    TIBURON DECORACIONLow Poly Wall Shark
    Low Poly Wall SharkLow poly shark with wall mount.With the original scale and spacing, once placed, it measures 395mm.You can use the template to test how it looks on the wall and to easily mark the drilling points while keeping the original distance.
    LSV - BARCO KAU-BÉ.
    MMSI: 261000743
    VER Mi canal en YOUTUBE
    VER TODOS MIS DISEÑOS 3D
      LLAVE Hella Switch Key
      Finally! A solution to all of those times you lose your Hella key. What do you mean they want $6-10 just for a new key? This fits Hella 2843 series and similar knockoff main battery cutoff switches for automotive and marine applications. Tested to work with less slop than the real one in a new Hella switch. Files come with lettering saying "HELLA BUTTS" and without, for your own customization. Example: http://www.amazon.com/HELLA-002843011-Series-Rating-Battery/dp/B0000AYAFE/
      LSV - BARCO KAU-BÉ.
      MMSI: 261000743
        Air Pump Adapter to 1/2" outer diameter valve.
        Adpater for Advanced Elements inflatable kayak "twist valve" with 1/2" outer diameter size.
        Unas rondas para empezar, ¿sabes donde puedo conseguir los adaptadores "negros"?
        En el enlace sólo está el verde, y justo necesito lis otros pero no soy capaz de encontrarlos.
        Por otra parte, muchas gracias por tus aportaciones
        Enviado desde mi SM-A528B mediante Tapatalk
          Pondré unos cuantos lurgo.
          De momento estos:
          ADAPTADORES BOMBA INFLADO Air Pump Adapter, conector
          LSV - BARCO KAU-BÉ.
          MMSI: 261000743
            (MIO) ADAPTADORES BOMBA NEUMÁTICA air pump adapter
            He rediseñado estos por si os son útiles. (NO PROBADOS).
            EL PRIMERO YA LLEVA EL ADAPTADOR INCLUIDO.
            2 SON PARA EL ADAPTADOR VERDE ANTERIOR
            Editado por última vez por LSV; 25/09/2023, 22:54:12.
            LSV - BARCO KAU-BÉ.
            MMSI: 261000743
              Muchísimas gracias
                CONECTORES TUBOS 25,4mm US 1/2 inch PVC Connectors Kit
                This remix includes all of the connectors in the original Thing, plus several more. In addition, I totally re-did a few of them to use fully rounded corners instead of sharp corners.Additional parts include:A "Test" part, which you should print first and test for good fitParts for a basic "swivel joint". I used these in my folding kayak awning project. Two hinge pieces, for putting a sturdy hinge between two PVC pipes. I used these parts in my 3D printer enclosure Thing. See link below.A camera mount, which I also used on my folding kayak awning projectAn end plug and ball end capA matching pair of hinge parts. See assembly notes for more details.A set of basic construction elements I used for this remix, and that you can use to build your own custom connectors. You can also resize them for any size PVC pipe, US or UK/EU, and do your own remix.a sphere, for base of connectors with two or more connections at an anglea barrel part, the same as outside diameter of US 1/2" PVC pipea shaft part, the same as inside diameter of US 1/2" PVC pipeDoor hionges and a door handle that bolts to a section of PVC. I also used these parts my PVC 3D printer enclosure Thing. See that project at: https://www.thingiverse.com/thing:4850204Like the original Thing, these parts are designed for a very snug fit into US standard 1/2" PVC pipe.
                LSV - BARCO KAU-BÉ.
                MMSI: 261000743
                  SI ALGUIEN LOS IMPRIME CONFIRMADME SI LAS MEDIDAS FUNCIONAN.
                  LSV - BARCO KAU-BÉ.
                  MMSI: 261000743
                    A mi me los van a imprimir pero no se cuando, me las imprime un amigo pero tiene ir al pueblo que es donde de momento tiene la impresora.
                    Pero en cuanto los tenga te digo
                      TAPA FRENO RUEDA TIMÓN Brake Spinner | Lewmar
                      LSV - BARCO KAU-BÉ.
                      MMSI: 261000743
                        Originalmente publicado por Pititis Ver Mensaje
                        SI PUEDES ELEGIR IMPRÍMELAS EN PET, EN PLA DURAN MENOS Y CON EL AGUA SIEMPRE SE DESGASTAN MÁS.
                        LSV - BARCO KAU-BÉ.
                        MMSI: 261000743
                          Ok se lo digo
                            AYUDA PARA RUEDA TIMÓN Steering wheel knob
                            This is my steering wheel knob (or brodie knob) project for car (or boat)I needed this to increase my capacity to maneuver my city car during the parking, as I had a small accident on my left hand. It worked very well, despite its simplicity.I decided, in fact, to avoid bearings (not really necessary due to the limited number of turns it makes)Here the list of the metallic parts: (all sizes in millimeters)1 bolts M8 (80 x 8) (hexagonal head)3 nuts M8 (6 mm thickness)4 washers M8 (ext. diam. 15 mm.)2 bolts M3 (20 x 3) (round head)2 nuts M3I added several versions, choose the model which correspond better to the section diameter of your steering wheel.Edit 27/04/16: Added a new larger knob, if you need one (better grip, in case you have an heavy steering, like on a tractor). If you choose to realize this one you should also replace the main bolt, always a M8 but 100 mm length. The jaws remain the same.
                            LSV - BARCO KAU-BÉ.
                            MMSI: 261000743
                              etiquetas cables 7mm Ignition Wire Markers Labels
                              I needed to label my ignition wires when I was changing the coils and plugs. Just another excuse to 3d print something, so I designed these ignition wire markers. Choose a filament color that contrasts with your ignition wire color. For example, if you have black or dark colored ignition wires, use a light colored filament for the numbers to show through. If you have bright colored ignition wires, then you can use a dark colored filament to contrast the wire color for the numbers to show through. If you have black wires and use black filament, you won't really see the numbers very well.Of course, the engine compartment is very hot. However, these don't support anything, so I don't think it really matters what type of filament you use. Certainly, a high temp filament would be bestUPDATE: I uploaded an "improved" version as a remake. I rounded a top edge to make it easier to install. This one works fine, but v2 is slightly easier to install: https://www.thingiverse.com/thing:5995145
                              LSV - BARCO KAU-BÉ.
                              MMSI: 261000743
                                Carrete Lightweight storage
                                LSV - BARCO KAU-BÉ.
                                MMSI: 261000743
