    CIERRE PATINES MÁSTIL Maxi 77 sail blocker
    This is to prevent the clamps holding the main connected to the mast from getting loose.Two versions:Non adjustable - two 4 mm holes Adjustable - longer 4 mm holes for adjusting star or portside after mouting. (Useful when you need to take off the sail, no need for unmounting, just loosen the screws)
    LSV - BARCO KAU-BÉ.
    MMSI: 261000743
    VER Mi canal en YOUTUBE
    VER TODOS MIS DISEÑOS 3D
      CHUMACERA REMOS DESCATALOGADA Old style Bombard oar holder (rare design, not produced anymore)
      Design by Printable Concrete, pictures taken on site at Budapest StudiosOld style paddle holder for older Bombard inflatable dinghy boat. This is a drop in replacement for the older style Bombard oar holder, but is designed to be much stronger. The original piece is injection molded and only around 1,5 mm thick. This replacement part is 6 mm tick and has an integrated M4 stainless bolt in the stem for added strength, as the part is prone to split at the stem and the ring shaped section.Part list:1 piece of stainless steel M4 bolt with hexagonal head, 40 mm long threaded section and 43 mm length over all2 pieces of washer with an outside diameter of 11.5 mm1 piece of M4 nutPrintingIt is best to use a more tougher material as PLA as this part is structural and is subject to great loads while paddling. A good choice would be PETG or tough PLA. Nylon would be great as well but could be a challenge to print as the part requires support under the stem.100% concentric infill, a high flow multiplier ratio and high temperatures paired with slower printing will make the part stronger.Post processingRemove the support, file blobs, insert the M4 bolt with washers and a nut, and tighten the nut.
      LSV - BARCO KAU-BÉ.
      MMSI: 261000743
        BICHERO PLANO Boat Hook (Flat Print)
        Quickie design I did to up-cycle some aluminum tubing.Tube specs: 17mm I.D., 18.5mm O.D.Use #8 or M4 screws.After-Use ReviewIn Canadian: "Works not bad!" which is our way of saying "works well". Took it on a trip that included a couple lockages and it performed it's duty admirably, if I did wish the tube was a little longer.We'll see how it weathers in the boat this summer."1000 Mile" ReviewWorks so well I made another for a friend :) . Came in might handy during an on-the-water emergency rescue. I won't be without one again!(Lots of users have downloaded it for holiday decoration, presumably to help them string the lights in hard to reach places, so I added the tags for that too).Check Out My Other Project!Cool cups, mugs & chalices: here!
        LSV - BARCO KAU-BÉ.
        MMSI: 261000743
          IDEA PARA BARCO Air vents Aérateurs Citroen Jumpy Peugeot Expert Fiat Scudo
          LSV - BARCO KAU-BÉ.
          MMSI: 261000743
            Tabla de surf impresa en 3D
            Thank you for downloading my files. I hope your board is gonna work just as good as mine. For more photos or how it performs please check out my online photo album or video under:https://youtu.be/tZFrTXWy1x0 and https://www.flickr.com/gp/135755515@N07/27C2HwPeace,Michel(any questions about the building process contact me: mzeller97@gmail.com)My whole final paper is now online and available under: https://doc.co/1EhyArIt contains many improvements I have made during the production of two printed surfboards which you might consider when printing your own :)
            LSV - BARCO KAU-BÉ.
            MMSI: 261000743
              OJO A LAS NORMATIVAS LEGALES Survival Fishing X-Bow
              LSV - BARCO KAU-BÉ.
              MMSI: 261000743
                Hola, has visto algún modelo de soporte para prismáticos en 3D, parecido a este?
                  No encuentro ninguno parecido, así que estoy diseñando este:
                  Si lleva compás no sé si cabrá.
                  (A ver si las medidas te valen y de paso dime cómo lo vas a sujetar, a tubo, dime el diámtro, o a la pared, para diseñar el enganche).
                  LSV - BARCO KAU-BÉ.
                  MMSI: 261000743
                  • Reunir ficheros impresión 3d barco
                    Hola, sería para fijarlo a pared, el diámetro lo puedo medir esta semana, es para unos prismáticos Plastimo 7x50 que tengo en el barco.
                    Tiene muy buena pinta, gracias.
                      Las medidas del soporte que te envié la foto son 230x120x85 mm
                        Y aquí este que diseñé hace tiempo.
                        En este cabe con compás.
                        SOPORTE FUNDA PRISMÁTICOS BOX SUPPORT BINOCULAR
                        LSV - BARCO KAU-BÉ.
                        MMSI: 261000743
                          Originalmente publicado por anca Ver Mensaje
                          Las medidas que yo te pongo son las interiores para un 7*50 como el amarillo y negro de la foto.
                          LSV - BARCO KAU-BÉ.
                          MMSI: 261000743
                            Perfecto, lo voy a medir con el que tengo en el barco.
                              Hola a todos.... flipo con este hilo! me habéis convencido de comprar una impresora! Espero que no os moleste si pregunto en este hilo que opináis sobre esta impresora:
                              Kingroon KLP1 is a high speed 3D printer at affordable price. With 230x230x210mm build volume, this core xy printer can print more big objets than others.
                              gracias!
                                SOPORTE binoculars holder
                                LSV - BARCO KAU-BÉ.
                                MMSI: 261000743
