LSV - BARCO KAU-BÉ.
MMSI: 261000743
VER Mi canal en YOUTUBE
VER TODOS MIS DISEÑOS 3D
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
Re: Reunir ficheros impresión 3d barco
MIO- POLEA 50x20 12 DIÁMETRO AGUJERO PULLEY 12 mm HOLE
LSV - BARCO KAU-BÉ.
MMSI: 261000743
MIO- 2 POLEA 50x20 12 DIÁMETRO AGUJERO PULLEY 12 mm HOLE
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LLAVE FILTRO Vetus Sea Strainer Wrench
This wrench fits the common Vetus sea strainer lid found in many boat engine rooms.It's a double sided design, with one side being rotated 45 degrees, in case your sea strainer is in a tight space and you can't manage a 90 turn.Never use this to tighten the sea strainer lid, it should always be installed just hand tight. Only use this tool to remove the lid.It always surprises me that installing the lid hand tight ends up requiring a tool to remove it, but physics on a boat seems to be a bit odd that way.I have included the .stl file ready to be sliced, as well as the .dxf CAD file in case you want to make changes to it.
LSV - BARCO KAU-BÉ.
MMSI: 261000743
TAPA RANURA TARJETAS Raymarine E80 capot
LSV - BARCO KAU-BÉ.
MMSI: 261000743
ANEMÓMETRO Vetus anemometer rotorhead ancient model before about 1985
A friend of mine has an old VETUS anemometer onboard his sailboat. The original part broke and he could not find a spare part. The instrument is more than 35 years old, he told me.I just could not resist this task and besides i earned some beer.But somewhere i made a mistake in the freecadfile, well sometimes it comes clear i am just a beginner. You will find a brick with each rotor printed. Maybe someone switches this off and sends me the file.Until then just dont care about the three little bricks....You wonder if you have the same instrument? You might identify it by the generator that has a bearing (see last photo) on its top.I added a screenshot to show how i arranged the parts in the slicer. This way there are no supports needed.
LSV - BARCO KAU-BÉ.
MMSI: 261000743
Palanca de cambio de marchas Gear shift lever 3B2-66225-0 for Tohatsu outboard motor
Gear shift lever 3B2-66225-0 for Tohatsu outboard motorФиксатор скорости Tohatsu
LSV - BARCO KAU-BÉ.
MMSI: 261000743
PRUEBA 1 CANTILEVER MUY REFORZADO ST2000
DISEÑO ORIGINAL:
DISEÑO MEJORADO:
Editado por última vez por LSV; 04/12/2024, 19:39:00.LSV - BARCO KAU-BÉ.
MMSI: 261000743
TAPA ESCAPE Replacement part for Vetus TRC100SV - stainless steel transom exhaust connection 4"
After several weeks of use I lost (allegedly broke in the course of back movement of the boat), part of system of release.I made by it replacement for it.It is 8 mm thick instead of 3mm as at an original detail.
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
PARTES IMPRESAS EN UN MINI TRANSAT:
(Si no se vé pulsar abajo en "Youtube")
LSV - BARCO KAU-BÉ.
MMSI: 261000743
Algo "parecido" al anterior:
LSV - BARCO KAU-BÉ.
MMSI: 261000743
