    MANETA SOPORTE FB Outboard motor mount
    A handle for an outboard motor mount.Made to replicate the one thats gone missing.
    LSV - BARCO KAU-BÉ.
    MMSI: 261000743
    VER Mi canal en YOUTUBE
    VER TODOS MIS DISEÑOS 3D
      BLOQUEO BOTON VOLUMEN Baofeng Locking Volume Knob
      Oct 22/2024 - Been using this basically ever since I designed it. It has worked fantastically.Updated Feb 1/23. Loosened up the tolerances after testingThis is a complete knob replacement with a integrated locking mechanism. You simply pull up on the knob a little, rotate, then push back down into place. There are 5 teeth on the knob that slot into 10 holes on the seat. You will lose a little fine adjustment of course, but it should be difficult to accidentally adjust your volume. You could put a dab of heavy grease inside of the knob to help it stick a little.For assembly, you will need a dab of glue (I might recommend a little white craft glue), for the Locking Seat, then install the Locking Knob, then finally the Locking Pin (maybe another dab of glue). If you used craft glue, you should be able to adjust the seat so that it lines up with the off position.I had this printed on a resin printer, but you should be able to do it with a 0.4mm nozzle as well
      LSV - BARCO KAU-BÉ.
      MMSI: 261000743
        PIEZA FB tell tale for outboard JOHNSON
        LSV - BARCO KAU-BÉ.
        MMSI: 261000743
          CLIP CINTURON Belt Clip for Baofeng UV-9R Plus
          LSV - BARCO KAU-BÉ.
          MMSI: 261000743
            Protección botón Trim tilt switch cap replacement for Mercury
            This is a replacement part for Mercury ouboards Big Tiller handle. Since my trim tilt switch failed and the original replacement was quite expensive, I went for a generic aftermarket trim switch on Amazon (see link below) and designed my own replacement cap to fit it. It fits perfectly, no rework needed, I left enough space to fit excess cables under the switch inside the cap. Trim button link: https://www.amazon.it/gp/product/B07SJ76J9P/ref=ppxyodtbasintitleo01_s00?ie=UTF8&psc=1)
            LSV - BARCO KAU-BÉ.
            MMSI: 261000743
              Garmin gpsmap 60csx GPS mount
              Garmin gpsmap 60csx GPS holder designed to be cable tied to a mast or a vertical pole.
              LSV - BARCO KAU-BÉ.
              MMSI: 261000743
                TAMBIÉN SE PUEDE BAJAR EL SKP DE SKETCHUP CON EL PUERTO EN FOTO GEOLOCALIZADA.
                LSV - BARCO KAU-BÉ.
                MMSI: 261000743
                  CAJA-BASE Back side cover for Silva 100 B/H compass
                  Back side cover for a Silva 100 B/H bulkhead mounted boat compass.The original back side is rather ugly and needs a cover if the backside is exposed. The distance from the bottom of the cover to the "flat" parts in the corner of the compass is 25 mm in this design. For a too thin bulkhead (including, in my boat, a wooden panel) this design might be to shallow.
                  LSV - BARCO KAU-BÉ.
                  MMSI: 261000743
                    PASACABLES Marine cable through fitting for spalshwell
                    I needed something to seal wire into the the large hole in my splash-well (above the water line) that was needed to pass the connector through. I found this part:http://www.jamestowndistributors.com/userportal/show_product.do?pid=8925And decided that this is something I can print and save some $$$$. Started with the makerbot knurled nut since it was the right size and I was too lazy to make my own threads that print well. I used the solid nut to get more torque. The split nut tends to slip when you tighten it. Update: I have used this as a gland in several locations now and it works quite well
                    LSV - BARCO KAU-BÉ.
                    MMSI: 261000743
                      ENGACHE RÁPIDO Klickfast for Baofeng UV-5R Type Radios
                      Klickfast system for the Baofeng UV5R type radios. Use with the Klickfast belt mount https://www.thingiverse.com/thing:4675613 or the Klickfast Molle mount https://www.thingiverse.com/thing:4675631 . To use, insert your radio mount into the receiver mount upside down then rotate right side up to lock into position and to remove, simply reverse the process. This will prevent your radio from falling from your belt as you move, walk, jump and run.
                      LSV - BARCO KAU-BÉ.
                      MMSI: 261000743
                        Me han hecho una consulta y pongo aquí algo de lo hablado por si os es de utilidad.
                        Comprar filamento:
                        Yo siempre compro en el mismo sitio. Es una casa española y sirve rápido. Está en Alcalá la Real (Jaén).
                        He comprado alguna cosa en Amazón, pero comprando siempre en el mismo sitio tienes más control de las temperaturas que necesitas por que ya conoces el material.
                        En este sitio puedes comprar un trozo de filamento de muestra para hacer pruebas.
                        Te recuerdo que el ASA y EL ABS necesitan temperaturas más altas y una protección o caja de lo que sea, aunque sea cartón o tela sobre un bastidor para mantener las temperaturas.
                        Busca por la web información para imprimir ABS o ASA en tu impresora específica.
                        Detalles como la ventilación, velocidad etc.
                        Revisa el perfil que tendrás como genérico para ABS y es parecidoal ASA.
                        En cuanto a máquina, si aún no la tienes es empezar por ASA es empezar por lo que necesita más cuidados y hay que adaptarse primero.
                        Una impresora 3d no es como una impresora normal, hay que montarla uno, afinarla, hacer pruebas, aunque suele funcionar a la primera, todo con calma.
                        Solo te diría que busques una que sea famosa, porque hay más información para usarla y que tenga de manera INDISPENSABLE cama caliente con NIVELACIÓN AUTOMÁTICA.
                        Editado por última vez por LSV; 16/06/2023, 00:44:56.
                        LSV - BARCO KAU-BÉ.
                        MMSI: 261000743
                          SOPORTE BEBIDAS TUBO 25mm Rail mounted cup/can holder for boats
                          A dual cup, mug or can holder for 25 mm rails on boatsThe inner part is divided in two sections so both cups and cans will fit.This one will only work on horizontal rails.
                          Hola a tod@s
                          Lo he rediseñado siguiendo el modelo y lo he impreso. Cafenets y cervecitas que van a caer este verano... y no por la bañera
                          Muchas gracias!!!
                            Llave para tuercas Mercury Outboard Retaining Nut Wrench
                            Works to remove and install the retaining nut on Mercury outboards lower unit. Use a large crescent wrench to turn the tool. Replaces part number 91-91947 wrench. Works for retaining nut 11-87763.Tested specifically on a 1996 40hp Merc.Not sure if its strong enough to torque to spec as I did not have a measuring tool for torque, but it's very strong.I recommend having having a wall line count of 6-8 and 15% infill.
                            LSV - BARCO KAU-BÉ.
                            MMSI: 261000743
                              BOTÓN Baofeng PTT button
                              PTT button for uv-5rI don't know if is compatible with other models
                              LSV - BARCO KAU-BÉ.
                              MMSI: 261000743
                                CARRO CREMALLERA Zipper Slider - Size 5
                                LSV - BARCO KAU-BÉ.
                                MMSI: 261000743
