet profesionales, osea de varios extrusores.
                Por todo eso será un material caro y solo accesible en grandes cantidades para empresas, por lo que veo en este momento.
                (Salvo que ya dispongas de una impresora profesional yo no me metería en ello).
                De momento no encuentro la temperatura de fusión entre las características y es lo más importante para saber si podemos imprimirlo con la impresora que tengamos.
                Sigo muscando datos.
                Por ejemplo: https://www.weerg.com/es/impresion-3...les/nylon/pa12
                LSV - BARCO KAU-BÉ.
                MMSI: 261000743
                  La temperatura para imprimir es de 255-270°C.
                  La mayor parte de las impresoras caseras no pueden usarlo.
                  En la web dicen que sufre bastante "warping" , deformaciónes de la pieza por cambios de temperatura, como el ABS.
                  Popr lo tanto: impresoras con cama caliente: 90º-100º
                  Y con caja de protección exterior para mantener la temperatura.
                  No es bueno para piezas grandes o muy sólidas.
                  LSV - BARCO KAU-BÉ.
                  MMSI: 261000743
                    Si tienes acceso a ese filamento podrías probar con una configuración ajustada similar al ABS, pero puedes quemar la impresora si no es la configuración adecuada.
                    (Puedes encontrar NYLONPA12 no MJF para impresoras no multijet).
                    Si quieres algo parecido pero aceptable para una máquina "normal" usa nailon "normal": temperatura 255º, cama: 90º y bobinas habituales de 750 gr.
                    Pero siempre para piezas pequeñas. Calculo que a menores de 15cm y que no pasen de un 60-70% de densidad.
                    Tengo una muestra de NYLON NYLSTRONG, para probar pero aún no he podido hacerlo, así que todos los datos son las webs de los fabricantes.
                    Editado por última vez por LSV; 02/06/2023, 12:00:27.
                    LSV - BARCO KAU-BÉ.
                    MMSI: 261000743
                      También se encuentra como NYLON 180.
                      El NYLON 180 = 60€ = 750 gr
                      El NYLSTRONG = 40€ = 750 gr (solo en blanco)
                      Solo por comparar el precio, no el resultado:
                      el PLA reciclado = 12€ = 750 gr.
                      LSV - BARCO KAU-BÉ.
                      MMSI: 261000743
                        GIRATORIO PARA PESCA 4 Blades Buzzbait blade
                        4 Blades version of Buzzbait blade. I'd recommend scale the model around 130-150% to get the proper thickness and etc. Modeled in Blender myself PETG is recommended, I've added the photo for my version of DIY Buzzbait with this blade. Enjoy ! ;)
                        LSV - BARCO KAU-BÉ.
                        MMSI: 261000743
                          6,35 cm = 2,5" TAPA POSAVASOS Cup Holder Cover
                          On my boat, there are 2 covers, one over the open bow, and another over the rear cabin. There are 2 cup holders in front of the windows not covered by either, so they're always getting clogged with leaves and filling with water. This loosely fits in the cup holders and sits flush with the boat because of the concave lip. Works for 2.5" cup holders. Remove before towing the boat anywhere or they may fly out.
                          LSV - BARCO KAU-BÉ.
                          MMSI: 261000743
                            AGUJA GAZAS FALCACEADO SPLICING
                            This marlinspike is a tool for splicing heavy three strand rope. I needed a large one for my anchor rode (rope). I would print with supports and 100% infill. I printed the one shown at 115% size and am in the process of sanding and varnishing.
                            LSV - BARCO KAU-BÉ.
                            MMSI: 261000743
                              Bimini Top Fastener side
                              LSV - BARCO KAU-BÉ.
                              MMSI: 261000743
                                COLGADOR CORNAMUSA Hook boat cleat stile
                                A small hook to hang towels and other light things. The base is quite sturdy but the arms are not meant for heavy loads. | Descargar modelos STL imprimibles en 3D gratuitos
                                LSV - BARCO KAU-BÉ.
                                MMSI: 261000743
