LSV - BARCO KAU-BÉ.
MMSI: 261000743
VER Mi canal en YOUTUBE
VER TODOS MIS DISEÑOS 3D
Re: Reunir ficheros impresión 3d barco
CAJAS Storage box
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
TIRADOR PUERTAS CAJONES https://media.printables.com/media/p...3267.webpFlush Ring Pull, Marine Recessed Handle for Drawer and Locker
These are often found on boats, and in crowded spaces where space is at a premium. No getting tangled with clothes, | Descargar modelos STL imprimibles en 3D gratuitos
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
UNIÓN DE REMOS INDIVIDUALES Oar Connector / Joiner - Intex Boat Inflatable
A simple replacement for the joiner on my Intex (Challenger Series) inflatable boat. The stock joiner broke at the screw and I wanted a more sturdy solution. It uses 2 Star Grip M6 Screws with 40mm of length aswell as two M6 nuts. The nuts are measured to be 9.9cm in width (from flat side to flat side) and have to be around that size or a bit smaller to fit into the sockets. I'd reccommend using PETG since the oars will proably mostly be used on warm days and will get lots of direct sunlight.
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
ALETA SURF Surfboard Replacement Fin
Hi i wanted to share with you all this design for a replacement fin for soft boards.i tried to search for a similar item thinking a STL file was easily available online but failed to find anything close to create a replacement item. So after some 5 or 6 revs later i came up with this design which works well & seems a very acceptable replacement option.This is just a basic push in softboard fin secured by a threaded 30mm location pin retainer + 36mm long x 30mm wide head screw as a replacement fin for the cheaper softboards, soft surf boards and the soft body boards.You can buy this items on eBay for about $30 Australian, but hay this is a 3D Printing website & a challenge … plus I’m too tight to pay $30 + postage and wait over 4 weeks for the item.This is a partial remix / redesign of the canoe fin by JANMES12 ... https://www.thingiverse.com/thing:964373i chose this fin design as it is very sturdy (at 13mm thick) and practical for diy home 3D printing. Some of the thinner more finesse designs were not sturdy enough to justify the printing fail rate and abuse they are going to get during use and in transit.i added a wider load spreading flange & the two push in 30mm threaded locating pins, these were ~93mm apart on my soft body board & surf board.i created 2 options of fin heights ... ~50mm & ~90mm fin, of course you can cut this fin off and insert any other design you want on to the mounting plate.I suggest you use at least 50% fill for the fins & 100% fill for the retaining screws.The screw is 35mm long x 30mm wide head, has an external size of 7mm thread for the bolt shaft & the nut receiver side of 8.5mm therefore a tolerance of 0.75mm each side which seems quite big & slack but works well. This also has a 2.5mm coin slot for tightening and removing (which is just right for the largest 2.4mm thick Australian 50 cent coin.)When mounting the Pin + screw it has a total board thickness clearance of ~60mm to ~42mm if you need a smaller gap for a smaller board thickness then cut the screws down by 5mm then retry so you get max thread grip overlap length. Using Cura to produce the GCode, I printed in an upright position & used a “everywhere” or “Touching Base Plate” support option, which works well but the only drawback is the internal female thread also gets a support mesh printed inside which needs removed or poked out on completion, I used a combination of 4mm wire, long nose plyers & wire flat head screw driver, but not too big it will damages the internal helix threads.For Cura Set up see screen grabs.See Post printing images for more supporting and detailed photos.I’m always learning so any good constructive feedback or links to other similar items are welcome.Thanks for reading.
LSV - BARCO KAU-BÉ.
MMSI: 261000743
AJUSTE REMOS PADDEL Paddle Adjustment Lock
My local surf shop approached me with a unique problem: a popular Stand Up Paddle (SUP) brand Ozoboard uses a snap-fit locking mechanism (grey piece in the pictures) to allow for adjustment of the paddle length, but many customers have been losing them into the ocean. With the supplier no longer able to supply replacements (which are sold for $20) it's 3D printing to the rescue! Once you print the 2 parts, all you will need is a screw with a 6mm diameter thread and length of 12mm from the underside of the head (M6 x 12mm in 316 stainless steel), and some high strength glue (I used Araldite) to glue all the pieces together. This part has been tested and will perfectly replace the old design. The print pictured has been printed on an Up! Plus 2, using the 0.2mm layer thickness and solid infill for strength. My surf shop Surf Connect is also selling these as I produce them since there is quite a demand at the moment, with the paddle useless without this small part. Get in touch with them, or contact me if you need a printed version of this to get back out on the water. | Download free and paid 3D printable STL files
LSV - BARCO KAU-BÉ.
MMSI: 261000743
ESPÁTULA CERA TABLA SURF WAVE ARCADE peigne à cire pour planche de surf
LSV - BARCO KAU-BÉ.
MMSI: 261000743
