    He encontrado por la foto el producto con medidas, pero supongo que como la tuya, sin fichero imprimible.
    Voy a buscar algo por ahí mientras tu acabas el tuyo.
    LSV - BARCO KAU-BÉ.
    MMSI: 261000743
    VER Mi canal en YOUTUBE
    VER TODOS MIS DISEÑOS 3D
      PESCA LLAVERO Articulated Fish
      LSV - BARCO KAU-BÉ.
      MMSI: 261000743
        BATERIAS BaoFeng BL-5 (UV-5R, UV-5X3, BF-F8HP) Battery Template
        BaoFeng BL-5 Battery template (.step)This is a template, not the final thing you should print.This shape of battery should fit BaoFeng UV-5R, UV-5X3, BF-F8HP radios.Share your derivates and remixes in comments and in BaoFeng group Press [WATCH] button to be informed about changesImport provided STEP file and customize it in your favourite editor.⚠ Contact plates are included in this model. Keep in mind to extrude-cut some space for your metal contacts⚠ This model is a template for customizing. Do not use STL file included.⚠ This model was successfully printed in PETG and tested for fitness on my desktop, but never tested in real world operation.The author and the materials provided are not related and are not supported by either BaoFeng or its affiliates.STL file is included only due to Thingiverse limitationsAll materials provided are licensed under CC BY-NC-SA license.BaoFeng is registered trademark of BaoFeng Tech, SD, USA.
        Editado por última vez por LSV; 30/03/2024, 15:58:08.
        LSV - BARCO KAU-BÉ.
        MMSI: 261000743
          Tapa para instrumentos Raymarine ST60+.
          Sólo encontraba modelos imprimibles para la serie ST60, no para la ST60+, que es muy parecida pero con ligeras diferencias, especialmente en su parte inferior.
          Así que tuve que diseñar yo mismo el modelo. Aquí os lo dejo, espero que a alguien le resulte de utilidad:
          https://www.printables.com/model/510...ne-st60-series
            LSV - BARCO KAU-BÉ.
            MMSI: 261000743
              LLAVE DESMONTAR VÁLVULA DE INFLABLE.
              6 Tooth Slots Air Valve Tool Wrench Inflatable Boat Kayak Paddle Board Kite
              6 slot valve removal tool suitable forkiteskayaksinflatable boardssupetcLE:Added a stronger version with a handle for valves that at harder to take out
              Editado por última vez por LSV; 30/03/2024, 16:03:11.
              LSV - BARCO KAU-BÉ.
              MMSI: 261000743
                LLAVE FILTRO YB-ACC04-1 6P3-WS24A Filter cups Fits Yamaha 4 Stroke fuel filters from F150 to F350 and Suzuki models similiar
                YB-ACC04-1 6P3-WS24A Filter cups Fits Yamaha 4 Stroke fuel filters from F150 to F350 and Suzuki models similiar | Descargar modelos STL imprimibles en 3D gratuitos
                LSV - BARCO KAU-BÉ.
                MMSI: 261000743
                  Estoy haciendo las etiquetas para el panel de interruptores, es un poco pesadito y repetitivo, pero ya tengo 4.
                  Esta es una de las pruebas que he hecho.
                  Grosor 1mm +-
                  Mañana las pondré aquí.
                  LSV - BARCO KAU-BÉ.
                  MMSI: 261000743
                    Llave para filtro VETUS
                    this is a simple spanner for a VETUS waterfilter 330 type. the revision typ is a bit sturdier.
                    Editado por última vez por bacilococo; 23/06/2023, 21:18:18.
                    EA4YV
                      Originalmente publicado por bacilococo Ver Mensaje
                      GRACIAS, AÑADO FOTO:
                      LSV - BARCO KAU-BÉ.
                      MMSI: 261000743
                        1º GRUPO ROTULOS ETIQUETAS PANEL INTERRUPTORES barco sail boat
                        Son para este tipo de panel :
                        LSV - BARCO KAU-BÉ.
                        MMSI: 261000743
                          Originalmente publicado por Nas Ver Mensaje
                          Gracias cofrade, me viene de perlas. Bien te mereces unas birras bien frias.p
                          Ya que estoy... ¿No tendrá localizado alguien el fichero de impresión para un Autohelm Bidata (sonda y corredera)?
                          Me he revisado el hilo completo, y salvo error o omisión, no lo he encontrado.
                          Birras a mi cuenta.
                            Originalmente publicado por inhaqui Ver Mensaje
                            Birras a mi cuenta.
                            A ver si encuentras la foto en internet y podemos sacar las medidas y el diseño.
                            ¿Puede ser este?
                            LSV - BARCO KAU-BÉ.
                            MMSI: 261000743
                              Ya tengo preparado el fichero de una tapa para ese de la foto, pero con medidas aproximadas porque no tengo el grosor de las pardes y otros datos.
                              Cuando las tenga alguien si me las facilita podré colgarlo.
                              No es una tapa complicada.
                              LSV - BARCO KAU-BÉ.
                              MMSI: 261000743
                                TAPA ESCAPE VETUS Replacement part for Vetus TRC100SV - stainless steel transom exhaust connection 4"
                                Editado por última vez por LSV; 30/03/2024, 16:08:46.
                                LSV - BARCO KAU-BÉ.
                                MMSI: 261000743
