    CRUSTACEO ARTICULADO Articulated Crayfish
    Model crayfish with 21 points of articulation. I'm entering it in the #OnSuchAFullSea competition, though technically it's not a fish... and it's a freshwater animal not marine! Shhh, hopefully no one will notice! The claws and tail segments are designed to use pieces of 1.75mm filament offcuts as hinges. All 10 legs are attached to the body on ball joints. No glue required, though it may help if the main parts feel too loose. Modelled and sculpted in Blender. Plated and prepared for export in 3ds Max. Crayfish_Assembly_Instructions.pdfFull assembly instructions with pictures. Crayfish_STL.zip [recommended]This contains all parts plated into small groups of related parts. You may wish to print several groups at once depending on your build-volume. Crayfish_Individual_STL.zipThis contains each part in a separate STL file. Don't forget to print 2x copies of each of the 4 leg files (a total of 8 walking legs).
    Editado por última vez por LSV; 05/07/2023, 16:38:48.
    LSV - BARCO KAU-BÉ.
    MMSI: 261000743
    VER Mi canal en YOUTUBE
    VER TODOS MIS DISEÑOS 3D
      (MIO) PLACA ROTULO CAPITAN
      LSV - BARCO KAU-BÉ.
      MMSI: 261000743
        HERRAMIENTAS LIJADO Sanding tools - hands & machines
        LSV - BARCO KAU-BÉ.
        MMSI: 261000743
          TIBURON ARTICULADO Articulated Shark
          No supports required. Just slice and print!!4 Versions available:Shark_v4_A.stl: Original design, movable jawShark_v4_B.stl: Friendly face, movable jawShark_v4_C.stl: Original design, NON-movable jawShark_v4_D.stl: Friendly face, NON-movable jawDesign updated to v4 for a tighter tail jointThe non-movable versions are intended for children, as teeth are quite sharp. Or just in case you have trouble printing the movable one.Best results if you use a thin layer resolution (0.16 mm works perfect)After printing, the tail and the jaw should get free with a little force:https://youtu.be/14z1ll9yMmUThen just enjoy it, even in the water!!https://youtu.be/E1W-RyH8bGAhttps://youtu.be/aV-XhMr7EdcCheck my other articulated designs HERE!For Commercial License questions, check here
          LSV - BARCO KAU-BÉ.
          MMSI: 261000743
            ESTANTE NEVERA REFRIGERADOR Mini Fridge Door Shelf
            I wanted to maximize the beer cans capacity for my Insignia 2.6 cu ft mini fridge. This is the design background of these shelves.I designed the door shelves with flat base to let cans stand straight instead of the original slanted slots. These will give more spaces for the main compartment and now I can stock more than what it can hold in default.CansOriginalMy Door Shelf1 pint536512 oz11PrintingPut front face down to print.No support needed as I designed thin walls for the hook parts. Chip them out, use a knife to clean and make hook surface smooth.PartsFridge Door Top Left.stl - A shelf with shorter arms designed for top left of the mini fridge door.Fridge Door Middle Long.stl - A shelf with longer arms designed for middle of the mini fridge on both left and right.
            LSV - BARCO KAU-BÉ.
            MMSI: 261000743
              (MIA) MESA BARCO GEMINI TABLE SAIL BOAT
              LSV - BARCO KAU-BÉ.
              MMSI: 261000743
                POLEA Flip-Flop Block (Harken)
                LSV - BARCO KAU-BÉ.
                MMSI: 261000743
                  CIERRE Dometic Fridge Lock
                  Small lock to keep the door from opening while driving on an RV-type mini-refrigerator.Top part only.ABS worked well for me.Print infill 100% for a solid part.Use a brim if needed.
                  LSV - BARCO KAU-BÉ.
                  MMSI: 261000743
                    Mesa para cortar y lijar con Dremel. Dremel sanding and cutting table.
                    ESPMesa 10x10cm para lijar y cortar para dremel 200 o similar.Se puede cambiar la herramienta de la dremel solo levantando la mesa ( por eso tiene los pies a parte).Para su montaje se necesita una madera o base de como minimo 12x20cm y tornilleria para madera y 2 tornillos con tuerca M5.ENG10x10cm table for sanding and cutting for dremel 200 or similar.You can change the dremel tool just by lifting the table (that's why the feet are apart).For mounting will need a wood or base of at least 12x20cm, some wood screws and 2 screws with nut M5 are required.
                    LSV - BARCO KAU-BÉ.
                    MMSI: 261000743
                      DISCO LIJADOR Dremel Rotary Sander
                      An easy print, use at least two layers and above 30% infill. Watch your extrusion multiplier to get the gap for the sand paper right. This sander is not meant to remove larger amounts of material, it is better to performs light sanding and buffing.If you would like help modeling a tool like this, or is you would like help with any other project, please visit my website. You can contact me there.https://www.bitdrafted.com/
                      LSV - BARCO KAU-BÉ.
                      MMSI: 261000743
                        PULPO ARTICULADO Ball-joint articulated octopus
                        This started out as an exercise in making the smallest ball joint tentacle that I could get to print reliably on my printer. It turned into a cute little octopus when I decided to make a fun gift out of the tentacles. It's surprisingly annoying and time-consuming to build, since each segment needs to be hand-trimmed of support and carefully snapped into the next, but the resulting toy has a lot of flexibility and posability. Printing the segments in all different colors to make a rainbow octopus is optional but highly recommended. Update 4/5 - I was experimenting with some freehand sculpting tools, and created a big-eyed alien head for the octopus that I've uploaded. Update 4/7 - added a fantasy steampunk submarine version of the main body. Update 4/9 - skull body remixed from http://www.thingiverse.com/thing:4126
                        LSV - BARCO KAU-BÉ.
                        MMSI: 261000743
                          ¿CONECTOR TANGÓN SPINAKER? HARKEN BOAT LATCH
                          LSV - BARCO KAU-BÉ.
                          MMSI: 261000743
                            CAJA PILAS Beer Crate battery holder
                            TAMBIÉN HAY PARA 9V
                            Remix of the AA and AAA beer crate battery holders from this things: https://www.thingiverse.com/thing:5389119https://www.thingiverse.com/thing:5404247Print the 8 letters A for AA crate and 12 letters for AAA crate and glues them with Cyanoacrylate (loctite)If you go with the stackable the bottom rim has to be super glued in place
                            LSV - BARCO KAU-BÉ.
                            MMSI: 261000743
                              PARA MANTENER ABIERTA LA PUERTA REFRIGERADOR Dometic Fridge Lock Card
                              This is the locking card for Dometic fridges in RVs. In my case, a Coachman 193BHS, for reference. | Download free 3D printable STL models
                              LSV - BARCO KAU-BÉ.
                              MMSI: 261000743
                                ROUTER PARA DREMEL adjustable router
                                This gadget converts your rotary tool (i.e. Dremel) to a handy router. The inner thread of this gadget is compatible with most Dremel-like tools. The height can be adjusted by turning the knob part. The thread pitch of the adjustable mechanism is 2 mm so each half a turn lifts the tool 1 mm. Total movement of the lift is around 20 mm depending the machine is used. I've tested the gadget with Bosch GRO 10,8 v.See an example groove cut on Youtube:https://www.youtube.com/watch?v=2-ibSAT9J0E
                                LSV - BARCO KAU-BÉ.
                                MMSI: 261000743
