    RETEN BOMBA AGUA Pump hose slide retainer clip
    Slide retainer clip part for electric pump. I drew this part to fit my Johnson viking-power-16 pump, but it should fit pumps with similar connectors. When the hoses are disconnected, these clips fall out and get lost easily. My improved part should not fall out as easily and can be printed in PLA. The connection name could be "KlickTite" but it seems pretty unique to these pumps. Should be compatible with Johnson part 01-36035, which is pretty hard to find, other than buying a whole new pump just to get the clip...Build tips:0.1mm layer height should work. Needs to be printed with support. Final thickness of the sliding part should be about 2.9mm. Depending on your support settings it may be needed to sand down the bottom side until it fits in the 3.0mm recess of the pump.My version may be a bit harder to install on the pump, but should not fall out anymore when the hoses are removed. The top of the print should face towards the pump. The small slope should be smooth. Especially with a large layer height, remove the steps in this slope to make it easier to install on the pump.If PLA degrades too much in wet environments, printing in ABS may be more suitable.I have designed this part using Rhino3D. It is my first Thingi and I will try to upload 3dm, iges, step in addition to STL format. (Photo's are of v1, added more rounded corners in v2)
    LSV - BARCO KAU-BÉ.
    MMSI: 261000743
    VER Mi canal en YOUTUBE
    VER TODOS MIS DISEÑOS 3D
      TAPÓN CERVEZAS Skull Beer Tap Handle
      LSV - BARCO KAU-BÉ.
      MMSI: 261000743
        FLOTADOR CERVEZA Beer Float
        LSV - BARCO KAU-BÉ.
        MMSI: 261000743
          TAPÓN CERVEZATappo bottiglia birra - Beer bottles cup
          LSV - BARCO KAU-BÉ.
          MMSI: 261000743
            Tapa de lata de refresco (Can Lid)
            LSV - BARCO KAU-BÉ.
            MMSI: 261000743
              CINTURON HERRAMIENTAS can Holster
              LSV - BARCO KAU-BÉ.
              MMSI: 261000743
                CUBIERTOS PARA EMEMERGENCIAS.
                (MEJOR HACER EN PET, ES PARA ALIMENTOS).
                Card sized knife-fork-toothpick kit remix with spoon
                I wanted to add a spoon to the card sized knife-fork-toothpick kit in case I need to stir the sugar in my coffee | Descargar modelos STL imprimibles en 3D gratuitos
                LSV - BARCO KAU-BÉ.
                MMSI: 261000743
                  tapa de cerveza
                  LSV - BARCO KAU-BÉ.
                  MMSI: 261000743
                    TAPÓN Y ABRIDOR BOTELLAS Bottle opener & lid
                    I combined the opener part of the "Josef Prusa Beer Opener" and the lid part of dede67's "Beer Bottle Lid" into a cool new bottle opener that can be used to open and close bottles with crown caps again to protect it from stuff like dirt, wasps or flys falling in.Just to mix it up a little I designed a few versions with toasts in different languages and one with a beer glass logo remixed from p5yho's "Beer keychain". Of course I added the blank version for remixing with your own styles as well. I printed with 0.2 mm layer height and changed the color after the first two layers / 0.4 mm. After printing just push a coin into the slot. If the coin doesn't fit heat it up with a lighter and melt it into the slot. If the coin is to loose just use a little super glue or a larger coin. With the given print settings one bottle opener prints in just 43 minutes. If printed a few of them in multiple colors it can be used at parties for keeping apart the guests bottles on a table. I remixed the designs using Tinkercad, sliced the models in PrusaSlicer 2.3.3 and printed them in Prusament PLA Galaxy Black and Vanilla White.
                    LSV - BARCO KAU-BÉ.
                    MMSI: 261000743
                      Un compañero del foro me ha preguntado cómo se pueden compartir los ficheros de 3d.
                      Doy la explicación aquí para todos.
                      Puedes hacerlo en varias webs.
                      Incluso cobrando, es decir, poniendo un precio a tu fichero para permitir que lo bajen.
                      Por mi parte he puesto muchos y siempre los he puesto gratis.
                      En todas ellas es necesario hacer un alta.
                      Yo lo pongo en THINGIVERSE, que es justamente una web para compartir sin problemas.
                      De ella copian otras webs que re-publican lo que pongas, dándote más "publicidad".
                      Normalmente sencilla, gratuita y sin problemas.
                      Luego subes el fichero y una o dos fotos o vistas de la pieza, no son indispensables.
                      Y ya está.
                      El que tipo de fichero lo más habitual es .STL. aunque admite otros formatos, pero con algunos tipos limitas bastante la cantidad de personas que lo usan y que deciden bajarlo.
                      En el proceso de poner la pieza en cualquier web es importante, como aquí en el foro, que el título sea descriptivo, no del tipo "¿A que no sabes qué me ha pasado?"
                      Y si lo pones en varios idiomas muuucho mejor, para ello puedes traducirlo con Google u otro, si es que te hace falta.
                      Dentro de los datos que añades puedes poner o no: el filamento que hay que usar, el modelo de impresora que usas, la densidad del modelo, la "calidad" como grosor del hilo impreso, etc.
                      Y puedes poner una descripción del uso o problemas que soluciona la pieza, etc.
                      Es fácil ver lo que los demás ponen en sus piezas ya colgadas.
                      En caso de que no tengas impresora no es mayor problema que dejar campos vacíos.
                      En un ratito puedes registrarte y colgar tu pieza, después puedes modificarlo todo o borrarla.
                      Desde luego se hace todo mejor desde una pantalla de ordenador que desde otras más pequeñas.
                      Después solo has de copiar la dirección de la página y la dirección de alguna de las imágenes y puedes colgarla aquí o en otro sitio que sea adecuado a su temática.
                      Comentario añadido:
                      Aunque mucho del disfrute de imprimir nuestras piezas es el tiempo que pasamos diseñando, a veces y si la pieza es muy sencilla, vale la pena mirar si el fichero para esa misma pieza ya existe, o hay alguno parecido que nos dé ideas o que podamos bajar y adaptar a nuestras necesidades.
                      Tampoco importa que haya más piezas parecidas a la tuya para ponerla, las diferencias importan a la hora de decidir bajarla.
                      Lo que siempre hay que hacer constar es: si hemos retocado una pieza ajena poner en el lugar adecuado que es un "REMIX" de la pieza que está en tal dirección, así eliminas reclamaciones o problemas.
                      Cualquier duda ya sabéis dónde estoy: aquí mismo.
                      Editado por última vez por LSV; 15/08/2023, 12:02:34.
                      LSV - BARCO KAU-BÉ.
                      MMSI: 261000743
                        RECIPIENTE CON CABO CONTAINER WITH ROPE
                        LSV - BARCO KAU-BÉ.
                        MMSI: 261000743
                          BOL TRENZADO Tangle Trays
                          LSV - BARCO KAU-BÉ.
                          MMSI: 261000743
                            Agradezco tu comentario pero me dejas con dudas de a qué te refieres con "arquitectura de Lissabon", supongo que el traductor no va muy fino.
                            Doy por supuesto que te refieres a Lisboa (en castellano) y su moderna arquitectura con formas de árbol.
                            Gracias por el Generador de Logos. Es otra herramienta interesante.
                            LSV - BARCO KAU-BÉ.
                            MMSI: 261000743
                              FILTROS FREGADERO Sink Strainer Stopper Caravan
                              Caravan (Adria) Sink Strainer Stopper - I made it for a neighbour, who told me this type is often getting damaged | Descargar modelos STL imprimibles en 3D gratuitos
                              LSV - BARCO KAU-BÉ.
                              MMSI: 261000743
                                DIVISIONES PARA CAJONES Customizable Drawer Dividers
                                Highly customizable drawer dividers, works not only for IKEA Alex Drawer Units created by Ralf Meier | Descargar modelos STL imprimibles en 3D gratuitos
                                LSV - BARCO KAU-BÉ.
                                MMSI: 261000743
