    POMOS TORNILLOS Handles for M3 to M6 bolts and screws
    This collection regroups the models of handles for nuts and screws i designed over time.All designs can be printed without support, refer to the illustration to identify the different types.Edit: Bigger sizes are now available here: https://makerworld.com/fr/models/31657#profileId-57076 or here:https://www.printables.com/model/455708-handles-for-m7-to-m12-bolts-and-screws
    LSV - BARCO KAU-BÉ.
    MMSI: 261000743
    VER Mi canal en YOUTUBE
    VER TODOS MIS DISEÑOS 3D
      PIEZAS ANEMÓMETRO Navico System WD200 Anemometer Replacement Parts
      A friend was facing replacing a whole Navico Wind Direction and Speed system on his 30 year old sailboat because he was unable to find a replacement wind cup. So I reverse engineered the hub, cap, and cups for the Navico System 200 WD200. It fits together and we will test it for the first season. Printed in Bridge Nylon with supports - coated with a UV inhibitor. Also printed in ASA. {If you find this useful and want to offer thanks - just like at the club buy me the good feeling of a beer - by donating to the local food bank).
      LSV - BARCO KAU-BÉ.
      MMSI: 261000743
        DINGHI NEUMÁTICA ANEXO Inflatable boat printable kit 35 piece
        you can make it remote control.some part should print more than two times.some of them should print normal & mirror mode.you can find them in pictures.(just four parts)please don't hesitate to ask me any question.
        LSV - BARCO KAU-BÉ.
        MMSI: 261000743
          PIÑÓN INTERNO Piloto automatico Raymarine
          LSV - BARCO KAU-BÉ.
          MMSI: 261000743
            AIREADOR CUBIERTAMushroom Vent Repair
            This is a replacement inner support for a 100mm (4 inch) metal mushroom vent, as found on the roof of many boats, caravans, and sheds.
            LSV - BARCO KAU-BÉ.
            MMSI: 261000743
              LÁMPARA TECHO Wall Lamp
              For my yacht I want to have lamp in the forepeak sail storage. Having some white led strips lying around and led driver in my drawer I designed simple "spray proof" lamp.Strips are "gel version" soldered together. All connections and PCB driver were painted with Electrolube FSC (Flexible Silicone Coating) for additional protection.Material used:Shade - PET-G - naturalHolders - PET-GPlate - ABSSeal - FIBERFLEXWashers - FIBERFLEXGland - FIBERFLEXthere are two version of shade STL's - normal and with internal removable support
              LSV - BARCO KAU-BÉ.
              MMSI: 261000743
                CONECTORES TIPO COCHE 1-8 way Inline Car-Connectors, 6.3 mm
                LSV - BARCO KAU-BÉ.
                MMSI: 261000743
                  RAIL MÁSTIL Mast Gate
                  (IDEA GENÉRICA PARA OTROS BARCOS)
                  This is to fill the mast gate on a Catalina 25 so the sail slugs don't fall out allowing reefing without removing anything .
                  LSV - BARCO KAU-BÉ.
                  MMSI: 261000743
                    SOPORTE HÉLICE PROA Minn Kota Terrova rig support
                    Two various size of rail supports for Minnkota Terrova rig/shaft (33mm diameter).A snap-on claw for 25mm hand rail and the Terrova's 33mm rig.Distance between 160mm or 220mm (two separate files). Please check the actual length and compatibility for your solution before printing.The rail and the shaft should be lined up, atleast almost.The Minnkota logo is just for honoring the great trolling motor and its boost sale purposes, not making my thing popular.Please use with your own risk. The support will not prevent any damage and it's not tested in heavy conditions. Not sure can the support harm the trolling motor or the hand rail.Printed with PLA and 30% infill.
                    LSV - BARCO KAU-BÉ.
                    MMSI: 261000743
                      Snack Attack
                      A durable easy to use design that allows one to carry food, drink, utensil, and napkin with one hand in a single trip. No need to make multiple trips when taking food and drinks about. The Snack Attack features a bowl, a cup holder, and two side holders. The cup holder can hold a wide variety of glasses and cans. The bowl has ample room to fit foods and snacks that you desire. The side holders can also help you carry napkins and any utensils. The Snack Attack is designed with durable thick walls, printed from the Replicator 5th generation Makerbot using PLA food safe plastic, while being easy to hold for anyone with any size of hand. The Snack Attack will enhances your ability to transport your food and drinks with ease.
                      LSV - BARCO KAU-BÉ.
                      MMSI: 261000743
                        BRIDA AMARRA FONDEO (FIABLE ummmm) Boating Anchor Bridle
                        Esta brida la hago habitualmente con un nudo Machard o Prusik, sin más.
                        this device allows you to moor your boat on the right angle, keeping the bow into the prevailing wind and your passengers comfortable as well as decreasing fishing line angle.With the tail end attached to the stern, the device then attaches to the bow line to bring the stern around to the desired angle.Enables you to swing the vessel in any direction with only one anchorhow it works https://www.youtube.com/watch?v=-vaL-QAs258not for remix or resale on ebay personal use only
                        Editado por última vez por LSV; 06/10/2023, 10:11:01.
                        LSV - BARCO KAU-BÉ.
                        MMSI: 261000743
                          JABONERA Soft Soap Holder for RV Bathroom
                          I made this soft soap/toothbrush holder for my Travato RV to keep things orderly in such a small bathroom. this holder could be stuck up in any corner with some double sided tape. This is a universal design that should work in almost any corner of 90degrees.
                          LSV - BARCO KAU-BÉ.
                          MMSI: 261000743
                            NÚMEROS BARCO Y ANEXO Number stencil 3cm typo
                            Some Stencil for creative work. 3cm letter hight. Letter stencil in different thing: https://www.thingiverse.com/thing:4342058Thanks, Enjoy!
                            LSV - BARCO KAU-BÉ.
                            MMSI: 261000743
                              MOTOR SURF Electrofin Thruster
                              Electrofin - underwater thruster for FatJay F4125 brushless motor.Fits inflatable StandUpPaddleboard or kayak. Cheap analog of AquaMarina BlueDrive Power Fin, Current Drives Electrafin, etcNot tested for maximum speed yet.Inspired by bluerobotics T200 thruster.RC: 18650 / Nano / nRF24 / WS2812 / PotentiometerMotor: F4125 / 6s4p battery / ESC 6s 70A / Nano / nRF24 Update:Finally I've tested it. Thruster gives 5-6km/h and more than one hour range.For FatJay F4125 it is better to have 100amps ESC. 70amps ESC got overheated on full speed and stops.Sketches: https://github.com/achupahin/electrofin
                              LSV - BARCO KAU-BÉ.
                              MMSI: 261000743
                                CAJAS FUSIBLES Stackable Fuseholder
                                I DID NOT MAKE THIS!! I like to keep things I'm printing in one location, i'm simply uploading this from another site. The creator is Erik Cederberg(https://www.youmagine.com/meduza), he gets 100% of the credit!Taken from original page:A stackable fuseholder for automotive blade fuses that uses nothing more than 3D printed parts, M3 screws and regular blade connectorsI thought that most fuse holders were way too bulky for a project of mine, so i made these instead :) Print one endpiece, one startpice and as many middle pieces you want to stack for your project.Materials and methodsFor the total: 2 pcs M3 Screws of a length that suites your stack 2 pcs M3 NutsFor each holder: 2 6.3mm blade connectors 2 pcs of cable, i used 1,5mm^2
                                LSV - BARCO KAU-BÉ.
                                MMSI: 261000743
