    CLIP CINTURÓN Replacement Belt Baofeng BF-T1
    Baofeng BF-T1 Replacement ClipThis is a very quick and easy to print replacement belt clip for the Baofeng BF-T1 miniature Ham Radio. Not sure if other baofengs use the same hole pattern (3mm holes 28mm apart), but if they do this should be compatible with those as well. Note that the part that the screws go into are a good bit thicker than the normal clip to simplify printing, so the screws are only threaded about 1mm into the radio. As far as I can tell this doesn't actually cause any issues, but if you aren't so lucky send me a message and I'll modify the design for you.UPDATE 10/19/2019V2 has now been uploaded. It features countersunk screw holes, allowing the clip to sit farther from the radio, reducing strain on the clip from bending outward to fit on a belt. The edge of the holes have been chamfered at about 60 degrees to the vertical to allow printing without supports. the clip itself is slightly thinner, but does include a fillet to increase the strength of the joint.
    LSV - BARCO KAU-BÉ.
    MMSI: 261000743
    VER Mi canal en YOUTUBE
    VER TODOS MIS DISEÑOS 3D
      BOTÓN SOPORTE Baofeng Speaker Mic Holder
      LSV - BARCO KAU-BÉ.
      MMSI: 261000743
        ALIMENTACIÓN SIN BATERÍA Baofeng UV-5R battery eliminator
        Empty BL-5 battery shell that allows running wires down to a JST XH port in back. | Descargar modelos STL imprimibles en 3D gratuitos
        LSV - BARCO KAU-BÉ.
        MMSI: 261000743
          BOTÓN PULSADOR Replacement PTT button for Baofeng UV9Rplus
          I dropped my radio and lost the PTT button. Since it was lost I did not have the original button for reference when designing this. It seems to work just fine though. It might even fit a little tighter than the original so less chance of losing it. I like the bright orange look over the original black!
          LSV - BARCO KAU-BÉ.
          MMSI: 261000743
            TOLDILLA Bimini cover bracket
            This is a bracket to hold a Bimini cover on a 1994 Four Winns Fling. The originals are hard to find and expensive so I made my own. You may want to file the inside to make sure it releases easily, my first one broke when disassembling the cover.
            LSV - BARCO KAU-BÉ.
            MMSI: 261000743
              SOPORTE MAMPARO Baofeng UV-9R Plus mount
              LSV - BARCO KAU-BÉ.
              MMSI: 261000743
                BaoFeng UV-5R Desktop Stand!
                Just purchased a BaoFeng FP-F8HP which is a great radio (see more here: http://radiotech.diy3dtech.com/baofeng-bf-f8hp ) along with a Nagoya NA-771 15.6-Inch Whip (see more here: http://radiotech.diy3dtech.com/Nagoya-NA-771-whip ) which makes fop a great combination, however the radio is now top heavy when sitting on the desk. So to Fusin 360 we went and designed a new desk stand for it and couldn't be happier with it so figured we would share it! Also if your interested Amateur Radio, also visit our Amateur Radio site ( http://RadioTech.DIY3DTech.com ) for more great information and projects! If your interested in seeing about this design, please check out this video: https://youtu.be/LUi9qnTG9TIMajor Favor: if you make one of these please post the Make and share it with the community :-) .Also, please follow us on Thingiverse and give this a like if this came in handy and for more information on this project, please visit us at http://www.DIY3DTech.com as well as subscribe to our YouTube Channel at http://YouTube.DIY3DTech.com along with a visit to our drone site and YouTube channel at http://video-drone.DIY3DTech.comIf you are looking for one of a kind swag shop for yourself or a Maker Geek friend, visit our swag shop at http://Swag.DIY3DTech.com for unique 3D Printing, Laser Cutting and CNC swag! Too, if you want a behind the scene look at what we are working on be sure to follow us on Instagram (https://www.instagram.com/diy3dtech/)!
                LSV - BARCO KAU-BÉ.
                MMSI: 261000743
                  SOPORTE Solar panel pole mount
                  Pole mount & electronics enclosure for a 150mm x 130mm solar panel. This accommodates a 1.2" (30mm) O.D. electrical conduit pole.
                  Editado por última vez por LSV; 05/05/2023, 19:29:06.
                  LSV - BARCO KAU-BÉ.
                  MMSI: 261000743
                    (MIO) SOPORTE BICHEROS 19mm + 25mm MOORING HOOK
                    LSV - BARCO KAU-BÉ.
                    MMSI: 261000743
                      SALVA-DEDOS ANZUELOS Fishing Pole Finger Saver
                      I love fishing. But I don't love snagging my fingers with a hook when all I'm trying to do is carry my poles to the car. So, I made this little piece that clips onto the pole and holds the hook without it being exposed to accidentally impaling my poor little fingers. I have not found a pole that it doesn't clip securely onto.Printed in PLA+Ender 3v2Nozzle 215Bed 5520% infillprint time: 27m
                      LSV - BARCO KAU-BÉ.
                      MMSI: 261000743
                        SOPORTE CAÑAS PESCA TECHO REDINGTON Path 586-4 & SAGE Foundation 590-4. Fly Fishing Pole mount rack
                        Designed for: REDINGTON, Path, line no.5, 8' 6", 4 pc., fly rods. Intended to securely fasten two assembled fly rods on the ceiling in a cap-over camper.The "reel side" is printed with TPU at 100% infill and was placed on its side for slicing. The inner diameter of the reel side hook is 0.60 inches with a 0.75 inch width and could work for a different rod. (Note: since uploading I have found my Sage Foundation 590-4 fits perfectly as well!)The "mid pole" file was also printed on its side, however, I used PLA for this component at 5%. The mid pole section final product pictured uses 0.25 x 0.75 inch foam tape with approximately 45 degree angle chamfer cuts on the outer ends.Both prints are adhered to the ceiling, semi-permanently, with 3M 1" wide double-side foam tape. 3 inches for each reel side mount (2 total), and 2 inches total for the single mid section mount. Semi-permanent usually isn't my style, but it seems plenty adequate to me. None the less, rest assured, if you're reading this now is hasn't failed me yet!
                        LSV - BARCO KAU-BÉ.
                        MMSI: 261000743
                          (MIO) PAPEL PORTARROLLOS WC TOILLETTE PAPER -MEJORADO-
                          Lo diseñé para casa pero puede valer para barco si hay sitio.
                          La idea es no tener que girarse y usar las dos manos si se tiene colocado en la pared de atrás, mi espalda no está para giros.
                          Así que con una sola mano se puede usar.
                          Por aquello de "Una mano para el barco y otra para tí".
                          LSV - BARCO KAU-BÉ.
                          MMSI: 261000743
                            Fishing Rod Holder (Storage Rack) 2 Rods
                            This design looked perfect for our fishing rods but my printer isn't big enough to print the whole thing. So I made two smaller versions that fit my printer. I didn't scale it down, just cut out the middle to make it fit my printer. You gotta print the Top and Bottom (or just print the Top twice and rotate it) to hang your fishing rods.Thanks dextergiii (https://www.thingiverse.com/thing:2798788) for the great model! I hope this version helps someone out.UPDATE 6/4: I added an updated version of the Bottom hook (FishingRodHolder_2rod_Bottom_v2_1.stl). Just wanted to switch the way the T Bar cut out was facing.UPDATE 6/7: Finally got everything printed and if I had to do it all over again, I would have printed individual holders for each end because they are a bit close together for a wall mount. Perfect for a ceiling mount (which I believe was their original intention). So I've added individual mounts (1rod-Circle, 1rod-T-Hook-Left, 1rod-T-Hook-Right).
                            LSV - BARCO KAU-BÉ.
                            MMSI: 261000743
                              FRONTAL Baofeng UV-5RA batman faceplate
                              LSV - BARCO KAU-BÉ.
                              MMSI: 261000743
                                Baofeng UV5R EXTENDED BATTERY Circular Friction GoPro Mount
                                This is a remix of https://www.thingiverse.com/thing:2489979 the intent is to make a functional alternative that fits the extended batteries. I took the original design into meshmixer sliced it into 3 sections and stretched out the middle slice. It works well, i can shake it inverted and the radio stays in. i will be using shock cord to make sure it stays secure on a bike. Making these for riders on our RAGBRAI team.Reducing the height and width to 98% while leaving the length at 100% will give you a snug fit. TPU! this will not work for PLA. These are the mounting parts needed designed by the original designer.https://www.thingiverse.com/thing:2491777https://www.thingiverse.com/thing:2491801Thanks to: https://www.thingiverse.com/coddingtonbear for the version for standard batteries.
                                LSV - BARCO KAU-BÉ.
                                MMSI: 261000743
