LSV - BARCO KAU-BÉ.
MMSI: 261000743
VER Mi canal en YOUTUBE
VER TODOS MIS DISEÑOS 3D
LSV - BARCO KAU-BÉ.
MMSI: 261000743
Re: Reunir ficheros impresión 3d barco
MIO-ROTULACIÓN CABOS BARCO
LSV - BARCO KAU-BÉ.
MMSI: 261000743
TAPA Bateria Isolator Terminal cover
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
CONECTOR Usb Port Holder for Switch Boards etc
This is a simple female USB port holder to put a USB port on any board or device. A 20mm hole is required to mount it. You can also mount it on a 3/4 inch hole. I have added the pictures of the female USB A port that I used. You can see the pictures below the description in the post printing section. Just straighten the bent legs of the port and insert it into the printed model from the front side of the model.To see my new designs, like my facebook page https://www.facebook.com/UmersLaboratory/I can not receive tips here since PayPal doesn't work in my country. You can donate on patreon instead https://www.patreon.com/umer . Thanks.
Editado por última vez por LSV; 26/09/2024, 20:59:09.LSV - BARCO KAU-BÉ.
MMSI: 261000743
TAPA MANDO MORSE Volvo Penta boat throttle cover 3857772
Cover for lower body of boat control. My original got old and brittle and blew out of the boat while trailering some day.This cover retains the shift override pin (white nylon pin shown in photo) allowing throttle to be opened without shifting. Current version fits Volvo Penta side control shift throttle, part number 3857772 within control part number 22903907.Built in OpenSCAD so if you need something similar, you can tweak the dimensions in the OpenSCAD file and regenerate.Update after 1.5 years of use: My PLA print of this object has become a bit less flexible over time and does not grip the back edge of the control as tightly as it first did. This is now allowing it to blow off while trailering the boat at highway speeds uncovered. If I print another I will slightly increase the size of the retention bumps that ring the back inside of the object, which will make it harder to snap into place but should last longer. Alternately I believe the existing design would last longer if printed in ABS. Meanwhile I remove it when trailering a long distance and store it in a glove box so that it can't blow away.
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
