    Bomba manualHand water pump
    LSV - BARCO KAU-BÉ.
    MMSI: 261000743
    VER Mi canal en YOUTUBE
    VER TODOS MIS DISEÑOS 3D
      PANEL INDICADORES (ADAPTAR A BARCO) Lexus IS200 IS300 gauge pod
      A top of the dashboard gauge pod for 1st gen Lexus IS300, IS200, Toyota Altezza.Suitable for 3x 52mm gauges.LHD and RHD versions included.Versions with angled objects included for minimum supports.Print it, sand it, paint it and stick it on or mould it in.Modeled in Blender 2.81, source .blend file is included as well.
      LSV - BARCO KAU-BÉ.
      MMSI: 261000743
        TAPA kayak locker
        The cap for kayak locker made in neoprene break easily. The Valley cap made in England are expensive and difficult to order.This design printed ninjaflex, work very well for 20 cm locker.
        LSV - BARCO KAU-BÉ.
        MMSI: 261000743
          TAPA Yamaha PWC Oil Injection Cover
          Yamaha Waverunner Oil Injection CoverM6 hardware. Goes in hose oils. No drilling required.
          LSV - BARCO KAU-BÉ.
          MMSI: 261000743
            CAJA Raspberry Pi 7 Inch Touchscreen display
            Easy to print solid Raspberry Pi 2 or 3, Official 7 inch touchscreen case. I wanted to keep the black bezel look of the screen and not making it bigger. You will need 4 M3x6 or 8 screws to secure the back cover. There is room inside for the power cables.I will use this as a kiosk display and NAS for my Kodi player I have cut out some areas at the back where I can add velcro strips to mount a 2.5 inch HDD.Enjoy and show off your builds and mods.Update 290516: Added 2cm Velcro lid and lid without HDD support.Update 310516: Added new case with little door access to the SD card. Still need small pliers or pincet but it's easier than unscrewing the back lid.Update 150317: Added split STL for front to enable print on small print beds.Update 010118: Added split STL for case Left and Right to enable print on small print bedsUpdate 240418: Added the 123Design source files
            LSV - BARCO KAU-BÉ.
            MMSI: 261000743
              Octahedral Radar Reflector
              This is a radar reflector with an overall diameter of 15 cm. The triangular leafs are 1 mm thick and 5 cm high, which have been pasted with aluminum adhesive tape to obtain the reflecting surface.Hereafter the parts list for printing a whole radar reflector (as shown in the image):1 center6 cap8 plate12 leafFor fixing the plates to the center 2.5 x 8 mm screws are needed.
              LSV - BARCO KAU-BÉ.
              MMSI: 261000743
                SOPORTE FUSIBLES Fuse Holder
                Keep all you fuses neatly organized with this easy storage unit. OpenSCAD source included.
                LSV - BARCO KAU-BÉ.
                MMSI: 261000743
                  BASE CONECTORES Lever Wire Nut Connector holder
                  I was unable to find any kind of holder or mounting system on Amazon for these cheap Wago-like connectors. I needed some for a project, so I had a go at making my own. A feature of this design is that you can still access the testing hole in the top of the connector. This means that you can check the voltage without disconnecting anything.The downloads comprise four sizes of connector housing; 2-way, 3-way, 5-way and 8-way. These can be used individually and screwed to a surface via the central 3mm countersunk hole. A connector can then be wired up and fitted into the housing where it will be held in place.2nd Dec 2021 update: The 'ears' at the top of the housing have been enlarged. The housing clip now holds the connector even when you lift one of the levers.Alternatively, if multiple connectors are required, then they can be slid into one of the channels. The connector housings at either end of the channel can be screwed down, through the channel, to whatever surface they are being mounted to. The are four channel lengths to give you options: 50mm 100mm, 150mm and 200mm.
                  LSV - BARCO KAU-BÉ.
                  MMSI: 261000743
                    PIÑÓN ARRANQUE OMC Johnson/Evinrude Pull Start Pinion
                    This is the pinion gear for the pull start mechanism on Johnson, Evinrude, and Gale outboard boat motors. It should fit most older models between 6 and 8 horsepower (and possibly some others). I designed the modified piece for our 1960s 6hp Johnson motor and the original piece for our 1980s 7.5hp motor. The reason I have two different part ones is that I made a modified gear to fit our 1960s motor because one of the bushings had worn out causing the whole assembly to be loose and the gear to slip. I fixed this by making the gear a little bit bigger. The original part one should fit in most cases, but if your bushing has worn out as mine did or if your pull start mechanism is really loose, you may want to print the modified version. Once you have decided which part one to print off, you will also need to print off part two. You will need to glue part two into the notch on the bottom of part one (I used super glue). Once the two parts are glued together, you can clip the spring onto the part and attach the gear. As for strength, I have used one of these parts for a month or two and I was able to get a couple hundred pulls out of it before the first tooth snapped (although it was still functioning). I think it is possible that this was a fluke, so I'll have to do some more testing.Update: After using it for a summer the PETG gear was missing quite a few teeth. It was still fully functional but close to failure. Have not tested the PLA gear as in-depth, but be aware that it could break
                    LSV - BARCO KAU-BÉ.
                    MMSI: 261000743
                      SOPORTE Boat Compass Mount
                      Quick and easy way to mount a compass to your boat. PLANo supportsExtruder 200CBed 70C
                      LSV - BARCO KAU-BÉ.
                      MMSI: 261000743
                        TAPÓN Scuba diving regulator DIN cap
                        LSV - BARCO KAU-BÉ.
                        MMSI: 261000743
                          VENTILACIÓN ORIENTABLE Mobile Home exhaust hood spoiler
                          In my MH project I needed a wind-spoiler at the exhaust. This is it ! Please 'LIKE' before collecting!Thomaswww.3daybreaker.blogspot.com
                          LSV - BARCO KAU-BÉ.
                          MMSI: 261000743
                            PIEZA CERRADURA TIPO PERKO Surface Mount Latch
                            Replacement arm for surface mount latch. I suggest using stainless nuts as inserts.
                            LSV - BARCO KAU-BÉ.
                            MMSI: 261000743
                              Tapa enchufe conector Cover XT60 Cap
                              Didn't need strain relief so I remixed this cap to use a pair of XT60s. One for the printer and one for whatever floats your boat.No supports needed. Already oriented for printing. I printed mine at .2 with no issues and had a good fit on both the XT60's and this PSU Cover (https://www.thingiverse.com/thing:2784531) designed by Gizzle (https://www.thingiverse.com/gizzle/).
                              LSV - BARCO KAU-BÉ.
                              MMSI: 261000743
                                TAPAS Blue Sea Systems 250A Bus Bar Cover
                                Design for a friction fit cover for the Blue Sea Systems 250A Bus Bar Cover. Can most likely fit other bus bars and terminal blocks as well. Covers 5/16' studshttps://www.amazon.ca/gp/product/B006VELFDK/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&th=1
                                LSV - BARCO KAU-BÉ.
                                MMSI: 261000743
