LSV - BARCO KAU-BÉ.
MMSI: 261000743
VER Mi canal en YOUTUBE
VER TODOS MIS DISEÑOS 3D
Re: Reunir ficheros impresión 3d barco
buenas,
teneis algun enlace para marcadores de cadena, he conseguido varios en thingiverse...pero no me convencen,solo uno de ellos lleva tornilleria...los que llevan clips de presion me parece que no van a ser muy fuertes, voy a probar a imprimir alguno
TAPÓN PILOTO AUTOMÁTICO ST1000 / ST2000 Raymarine Tiller Pilot Thrust Cap G004
Our autopilot gave up the ghost when the connector became detached from the tiller.It immediately became obvious why it broke and that this is unlikely to be an isolated incident.The original thrust cap is hollow through the thread where the highest load or stress would be. The thread even has a very obvious neck which seems to have no purpose other than to weaken the cap further.Guess what? A genuine replacement part is available. Judging by the cost I can only assume the replacement part is made from some sort of rare earth and highly scarce element. Although it does look suspiciously like the original made from ordinary plastic.Since Raymarine call this part the “thrust cap” one would have thought they may have considered not making the centre hollow and also leaving off the neck!! Very much a case of “there is a clue in the name”!!!Anyways, I decided to make my own replacement part out of PLA rather than deplete the earths resources of rare and expensive black plastic looking stuff.My version has an inner ring so that it snaps positively into place when used.The thread is slightly off pitch so that it screws in freely until close to the end where it starts to bind up to provide a “nyloc” type effect.I gave it 9 perimeters for strength and used 0.2 layer height.
Editado por última vez por LSV; 11/09/2023, 21:41:15.LSV - BARCO KAU-BÉ.
MMSI: 261000743
EXTENSOR CAÑA PILOTO AUTOMATICO Ray marine ST1000 tiller pilot extension bars
Tiller pilot extensions are very expensive . Print them for cheap!Check out my youtube channelhttps://www.youtube.com/@boatsandbitsThe design for this is public on tinker cad link in the following video descriptionhttps://youtu.be/YNcIELC3s6gf you got some value out of this and want buy me a coffee it would be much appreciatedhttps://www.buymeacoffee.com/boatsandbits
LSV - BARCO KAU-BÉ.
MMSI: 261000743
MIO- EXTENSIÓN CON TAPÓN Raymarine Tiller Pilot Thrust
LSV - BARCO KAU-BÉ.
MMSI: 261000743
HolaOriginalmente publicado por LSV Ver MensajeTAPÓN PILOTO AUTOMÁTICO ST1000 / ST2000 Raymarine Tiller Pilot Thrust Cap G004
Os funciona este archivo?
Cuando hago la segmentación y lo guardo para imprimir no reconoce los archivos
A mí si me funcionan.
¿En qué clase de fichero guardas la segmentación?, supongo que en GCODE.
En GCODE se puede guardar en texto y codificado digital.
Hay que guardarlo siempre en modo codificado ya que los de texto no todas las impresoras los leen.
Y cada programa le pone sus variantes al GCODE, así que ha de ser el de tu impresora.
Normalmente los STL debe leerlos tu laminador y de ahí no debería haber problema en crear el GCODE específico y con el "apellido" *.GCODELSV - BARCO KAU-BÉ.
MMSI: 261000743
Puedes hacer una prueba: abrel fichero con el NOTEPAD o algún programa de texto.
Si se puede abrir y leer coordenads bien es texto y no vale.
Así se ve en modo texto:
"facet normal 0.0 0.0 0.0
outer loop
vertex 18.434001922607422 -0.7600002288818359 0.0
vertex 19.016002655029297 -0.8240032196044922 0.0
vertex 19.016002655029297 -0.8240032196044922 6.079998970031738
endloop"
Y así codificado:
"Z ÈÞß=Gw~¿ ŠA¬A—n=ÂxéRAš™§A!°=ÂxéRAš™§A!°=–Cã@ "
Editado por última vez por LSV; 13/09/2023, 19:05:36.LSV - BARCO KAU-BÉ.
MMSI: 261000743
HolaOriginalmente publicado por LSV Ver MensajeA mí si me funcionan.
Si los guarda en GCODE, y el programa de impresion y segmentacion es el Cura.
He probado con los tuyos y no tengo problema, pero el otro cuando lo guardo en un pen la impresora me dice "not faul line"
Te explico:
Veo que a mí también me da algú error cuando lo abro tal como baja.
Yo repaso todos los fichero que bajo con el programa 3D Builder, que suele venir directamente en windows y si no se baja en pocos segundos de aquí:
https://apps.microsoft.com/store/det...hl=es-es&gl=es
Y al abrirlo sale un recuadro rojo diciendo que hay un error.
Pulsas el recuadro y lo arregla al momento.
Luego lo guardas como un nuevo STL ya arreglado.
Yo tengo el 3D BUILDER como visor por defecto de los fiecheros STL y repaso todos con él.
https://blog.prusa3d.com/repair-3d-models-errors_7529/
LSV - BARCO KAU-BÉ.
MMSI: 261000743
Respuesta: Re: Reunir ficheros impresión 3d barco
Ok, lo probaréOriginalmente publicado por LSV Ver MensajeTe explico:
Muchas gracias
FIJAR CAÑA Tiller Clutch, Tiller Lock
This is a Tiller Clutch or Tiller Lock for use on a sailboat when you need to attend to a fouled sail or what have you, and can't leave the helm. Engage the lock and this will keep the tiller from wandering aimlessly. Pressure fit so that no screws are needed to fix this to your tiller! A stainless bolt/nut and line are all that is needed. Store bought clutches cost upwards of $100 (like this one). Print your own for pennies!Modified from ottaross's EXCELLENT model!: https://www.thingiverse.com/thing:3049554Thanks ottaross!
LSV - BARCO KAU-BÉ.
MMSI: 261000743
RETÉN TIMÓN crew on Tiller Lock/Clutch for square tiller handle
A remix of Propeller Heads Tiller lock. My tiller has a square cross-section so I neededsomething to affix to a flat surface. I have a small sailing dinghy (AMF Puffer) so there's not much strain on this piece. If you've got a bigger boat (more rudder area) you probably want to beef up the mounting area. I've used a dowel for both the pivot and the piston that goes inside that pushes on the clutch line (craft dowels are cheaper than filiment).Mounting holes are not sized for screws, they Ar just there as pilot holes for a drill/counter sink. Next rev I'll probably extend the ear on the base plate to add a little more area for fasteners OR get rid of the ears altogether and locate the screw holes in the bod of the block. But this remix was thrown together quick to get out on the water.
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
