LSV - BARCO KAU-BÉ.
MMSI: 261000743
VER Mi canal en YOUTUBE
VER TODOS MIS DISEÑOS 3D
LSV - BARCO KAU-BÉ.
MMSI: 261000743
Re: Reunir ficheros impresión 3d barco
SOPORTE BOLSILLO Baofeng m90 mount
Wanted to mount my baofeng uv-5r to my uniform that i use when hunting/airsoft.Its a standard m90 swedish army uniform and i use the pocket for the nametag as my mounting point.Fits my uniform perfectly but may require modification therefore i include the blender file.stl should be same size as my print. blender i export with 32.185600 metric unit scale for the scene unitI used the standard screws that came with the baofeng to attach the clip to the radiothanks to: DragonflyFabrication for parts of the modelhttps://www.thingiverse.com/thing:2821045
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
DISEÑO SOBRE IDEA DEL COMPAÑERO TABEIRON
(MIO) PASACABLES CUBIERTA DECK CABLE GLEMET
LSV - BARCO KAU-BÉ.
MMSI: 261000743
CARGADOR Li-ion battery charger (Baofeng)
LSV - BARCO KAU-BÉ.
MMSI: 261000743
SOPORTE BASE Baofeng UV-5R desk stand
HT Radios have a tendency to fall over when sitting on the desk.This stand designed for Baofeng UV-5R.I added stick-on rubber feet which keep the base from sliding around on a flat surface.(Photo is taken from the companion BF-F8HP design, this is very similar to that design with only minor dimension adjustments to accommodate the smaller UV-5R Battery.
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
MOLDE ENCHUFE Press mold for BAOFENG 3.5+2.5 jacks plug repair
This molds for molding BAOFENG 3.5+2.5 plug connetors.I'm use hot glue with hot glue pistols for made this connectror. And i have best quality with layer thickness - 0,1 mm nozzle diameter - 0.5 mmMaybe if u use 0.05 mm layer thickness u have better qualityBefore pouring hot glue lubricate the form of motor oil or Vaseline. After pouring wait 30 min and open the form/Subscribe Me if U like my things )If you want to support me: The best way to say "thank you" is to send a dollar (or more) Alas, I can't accept Paypal, but I can give you the number of the card (reality of life in Ukraine)
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
FB TIRADOR ARRANQUE Mower Starter Pull Grip Handle
Replacement handle suitable for any pull start mower, outboard engine etc.Printed in PETG for strength but could use PLA or other fine.Works a treat. I have largish hands - could scale bigger or smaller to suit.
LSV - BARCO KAU-BÉ.
MMSI: 261000743
LSV - BARCO KAU-BÉ.
MMSI: 261000743
GANCHO PINZA COLGADOR Handrail hanger peg for boat
LSV - BARCO KAU-BÉ.
MMSI: 261000743
ESTABILIZADOR GoPro SteadiCam Gimbal for Kayak
I've gotten a lot of questions about how to mount and use this piece, so I'll tell you what I did for my needs. I used a 5/16 inch (Freedom Units) tap to create threads in the bottom hole if the center part of the gimbal. A comparable metric tap should work. I put a bit of plumber's thread tape on a foot-long 5/16" threaded rod and screwed that into the tapped hole. I then used two nuts and two lock washers to secure an entire package of large washers onto the rod for a counterweight (A big thanks to the open source telescope community for that idea!).As for mounting it on my boat, I use two different solutions. On my rotomolded sit-on-top, I use a Scotty #135 Portable Camera/Compass Mount attached to a Scotty #429 Extended Gear Head Adapter seated in a Scotty #344-BK Round Flush Deck Mounting Bracket. For my thermoformed sit-inside boat, I use a Delkin Fat Gecko mount with an extender rod. Combine the gimbal pieces with VikingScientist's helm-cam selfie arm (https://www.thingiverse.com/thing:233185) or a comparable GoPro arm and create a waterproof SteadiCam that doesn't need its own set of batteries.This is more of an assembly/adaptation job than an original creation. My big contribution here is an obtuse butchering of foucteau's gimbal center:https://www.thingiverse.com/thing:1854908I filled in the center using TinkerCAD, slapped Ghir0's convenient GoPro mount on top of it like a LEGO brick, and put a hole in the bottom for a 5/16ths threaded rod. The v2 gimbal center has been updated with a smaller diameter hole for the threaded rod and a raised GoPro mount to give the camera more movement clearance. Also, a big thanks to flahut59, who re-sized the bearing holes on fouctou’s original gimbal design, so we no longer have to crack that piece when assembling the parts.TinkerCAD file for center:https://www.tinkercad.com/things/6ecg42xJSma-gopro-gimbal-center
LSV - BARCO KAU-BÉ.
MMSI: 261000743
