    TAPÓN VACIADOR AUTOMÁTICO Kayak Self Draining Scupper Plug
    I got tired of water coming into my kayak from the scupper holes. They drained fine but when it was windy and there were waves water kept splashing in, so I designed this simple scupper plug that has a floating ball check valve. If water gets in from the paddle or over the side it easily flows out but no more splashing in through the scupper holes. Give it a try and give me some feedback. It can always be made better so suggestions are welcome.You may want to print the plug itself with ninja flex to allow it to seat in the hole better or you can simply epoxy them in. Note: For assembly, epoxy the the grate to the scupper plug after putting the ball in side and it works pretty well.
    LSV - BARCO KAU-BÉ.
    MMSI: 261000743
    VER Mi canal en YOUTUBE
    VER TODOS MIS DISEÑOS 3D
      PINZA NARIZ BUCEO Nose Clip for Swimming
      LSV - BARCO KAU-BÉ.
      MMSI: 261000743
        Raspberry Pi 7" Touchscreen
        UPDATE: The original model was optimized to slice and print well on my printer, which has a 0.35 nozzle. But a friend had trouble slicing this for his 0.4 printer due to the very thin walls of the enclosure. So I have uploaded alternate versions of the case and surround .stl files that have a 2mm wall thickness. (The original is 1.85mm) The same brackets can be used with either design. After slicing, it is recommended that you inspect the tool path output in the gcode before you print, to ensure adequate wall strength.The Raspberry Pi makes a great portable linux machine, but it is hard to manage without some kind of display. Now the 7" touchscreen makes it easy to see what the Pi is doing. There were a few good case designs already, but none of them allowed easy access to change the SD card. I also had problems slicing some of the existing designs to fit onto my 200mm printer.This project was inspired by http://www.thingiverse.com/thing:1082431 and http://www.thingiverse.com/thing:1164446, but is a brand new design (not a remix) hand-crafted with OpenSCAD.Design Goals:1.) Full access to (almost!) all Raspberry Pi 2 or 3 Model B ports, including the SD card slot. The case intentionally covers the USB power input port on the Pi so that you don't accidentally try to use it. Instead, USB power goes into the port on the PowerBoost to charge the battery and/or run the Pi from wall power.2.) Room inside for a large battery. I am using a 6000 mAH battery pack.3.) 3D printable without supports - short bridging required. Can be printed on a 200mm print bed. To avoid warping, let printed parts cool before attempting removal from print bed. Total print time ~ 8 hours.4.) All cables exit through the side or rear of the enclosure to allow it to sit smartly on edge during use.Ingredients:The circuit I used was published by Adafruit. I used the element14 7" Touchscreen and the Adafruit PowerBoost 1000C lipo battery charger with a Raspberry Pi 3B, along with a 6000 mAH 3.7v lipo pack. You will also need to provide a SPST or SPDT slide switch, some velcro, and a few small (#0 or M3) screws to hold everything together.NOTE: If you attempt to turn on the Raspberry Pi without a formatted (and uncorrupted) OS loaded onto the micro SD card, the monitor will not turn on. If the display doesn't work with your Pi, first make sure you have inserted a good micro SD card before you disassemble the unit.For additional build instructions, see the excellent Adafruit page describing the original project:https://learn.adafruit.com/7-portable-raspberry-pi-multitouch-tablet/overview
        LSV - BARCO KAU-BÉ.
        MMSI: 261000743
          MAQUETA Sail Training Ship Lord Nelson
          STS Lord Nelson model at about 1:74 scale. A massive thanks to Max Mudie for his help with this. It is not a simple build and requires a 500mm*500mm bed printer in addition to at least one double head or mixer head printer. It is probably not for the beginner. It took me over a week of 24 hour a day printing on three printers to make the parts in addition to a number of days of construction. This one could be RC for rudder and two prop shafts and motors my intention is to build one at twice this size and add remote control for some sails.
          LSV - BARCO KAU-BÉ.
          MMSI: 261000743
            Buenas
            haber si alguien ha visto la veleta de un equipo de viento de Garmin GWS 10?
            Saludos y buena mar
              Buscaremos a ver que sale
              LSV - BARCO KAU-BÉ.
              MMSI: 261000743
                MANETA POMO Throttle handle for Volvo Penta
                After 27 years of service the rubber handle of the throttle lever on my volvo penta disintegrated completely. No spare parts available. So redesigned it. It's not as soft as the original, but better than the steel rod inside anyway.
                LSV - BARCO KAU-BÉ.
                MMSI: 261000743
                  Originalmente publicado por vicand66 Ver Mensaje
                  Buenas
                  ¿Tienes la veleta rota guardada o se ha perdido entera?. Lo digo por tomarle medidas a ver que hay compatible o incluso generar el fichero para que te la impriman.
                  LSV - BARCO KAU-BÉ.
                  MMSI: 261000743
                    Estoy viendo que esa pieza se vende relativamente barata, sobre 38€. Indudablemente es cara para lo que cuesta el material, pero si no tienes impresora, o alguien que te la imprima como amigo, el llevarla a un servicio de impresión puede ser de 20-25€, (tendrías que consultarlo) y no sé si te saldría a cuenta.
                    Yo voy buscando a ver qué encuentro.
                    LSV - BARCO KAU-BÉ.
                    MMSI: 261000743
                      TAPA Old NEXUS instrument panel cover
                      It is very difficult to find additional cover for the old NEXUS instrument panel. Hence, I have created one for myself. I have upload for other old yacht owners just in case. It fit well following instrument's curvature. Just one note that it is a bit tight fit. If you need, you may scale up a little when you print. I have printed using PLA and UV coated for several times as it is used under direct sunlight. You may try other materials if you wish. Hope you like it.
                      LSV - BARCO KAU-BÉ.
                      MMSI: 261000743
                        Chain Marker
                        Chain marker auto clip.Design for a chain of 10 according to DIN standardclip some markers every 5m or whatever you prefer along your Anchor chain.you will alway know the chain lenght in the water.print by lot of 3 or 4 if you want to avoid overheating during process. Especially if you have a poor part cooling fan.Of course use water resistant plastic. (ABS, PET...)Added stronger clip, need to be pressed with a pliers.
                        LSV - BARCO KAU-BÉ.
                        MMSI: 261000743
                          Hola
                          no compre el barco y ya no estaba, si tengo impresora ese no es el problema....y si tuviera plano lo diseñaba sin problema..pero no lo tengo ...
                          gracias
                          Saludos y buena mar
                            Yo creo que podrías adaptar cualquier otro diseño parecido y que lo único importante es el agujero donde entra el eje, que seguramente tendrá una muesca o chaflan para mover el mecanismo inferior.
                            Con las fotos y una idea aproximada de la longitud se pueden extrapolar las demás medidas de la foto.
                            Yo no he encontrado ni siquiera las características técnicas de la veleta y de ahí si se podrían sacar el resto de medidas, pero no aparece.
                            LSV - BARCO KAU-BÉ.
                            MMSI: 261000743
                              FLOTADOR gopro float tripod / tripode flotador gopro
                              LSV - BARCO KAU-BÉ.
                              MMSI: 261000743
                                Veleta Weather Vane substitute for Davis Vantage Pro
                                LSV - BARCO KAU-BÉ.
                                MMSI: 261000743
