    SEÑUELO Wedge G
    LSV - BARCO KAU-BÉ.
    MMSI: 261000743
    VER Mi canal en YOUTUBE
    VER TODOS MIS DISEÑOS 3D
      PIEZA Quilla retráctil Beneteau First 211.
      This piece allows to hold another piece that contains a ball bearings system (51106 din711). These components allow to turn the endless screw of the sailboat Beneteau First 211 retractable keel system, using a winch handle.
      LSV - BARCO KAU-BÉ.
      MMSI: 261000743
        GoPro - Ultimate Support for Laser sailboat
        THIS PROJECT IS COVERED BY CREATIVE COMMONS - ATTRIBUTION - NON-COMMERCIAL - SHARE-ALIKE LICENSE.USERS CAN FREELY DOWNLOAD AND PRINT FOR PERSONAL USE, AND/OR DISTRIBUTE IF ACCOMPANIED BY PROPER CREDITS.CREATORS OF NEW WORKS BASED ON THIS, SHALL APPLY THE SAME CC LICENSE.COMMERCIAL USE IS FORBIDDEN IN ANY CASE !Update 2020-12-11: it snapped ! (Se image above) It's the "Straight link Type 2" So, even printing it horizontally, it eventually snapped, a couple of weeks ago. I printed it again, this time using Nylon Bridge. It works fantastically !! Today I sailed with I nice northern breeze. Did something like 50 jibes in 20 minutes, some - of course - went wrong and the main sheet got tangled around the camera mount, with no consequences. Very good, indeed. Update 2020-12-01: uploaded a new, improved, STL file for the straight link type 2. Strongly suggest to use the improved version, which matches much better the camera link.This improved version can be sliced for printing it vertically!This is a project I've been working on for more than one year. Over this period, I tested several different solutions, customising things like this, and like this.They all worked pretty well, but had some big flaws too - the excessive size being the most significative.I also took into consideration buying a thing like this, but it was far too much expensive for my budget (and bulky, as well).Then I came up to this solution, which I [not so] humbly call "The Ultimate GoPro Support for Laser sailboat", which in my view has many pros, compared to the other solutions:it is cheap, very cheap;it is small (it can be transported in your sports bag);it is small (it creates little to zero interference with other boats);it takes less than five minutes to install (the first time);it takes less than two minutes to mount/dismount;it is super simple and quick to 3D-print ! (anyone with basic 3D printing skills can do it)It does not obstruct the rudder/tiller movements (obviously), but the main sheet may get tangled in the mount/camera when gybing clumsly.(which is the only significative problem I have registered so far, for solving which I would very much appreciate any suggestion)======================DRAWINGSMy drawings are parametric, drafted with OnShape.They are all public, available here, accessible even by those who do not have an OnShape account.The main parameters of each part may be adjusted as required (even by those who do not have any 3D drawing skills), using either metric or imperial units.See relevant screenshot, which I have included within the thing's images.(If there is a parameter that you want to modify, but is not listed, just drop me a comment and I will add it as soon as I can.)To save the STL of any of the support Parts, access the Export command from the context menu on that Part's tab (right click on the tab, then select Export...), and specify "STL" as Format - no need to change other parameters.======================LIST OF MATERIALS40 cm (15 3/4") x PVC electrical conduit, 16 mm (or 3/4") diameter6 cm (2 1/2") x PVC electrical conduit, 16 mm (or 3/4") diameter2.5 m (8 ft) x string, 2mm diameter2 x M5xL30 stainless steel hexagonal bolt (in the US, a #10 x 1 1/4" bolt should work)2 x M5 stainless steel nut (in the US, a #10 nut should work)1 x rubber cap (chair leg caps or ferrules will do the job)25 cm2 (4 sq in) x double-sided tape (it must be strong !!! **) 18 m (circa 50 g) 3D printing filament (I used PLA, but ABS and PETG should be fine too)The total cost of materials (without double-sided tape), should be around 5.50-7.00 euros/bucks** TO NOTE : the double-sided tape must be of extra good quality. I tested several different (budget) tapes and they simply don't do the job. I strongly recommend using the 3M VHB 5259 or similar 3M VHB, 19mm width, which works perfectly. It is a bit expensive though (I paid 10 euros for 3 m on Amazon), but it is worth the investment. And you'll still have 2,90 m afterwards... :-) ======================3D PRINTING RECOMMENDATIONImportant !!!It is crucial that all "GoPro links" are printed with the hole axis normal to the hotbed.I.e.: the "Transom_plate" shall be printed vertically !I know, it is not ideal for a flat thing, but that is the only way to allow the link to be sufficiently strong !The "Y-link" shall be flat on the hotbed.Se relevant image as a reference for the printing orientation of each part. (Print each part separately, though)I used brim to enhance built plate (hotbed) adhesion. It is nice to have, especially when printing the transom plate.The three parts showing a GoPro link shall be printed with "supports everywhere" enabled (or equivalent) ======================MOUNTING INSTRUCTIONSWhen I will have time, I will write down some instructionsFor the time being, I ask you to be patient and refer to the images that I am attaching here.They are pretty much self-explanatoryTO NOTE: the "collar" should be fixed closer to the camera than what it shows in the photos. I believe that 1 inch (2.5 cm) from the camera should work better than in my example ======================CLASS RULESLet me spend a couple of words about Laser Class rules...Is my "Ultimate GoPro support" Class compliant ?I am pretty sure it is, but I'm not 100% sure.Indeed, since January 2017, the ILCA has introduced Class Rule 28, to allow boat or body mounted cameras.I quote from the 2020 edition of the Rules: "One camera may be attached to the sailor or may be mounted on the boat if the hull cavity is not pierced by anything other than the fasteners"I'm a bit worried, (but just a tiny bit) by those two strings tied onto the traveller fairleads. That's it.Anyway, I would never race with this mount attached to the transom of my boat ! So... problem solved ;-)
        LSV - BARCO KAU-BÉ.
        MMSI: 261000743
          SOPORTE BEBIDAS TUBO 25mm Rail mounted cup/can holder for boats
          A dual cup, mug or can holder for 25 mm rails on boatsThe inner part is divided in two sections so both cups and cans will fit.This one will only work on horizontal rails.
          LSV - BARCO KAU-BÉ.
          MMSI: 261000743
            Hola, he visto esto, LSV, crees que sobre dimensionándolo, podría utilizarse para cabos de 6 m/m. La idea seria utilizarlo para mover pequeños pesos, (bajar el auxiliar al chinchorro, unos 20 Kg)?
            https://www.thingiverse.com/thing:3691281 https://www.thingiverse.com/thing:3691483
            Agradezco y mucho, todos los diseños que estas aportando.
            Salud
              Creo que con los tornillos de acero, haciéndolo con una densidad alta (70-80) y con PETG cómo mínimo, podría aguantar esos 20 kg, sobre todo si le pones uno a proa y otro a popa, lo que repartiría el peso entre los dos.
              Si lo tuviera que hacer haría varias ruedas interiores de la polea como repuesto, pues es lo que más sufrirá y reforzaría el agujero superior, de donde se cuelga, haciéndolo lo más pequeño posible para engrosar las paredes. O ponerle un trozo de tubo de metal dentro que se adapte al agujero.
              Otra mejora sería ponerle unos cojinetes en el interior de las ruedas interiores, en lugar de todo plástico.
              LSV - BARCO KAU-BÉ.
              MMSI: 261000743
                Algo intermedio con estas ruedas:
                POLEA CON COJINETE (ESCALABLE)
                LSV - BARCO KAU-BÉ.
                MMSI: 261000743
                  ALARGADOR CARRIL MAYOR Harken Battcar "A" 22mm rail supplement
                  Needed 20 cm to get closer to the boom so the sail is easier to cover when unused.The added portion of rail is not subjected to any high loads so polymer should be OK.The rail includes holes for standard hex nuts.Both parts printed properly without support.Files are STL, STEP AP203 and Solidworks 2013
                  LSV - BARCO KAU-BÉ.
                  MMSI: 261000743
                    TUERCA TAPA CONEXIÓN For comm cables on ePropulsion outboard motors
                    End cap with 7/16-28 UNEF thread for Amphenol Ceres Mini Size connector for comm cables on ePropulsion outboard motors | Descargar modelos STL imprimibles en 3D gratuitos
                    LSV - BARCO KAU-BÉ.
                    MMSI: 261000743
                      PLANCHA CAVITACIÓN Cavitation Plate for ePropulsion Spirit
                      LSV - BARCO KAU-BÉ.
                      MMSI: 261000743
                        SOPORTE MESA Table support bottom ring for Hunter sailboat
                        For a Hunter sailboat with a cabin table supported by a 2" compression pole. It is split so you can replace it without removing the pole from the boat. Accepts a 1/2" cross rod that goes through the compression pole.
                        LSV - BARCO KAU-BÉ.
                        MMSI: 261000743
                          CIERRE Optimist bow lock
                          Optimist bow lock helps prevent the boat tipping or sliding back off of the trolley.
                          LSV - BARCO KAU-BÉ.
                          MMSI: 261000743
                            BLOQUEO DIRECCIÓN FB Marine Outboard Engine Steer-Stop Steering Lock
                            I made this Steer-Stop Steering Lock for my yamaha 150 outboard engine.Size isHeight 104mmInside radius is 19mm
                            LSV - BARCO KAU-BÉ.
                            MMSI: 261000743
                              CONECTOR Baofeng UV-5R replacement Kenwood plug
                              All what you need to replace the plug are:2.5mm stereo audio plug3.5mm stereo audio plug4 wires cablesolderingrosintinheat shrinkglue gun
                              LSV - BARCO KAU-BÉ.
                              MMSI: 261000743
                                CARBURADOR CUBETA British Seagull Villiers Float Bowl
                                This is a float bowl for a Villiers carburettor on a British Seagull outboard motor. I'd suggest printing with PLA at 100% infill and with the open side upwards, which should give the threaded internal section some support. It should just screw on if the print is good. Can't say about the fuel resistance of PLA, but from what I've read it should be OK for emergencies!
                                LSV - BARCO KAU-BÉ.
                                MMSI: 261000743
