    POLEA HECHA CON GRILLETE Roll for shackle
    LSV - BARCO KAU-BÉ.
    MMSI: 261000743
    VER Mi canal en YOUTUBE
    VER TODOS MIS DISEÑOS 3D
      TAPA VENTILACION Boating Stuff - Vent Flange
      I bought a few 4" (102mm) stainless vents for the storage lockers on my old sailboat. I chose a type I could close in the winter or while sailing through heavy seas. Then, I thought it would be nice to create a flange that catches and drains water that gets thru. In working on this upload, I just realized that a slightly tweaked version that goes on the outside might be nice too. I'll upload that soon. I'll also upload pics after I install this. For any PLA print to be used outside, I would spray the piece with exterior paint made for plastics. Or sand, prime, and paint with enamel. I've also had good luck with just spraying a clearcoat over PLA to protect it. Even a coat of factor 50 sunblock followed by thick car wax can help. I know that last one sounds crazy. Printing of this is easy. Heavy on the infill. No supports or adhesion required. For the vent cover, use support - there is a bevel on the bottom.I bought my stainless vents at a marine consignment, but I'm 90% sure these are the same thing at defender marine. https://www.defender.com/product.jsp?path=-1&id=6511415This is a pretty obscure thingy, but hopefully someone will find it useful! It might be good for RV's, Caravans, sheds, dock boxes, etc.
      LSV - BARCO KAU-BÉ.
      MMSI: 261000743
        Una cosa que sería muy útil son deflectores para tapar los desagües del pozo de anclas, esos bonitos agujeros cuya función es introducir agua en el barco mientras estás navegando, especialmente con olas de proa (buen susto me llevé hasta que encontré a los "culpables", que ahora tengo tapados con cinta).
        No he encontrado ningún diseño precocinado, así que voy a preparar uno, lo que debería ser fácil (algo como lo siguiente):
          COJINETE Quilla retráctil BALL BEARING - Sailboat Beneteau First 211
          This piece allows to contain a ball bearings system (51106 din711) inside. The whole components allow to turn the endless screw of the sailboat Beneteau First 211 retractable keel system, using a winch handle.
          LSV - BARCO KAU-BÉ.
          MMSI: 261000743
            ACOPLADOR PIEZAS SEÑALES CONO BOLA Sea signs building coupler
            LSV - BARCO KAU-BÉ.
            MMSI: 261000743
              RECIÉN SALIDA DEL HORNO ESTA MAÑANA
              (MIA) Espatula rasqueta con tarjeta crédito scraper spatula with credit card
              LSV - BARCO KAU-BÉ.
              MMSI: 261000743
                Baofeng uv-5r dust cover for mic/headphone plug
                LSV - BARCO KAU-BÉ.
                MMSI: 261000743
                  BASE CARGA iPhone Cradle with 24mm Ball Joint
                  CAMBIANDO EL CABLE PUEDE SERVIR PAR ANDROID, AJUSTANDO LAS MEDIDAS DE LA CAJA
                  LSV - BARCO KAU-BÉ.
                  MMSI: 261000743
                    CAJA PARA "COSAS" POR EJMPLO MANIVELA (SI NO PESA MUCHO)
                    holder for stuff on boat
                    LSV - BARCO KAU-BÉ.
                    MMSI: 261000743
                      NEUMÁTICAS Y KAYAKS: ULTIMATE KIT FOR FISHING AND SLIDE RAILS
                      WELL this parts of Fishing kit is mostly and originally at thingverse, I am not the creator, I just adapt the parts to fit at sliding rail of Zemenmech ( THE BIG ONE )...You can buy the Rails here: https://pt.aliexpress.com/item/1005001947522246.html?spm=a2g0o.9042311.0.0.2742b90aVPEux8The Fishing Rod Parts I reccomend print with: 80-9% Infill, The rest I used 40% in PLA or ABS, I prefer PLA...The Rail Blaza was modified cutting the body in two pieces to allow you to print it without support...Notice that: I also added the .3mf file from the Microsoft 3D Builder, it is a free program to allow you make your own modifications...This kit is composed of this 17 parts:Rail Blaza - Base, Top of Base, Clip, and two connections one clean and another to pass ropes inside - (first 5 Pieces at left )DK Scott mount (1Piece at next collumn )KAYAK SELF DRAIN SCUPPER PLUG - Works like a valve - ( 3 Pieces, CONIC, Grid and Bal Same cllumn of DK Mount)Fishing Lures Support - Modified to Rail Blaza ( 1 piece at Next collumn)Cleat to fix ropes - under the lure support - (1 Piece)HOOK CLIPS ( 2 Pieces ) - for fix the paddle at boatFishing rod Support - at last collumn - ( 4 Pieces: clip, Support itself, Knob and rail Blaza adaptation)Have fun, soon I will test the parts in water...Updating:22-10-2024Sorry to say that, but the original .3mf was losted due a computer blue screen of dead... ( yes I kind of lost my Hard Drive) but I added the 3D Builder software to this stl, so if you have a smaller printer or desires to cut and print only one piece from all set , now you can do it, and also modify expand or shrink all .stl files here...
                      LSV - BARCO KAU-BÉ.
                      MMSI: 261000743
                        Raymarine transducer nut and shims
                        LSV - BARCO KAU-BÉ.
                        MMSI: 261000743
                          BASES VARIADAS Fully Customizable Boat Rail Base
                          Today we bring you a fully customizable boat rail fitting that can also be used for shower rails, clothes rails, etc.This was created by request for one of our followers and is currently untested.Update: This design can now also be used for rectangular tubes (as of version 1.2).This design is completely free and shared under a permissive license. Your support is hugely appreciated.Did you know?Some of our designs cannot be found on Thingiverse. If you are looking for more, check out our premium projects:https://codeandmake.com/premiumOpenSCAD Customizer OptionsThis design has the following Customizer options:MaterialMaterial_Thickness - Thickness of the materialTubeTube_Profile - The shape of the tubeRound_Tube_Inside_Diameter - The inside diameter of the round tubeRectangular_Tube_Inside_Width - The inside width (Y axis) of the rectangular tubeRectangular_Tube_Inside_Height - The inside height (X axis) of the rectangular tubeMin_Tube_Length - The length of the tube on the shortest sideTube_Angle - The angle to tilt the tubeTube_Bevel_Percentage - The amount to bevel the end of the tube (as a percentage)Grub_Screw_Hole_Diameter - Grub screw hole diameter. Not threaded. Will require manual tapping.BaseBase_Type - The type of base (round or rectangular)Screw_Hole_Diameter - The diameter of the screw holeScrew_Head_Diameter - The diameter of the screw headScrew_Head_Countersink_Angle - Screw countersink angle (82 and 90 are common)Screw_Padding - The minimum amount of padding around each screwBase_Bevel_Percentage - The amount to bevel the edge of the base (as a percentage)MaterialWe recommend printing this in a durable filament, such as ABS, nylon or even metal!Versions1.4 (25 Apr 2021)Improved screw positions for round base with non-square rectangular tube1.3 (25 Apr 2021)Fixed issue with bevelled corner for rectangular tube profile1.2 (25 Apr 2021)Added rectangular tube profile (Tube_Profile option added and Tube_Inside_Diameter option replaced with Round_Tube_Inside_Diameter, Rectangular_Tube_Inside_Width and Rectangular_Tube_Inside_Height options)Improved preview performanceFixed bug when Rectangular Base_Type selected and Base_Bevel_Percentage set to 0Fixed round tube quality issue when Tube_Angle set to 901.1 (1 Apr 2021)Increased polygon count for smoother finishAdded base type option (Base_Type) and a new base type (rectangular)Added screw padding option (Screw_Padding)1.0 (31 Mar 2021) - Initial versionPrintingRecommended slicer settings:Resolution: 0.1mm - 0.2mmInfill: ~50% or higher if you need it to be extra durable.Supports: Should not be requiredRafts: Not required, unless you experience adhesion issues.LicenseThe "Boat Rail Base" models (.stl) are licensed under the CC BY license by Code and Make.The "Boat Rail Base" code (.scad) is licensed under The MIT License by Code and Make.Note: 'BSD' license has been selected as it is the closest available option in the list.We are proud to offer content to you absolutely free.We love to create free content for you. As you might imagine, it takes a lot of time. Supporters help us fund materials and equipment to create future projects and tutorials. To show your appreciation, please use the link below:https://codeandmake.com/supportWe thank you so much for your support!
                          Editado por última vez por LSV; 24/05/2023, 00:49:49.
                          LSV - BARCO KAU-BÉ.
                          MMSI: 261000743
                            CAJA Raymarine i70 instrument housing
                            This is a housing for the Raymarine i70 range of instruments if you want to mount as stand alone instruments. | Descargar modelos STL imprimibles en 3D gratuitos
                            LSV - BARCO KAU-BÉ.
                            MMSI: 261000743
                              CAJA COSER VELAS Speedy Stitcher Storage Box
                              Wanted a box to stop my speed stitcher, needles and bobbins rattling around in the bigger toolbox so decided to make… | Descargar modelos STL imprimibles en 3D gratuitos
                              LSV - BARCO KAU-BÉ.
                              MMSI: 261000743
                                SOPORTE RAYMARINE Autohelm autopilot attachment
                                This is a replacement for a broken clamp that connects the autopilot to the steering wheel. You could potentially also use it for clamping other things like pipes or cables.
                                LSV - BARCO KAU-BÉ.
                                MMSI: 261000743
