    Originalmente publicado por Alex Ver Mensaje
    Así es... esa es la pieza... más que esfuerzo, soporta mucha fricción pues la pestaña se acopla en el cilindro central del winch, por lo que ademas de soportar el peso del cilindro de inox, tiene rozamiento con este cuando gira con la manivela (uso un taladro eléctrico como manivela eléctrica)
    Pues con el Delrim podría ir bien. En el hilo de "Deslizadores tapa tambucho entrada" comentan que esos deslizadores son de Delrim.
    Editado por última vez por LSV; 04/04/2024, 00:18:52.
    LSV - BARCO KAU-BÉ.
    MMSI: 261000743
    VER Mi canal en YOUTUBE
    VER TODOS MIS DISEÑOS 3D
      POLEAS BEARING PULLEY PARACORD
      I had some extra 6001 bearings, so I figured I would try designing some medium duty pulleys. I sized the v-roller to fit 550 cord, and mine works flawlessly.I used 6001 bearings just because I had them on hand, but I also found a 10 pk for $10.40 on Amazon. 6001 bearing size: 12mm ID, 28mm OD, 8mm thick.For a single pulley Print 2 matching housings and 1 V-Roller for each pulley. For the Double pulley print 2 of housing 3, 2 of housing 4, and 2 of the V-RollersHardware:SINGLE PULLEY(3 or 5) #10-32 x 1" screws(3 or 5) #10 nuts(3 or 5) #10 lock washers(6 or 10) #10 washers(1) 6001 bearingDOUBLE PULLEY(5) #10-32 x 1-3/4" screws (I used 2")(5) #10 nuts(5) #10 lock washers(10) #10 washers(2) 6001 bearingsIf you are looking for any of the hardware I have an amazon shopping list here (all with prime shipping):https://www.amazon.com/hz/wishlist/ls/3STXTU1MNPO5P?ref_=wl_share&_encoding=UTF8&tag=maltvat-20&linkCode=ur2&linkId=cc242fb775a0915e69ac912bfe7ad0c1&camp=1789&creative=9325Disclaimer:Use this at your own risk. I cannot and will not offer you a load rating.UPDATE:11/24/2020: I uploaded a single pulley housing with 2 anchor points. It uses more hardware though.Uploaded a pulley housing without any anchor points. This one will be easier to make a double pulley out of. I have updated the hardware listed for both.Updated the V-Roller to a larger ID.
      LSV - BARCO KAU-BÉ.
      MMSI: 261000743
        Pues... no tanto...
        Esta es su respuesta y precio:
        "Hi Alex
        the collets price is = £ 16.8 each ( uk pounds )
        Delivery £10 to 12
        Regards Tony
        ps-- Due to the age of your winch :- 40st Service kit = £9.5 per winch ( Pawls, Pawl springs , Gear BEARINGS )"
        Videos
        Alex Sailing en Facebook
          Buenas tardes a todos...
          Una pregunta para vosotros, grandes diseñadores que plasmáis para poder imprimir vuestras creaciones en 3D, unas inventadas y otras copiadas pero que sacan de un gran apuro al no encontrar esos productos.
          Cual es el procedimiento si requiero de alguna pieza y no tengo impresora, hay un fichero que descargar y llevarlo a imprimir a algún lugar, hay algún servicio que le digas lo que necesitas y envias foto para que te lo remitan fabricado. Alguno de vosotros además de diseñar lo vendéis ya realizado?.
          He visto algunas piezas que me gustaría adquirir, por ejemplo el terminal Seatalk1 y alguna cosa más.
          Gracias a todos.
            No llego a encontrar un tapón para 1/4 de pulgada en vez de la de 1/2. Es posible encontrarla? Es la de Dehler
            Este es para 1 1/2 pulgadas. Una pulgada y media.
            ¿Tú necesitas de 1/4 de pulgada o 1 1/4. Una pulgada y cuarto.?
            Dime de que eslora y año es tu barco para mirando algo.
            Editado por última vez por LSV; 04/04/2024, 18:55:55.
            LSV - BARCO KAU-BÉ.
            MMSI: 261000743
              Mirando los tapones y los adaptadores para manguera me doy cuenta de que en realidad no hace falta que sean roscados.
              Con que entren 4-5 cm y con una holgura de 1 mm en el diámetro, con una forma ligeramente cónica ya deben quedarse en su sitio sin problema para el llenado, aunque queden flojos no deberían caerse sujetos con la manguera.
              Más rápido de poner y quitar y sin desgastes ni en el adaptador ni en la boca de llenado.
              Todo es cuestión de probarlo.
              Si alguien me dice el diámetro interno exacto de la boca de llenado o el diámetro exacto de tu tapón lo hago y lo pongo aquí.
              Haciendo la conversión a mm me sale: 1 /1/4 = 31,75mm.
              De momento voy a hacerlo con ese diámetro máximo, en espera de confirmación.
              Editado por última vez por LSV; 05/04/2024, 09:55:28.
              LSV - BARCO KAU-BÉ.
              MMSI: 261000743
                Originalmente publicado por PINGOL Ver Mensaje
                Gracias a todos.
                Lo más fácil es llevar el fichero STL a un servicio de impresión en una tarjeta o pendrive.
                O mandándolo por internet.
                Lo principal es decirles qué filamento necesitamos y que hagan un presupuesto con el fichero en su mano.
                Por ejemplo para el conector Seatalk yo lo haría con PETG que es el plástico de las botellas de refresco.
                Resitente, algo flexible y no se degrada fácilmente.
                Y el filamento depende del uso a darle.
                Editado por última vez por LSV; 04/04/2024, 21:21:49.
                LSV - BARCO KAU-BÉ.
                MMSI: 261000743
                  MIO- Aquí está el ADAPTADOR MANGUERA para DELHER 1-1/4.
                  (Falta que alguien lo compruebe).
                  LSV - BARCO KAU-BÉ.
                  MMSI: 261000743
                    Tremendo Lsv. No tiene rosca debe ser para los modelos mas modernos pero inventaré algo supongo.
                      Este modelo lo he hecho expresamente sin rosca y se supone que no la necesita.
                      Se debería ajustar como el tapon de corcho de una botella, solo a presión. De hecho no necesita ajustarse a presión, si no solo poner el cono en su sitio como si pusieras la punta de una pistola de riego.
                      Si las medidas son correctas la parte más ancha del cono debería ajustar exacta a la entrada.
                      Voy a hacer otra variante y le doy algo más de ancho que la entrada y tendrá la opción de apretarla a presión o dejarla floja.
                      Editado por última vez por LSV; 13/04/2024, 11:25:36.
                      LSV - BARCO KAU-BÉ.
                      MMSI: 261000743
                        Ya he cambiado las medidas del cono.
                        Está en el mismo enlace.
                        La versión actual es 4mm más gruesa, por lo que debe entrar a presión si se decide apretarlo o quedar floja si no se empuja.
                        LSV - BARCO KAU-BÉ.
                        MMSI: 261000743
                          SOPORTE DEFENSAS-BOTELLAS BUCEO SCUBA Tank bracket
                          A simple bulkhead mount bracket for SCUBA tanks with a 190 mm diameter. | Descargar modelos STL imprimibles en 3D gratuitos
                          LSV - BARCO KAU-BÉ.
                          MMSI: 261000743
                            CONECTOR MANGUERA LIMPIEZA Yamaha 15a outboard flush plate
                            Yamaha 15a outboard flush plate.Designed to connect your Gardena style garden hose to your motor for cooling.
                            LSV - BARCO KAU-BÉ.
                            MMSI: 261000743
                              MOLDE PARA TIMÓN U ORZA Mold for a carbon fiber IOM sailboat rudder
                              LSV - BARCO KAU-BÉ.
                              MMSI: 261000743
                                Lo tenía en espera para colgarlo aquí un día de estos.
                                Te agradezco que lo hayas puesto y lo amplío con la imagen visible.
                                Hola.
                                Me han pasado un presupuesto para este panel en PETG negro de 69 €.
                                Cómo lo veis?
