Editado por última vez por LSV; 14/05/2023, 11:10:08.LSV - BARCO KAU-BÉ.
MMSI: 261000743
VER Mi canal en YOUTUBE
VER TODOS MIS DISEÑOS 3D
Re: Reunir ficheros impresión 3d barco
BASE Compass Bracket Mount Pad
Since the original part accidentally broke on our boat, I gave it a try and designed a replacement compass mounting pad in Autodesk Fusion 360. The mounting plate is for a Plastimo Offshore 105 compass, the original bracket replacement is Plastimo's partnumber 17268.http://ecat.plastimo.com/EN2015/common/data/0323.pdf I successfully printed one instance of it on an Ultimaker 2 in the Paja maker space in Espoo city's library in Iso Omena. This copy is installed and working fine. Plastimo is a registered trademark of Navimo Group
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LUZ COMPÁS Compass Night Light
Found this cool Plastimo 105 OffShore compass at a yard sale for $20 and brought it home to see what I could do with it. Created this base and printed it in clear PLA, then scratched the paint off the round nubs, lined it with a cheap 5v LED strip and superglued a little section of that strip (3 LED's worth) into the hood/cover. Hopefully this inspires you make an ordinary object extraordinary with your creativity.Materials:spare USB cord laying aroundLED strip https://www.amazon.com/gp/product/B08LR6PQK8/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
LSV - BARCO KAU-BÉ.
MMSI: 261000743
VOLANTE ARRANQUE Yamaha Hidea Parsun pull starter part
Fits good, makes the motor turn. Time will tell for how long it will hold. ABS should be the best filament or nylon if you want it really good.The thingthingy has no name that I know of. Ordered a new one so I have not used this for a longer time, I was about to use it until the new parts came.It came quickly.
LSV - BARCO KAU-BÉ.
MMSI: 261000743
BASE MESA BaoFeng UV-5R Desk Stand
This stand is designed for the BaoFeng UV-5R and the BF-F8HP. There is both a regular battery model and an extended battery (2100mAh) model. I have also designed the stand to accept the belt clip of both radios, as the BF-F8HP belt clip is slightly larger in every dimension in comparison to the UV-5R.The dimensions of the pockets are:Regular battery model: 30mm deep x 50mm wide x 30mm tallExtended battery model: 35mm deep x 50mm wide x 30mm tallThis stand will not work with the BL-5L 3,800mAh battery or large antennas like the ABBREE, as the stand is at an angle. The higher center of gravity from these modifications will cause the radio and stand to tip over backwards. However, this could be counteracted by adhering the stand to a flat surface with 3M Command Strips or other adherence methods.
LSV - BARCO KAU-BÉ.
MMSI: 261000743
Base cargador conversion Baofeng uv-5r DC charger portable / dash mount
https://cults3d.com/en/3d-model/various/baofeng-uv-5r-dc-charger-base-conversion-portable-dash-mountLet me start with this - you choose to make, create, change, any device at your own risk of damage or injury. You mess it up, it is your fault, I didn't sell or tell you to do anything. I'm just showing something I did, right or wrong. I converted a Baofeng AC charger to a dash mounted / portable DC charger for a Baofeng uv-5r using this case and the internal parts of the base charger that came with my radio. In order to hang the charger on the dash / wall or whatever, I made it so it will work with the Universal Ham / CB handheld radio / mic mount kit I created: https://www.thingiverse.com/thing:4772448 I also used a BTECH USB Smart Charger (9-10.8V) Transformer Cable for power. https://baofengtech.com/product/10-usb-smart-charger/ There are 2 versions of the case back, 1 is blank, and the other has the clip to use the dash mount. I provided an exploded diagram showing what I did - basically.
LSV - BARCO KAU-BÉ.
MMSI: 261000743
MARCO DOBLE VIDRIO PORTILLOS Portlight 2 glass system (Boat window)
Tyerd of singel glass windows foging and dripping in your boat? Print a nice 2 glass frame!Small guide holes for steel wire to be glued in, the holes go all the way if you need to cut a part to custom length. M4 bolts.This is v2.0 many improvemnts made efter i printed the fist prototype. Want diffrent size or radius? Type a comment.... Every part prints with no supportNew: Wallframe for thicker walls on demand.
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
Agradezco la información, pero es necesario poner todos y cada uno de los diseños en thinkverse náuticos aquí?
Entiendo que sería bueno si se han impreso y probado, pero deduzco que no los has impreso todos.
No es obligatorio verlosOriginalmente publicado por jiauka Ver MensajeAgradezco la información, pero es necesario poner todos y cada uno de los diseños en thinkverse náuticos aquí?
A mi me parece muy interesante todo lo que se puede hacer con estas impresoras y además se sacan ideas muy interesantes
El título es muy claro , nada engañoso. El que entra sabe lo que se va a encontrar.
Gracias a las personas que aportan.
Gracias por los comentarios.
La idea que me llevó a crear este hilo era mostrar a la gente la cantidad y variedad de cosas que se pueden hacer con la impresora, para todo, pero especialmente para nuestro tema, para la náutica.
Evidentemente yo ni he hecho ni tengo todos los barcos para los que existen piezas para haberlos probado.
Pero todas ellas dan idea de que si en un barco se puede solventar un problema determinado en otro barco se debería poder hacer también.
Si ves un plato de arranque de un fueraborda muy específico puede que no te valga para el tuyo pero te da idea de que el tuyo seguramente también se puede hacer.
En todo caso yo he diseñado y montado en mi barco o para otros compañeros unas 40 piezas diferentes.
Y lo que procuro es mirar, no solo en Thingiverse, sino en una veintena de webs diferentes, lo que pueda interesar a nuestro tema, ya que hay mucha cosa pero muy dispersa por la red y hay que dedicar unas cuantas horas cada semana a revisar miles de piezas, muchas ya vistas y revistas y a extractar las nuevas que puedan ser intereresantes para alguien, aunque a mí ni me interesen ni pueda usarlas en mi barco.
Y si veo algo que no es de náutica pero podría ser oportuno para dar nuevas ideas, como un llavero con tema naval, o un escurreplatos, o un soporte plegable para la bolsa de la basura, etc. también empezaré a ponerlos en algún momento.
Creo que gastar un poco de tiempo y unos céntimos en probar si nos vale una pieza que sale en la tienda a 70€ bien vale la pena hacer la prueba y si no sale bien podemos adaptarla a nuestras necesidades específicas.
Y mientra nos vamos divirtiendo y ahorrando para cervezas (o lo que sea).
Editado por última vez por LSV; 18/05/2023, 21:06:53.LSV - BARCO KAU-BÉ.
MMSI: 261000743
Por si alguien tiene curiosidad. Aquí están algunas de las piezas, de diferentes temas, que yo he diseñado.
https://www.thingiverse.com/salida999/designs
LSV - BARCO KAU-BÉ.
MMSI: 261000743
