    Botes HERMÉTICOS tapones reciclados JARS TAP
    https://www.thingiverse.com/thing:5941165
    LSV - BARCO KAU-BÉ.
    MMSI: 261000743
    VER Mi canal en YOUTUBE
    VER TODOS MIS DISEÑOS 3D
      LAMPARA Solar FARO Lighthouse
      https://www.thingiverse.com/thing:2875991
      LSV - BARCO KAU-BÉ.
      MMSI: 261000743
        Y VAN 300 OBJETOS + LOS COLGADOS POR VOSOTROS
        Y PARA MI SORPRESA + 26.000 VISITAS EN 3,5 MESES.
        LSV - BARCO KAU-BÉ.
        MMSI: 261000743
          CAÑERO PORTACAÑAS Fishing rod holder
          https://www.thingiverse.com/thing:5942863
          LSV - BARCO KAU-BÉ.
          MMSI: 261000743
            BOMBA MANUAL CALA Manual bilge pump
            https://www.printables.com/es/model/...ual-bilge-pump
            LSV - BARCO KAU-BÉ.
            MMSI: 261000743
              No estoy seguro de si ha salido antes... pero creo que vale la pena para realizar el mantenimiento de nuestros barcos.
              Una llave para filtro.
              https://www.thingiverse.com/thing:1417160
                Originalmente publicado por kelevra Ver Mensaje
                ME ESTABA HACIENDO FALTA
                LSV - BARCO KAU-BÉ.
                MMSI: 261000743
                  Europe dinghy RC sailboat
                  https://www.thingiverse.com/thing:5204310
                  LSV - BARCO KAU-BÉ.
                  MMSI: 261000743
                    SOPORTE BEBIDAS EQUILIBRADO Gimballed Print-In-Place Drink Holder
                    LSV - BARCO KAU-BÉ.
                    MMSI: 261000743
                      REPARAR PUNTA BICHERO Hook Threaded End Repair
                      I bought a boat hook from amazon. It goes by different manuf. names (Rainier Supply, Better Boat, Rage Powersports) and has a 3/4" threaded end for attaching brushes. On my first day of use, the threaded end broke off! So I made this! It slides over the end of the hook and a stainless steel (SS) screw reinforces it and holds it in place. I have not abused this yet in real life, but will report back when I do. Print with 100% infill and supports. I used a 12mm brim. The screw is 4mm dia x 50mm long (#8 X 2"). I used a non SS screw but put hot glue over the end to weatherize it. I you're on a lake, the SS is not as important.
                      LSV - BARCO KAU-BÉ.
                      MMSI: 261000743
                        LLAVERO CHALECO SALVAVIDAS Life Jacket Keychain
                        LSV - BARCO KAU-BÉ.
                        MMSI: 261000743
                          OJETE VELA O LONA Snap ring for canvas-sails
                          On the ship we often made simple covers from tarpaulin to protect equipment from cargo dust during loading/discharging or against weather condititons. The easiest way is to make few holes in canvas, put a rope through and tight. It looks... well- imagine, and sometimes fabric tears.So I invented simple ring to snap in a hole.If not fit, put a little glue between stringers.As far as I know something similar is used to reinforce sails corners.
                          LSV - BARCO KAU-BÉ.
                          MMSI: 261000743
                            SOPORTE COMPÁS Mast Slug Drilling block (Fits Tack Tick compass mount.)
                            Instruments are typically held to sailboat masts using slugs in the sail track. The slug gives the equipment something to screw to that can be adjusted up and down. A slug is usually a piece of round aluminum bar-stock with threaded holes drilled crosswise in it. How does one align a drill bit to drill these holes? Using a Mast Slug Drilling block. This one will align 3 holes in a 3/8" x 2+" piece of aluminum bar-stock. Perfect for mounting a tack tick compass mount. Assuming you've lost the slug that came with it and want to make a new one right now.
                            LSV - BARCO KAU-BÉ.
                            MMSI: 261000743
                              POLEA TIPO harken fly block
                              Do you love sailing, fancy those nice fly blocks but think they're rather expensive...It takes a 12x18x4 bearing, preferably use stainless. The block is suited for 4mm rope.I suggest you read the manual of the real deal before use!
                              LSV - BARCO KAU-BÉ.
                              MMSI: 261000743
                                CAJA REGLA TRANSPORTADOR Portland Plotter Case
                                I love my Portland Plotter, but it's inconveniently larger than all the rest of my sailing navigation equipment. This is a case I use to give it some protection in while its sat in my regular sailbag rather than being safely tucked away with charts, dividers and the like.I printed in PETG and the end result has held up pretty well. However, don't expect miracles - if the wrong heavy thing hits the case in the wrong place its still going to break. The latch on the lid is quite firm, but keeping the lid closed in an important part of stopping the lid breaking off!The case in the photos has my name on it, but the STL files don't have any name. If you'd like you can very easily edit the constants at the top of the OpenSCAD file to add your own name, or tweak any of the dimensions.
                                LSV - BARCO KAU-BÉ.
                                MMSI: 261000743
