    POMO PERILLA Scuba Diving Tank Valve Knob
    This is a square drive knob that will fit most scuba Tank valvesPrinting: Can be any material you like my first try was in PETG 20% infill but I will try TPU and higher infill. I feel that water will get stuck inside when at various depths This works perfectly for my knob that broke off. Will make new designs and updates soon.Maybe one that TPU with a PTEG insert that way it can be used for other types of Valves.Update: TPU will need a PTEG or PLA insert so making another one that has a TPU shell.
    LSV - BARCO KAU-BÉ.
    MMSI: 261000743
    VER Mi canal en YOUTUBE
    VER TODOS MIS DISEÑOS 3D
      CAJA CONEXIONES Cable Box with Zip Ties , Screw mounts & Strain Relief
      HeyhoI was originally looking for a box to hide the cables behind my projector. Immediately afterwards, however, I also needed a smaller version for my ceiling light.With this version, you can simply push your cables through it and connect them inside or stow away other electronic components. If you do the latter, the recesses for cable ties help to keep things tidy!Different Versions:I have prepared 3 different sizes for you, each of which can be printed in one with high walls and one with lower walls for smaller connections.Mounting:You can use 4 x 3 mm wood screws to mount the box onto sth.strain relief:In addition to the box (and the lid), you will need 2 cable holders and 4 M3 x 10 mm screws. Choose the simple version for thick cables (approx. 10 mm diameter) and the one with a bulge for thinner cables (approx. 8 mm) to be able to exert more pressure. However, do not screw the brackets too tightly, otherwise the bracket or the cables could be damaged.In my case, I was also able to use the strain relief to minimize sagging of the cable on the ceiling.printing instructions:You shouldn't print the parts out of PLA so that the strain relief doesn't lose its meaning over time and due to the poor flame-retardant properties. PETGV0 (Prusa) or similar materials are certainly a better choice here!https://m.youtube.com/watch?v=L1DJqn2223M&t=3sIf you have any suggestions for improvement or other wishes, please feel free to make them in the comments!Have fun tinkering!A small disclaimer: Everything that has to do with electricity naturally always carries a residual risk if not done properly. So please only act with the necessary minimum of specialist knowledge!
      LSV - BARCO KAU-BÉ.
      MMSI: 261000743
        Repetido
        LSV - BARCO KAU-BÉ.
        MMSI: 261000743
          POLEA RESISTENTE Strong Pulley 100% 3D Printable, Scaleable & Durable
          HeyhoHere I have a completely 3D printable pulley for you!I recently designed an attachment for my clothesline (which also works great!) and of course the idea came up to simply use a pulley! Previous designs I found online always needed extra parts or didn't look very sturdy.So I designed my own solution and tested it for you!There are 3 different versions:1) Easy to print pulleyA quick printed version where there is only 1 main part. Due to the slightly thinner suspension, this version fits well into most hooks or can also be attached with a rope. The disadvantage is that it is less stable than the other versions due to the print orientation. Nevertheless, it is more than sufficient for most tasks!2) Stable pulleyThis version is particularly solid and can be printed even more stably thanks to the optimized alignment. After printing, simply put the 2 halves together with the small pin in the middle and after inserting the roller, the version is sufficiently stable.If you prefer, you can also put the two halves together with a little glue.3) Pulley for eyeletsThis version can also be used in combination with eyelets, where the two previous versions cannot simply be used. However, you must first assemble the individual parts on the eyelet.The halves should not be glued together! Unless you don't want to remove it from the eyelet!ScalabilitySince all 3 variants are completely 3D printed, you can also scale them "at will"! So make them bigger or smaller! But always keep an eye on the tolerances and the perimeters!Printing tips:You should use as many perimeters as possible (6 Perimeter should be enough with the given size). Infill at 100% brings the remaining stability. PLA is probably sufficient for short loads. For continuous loads, I would recommend PETG or other stable materials.Post processing:As the friction between the 2 parts of the roll naturally increases with higher loads, some oil must be added. I simply used some chain oil from my bike for this. To make it easier to add the oil, I constructed 2 small openings on each side of the wheel. Simply pour in some oil here, move the wheel back and forth a little and then remove any excess oil.Slicing Tips:If you are struggling with some parts you can separate them into single objects and scale them up/ down a little to get a perfect fit!Have fun!Small Tipp: You can separate all files into single objects with each slicer!
          LSV - BARCO KAU-BÉ.
          MMSI: 261000743
            FUERTE SOPORTE PARED Extra strong wall mounting
            Heyho :)This is part 1/3 of my DIY Canvas project.Part 2/3: Canvas Tensionerhttps://www.thingiverse.com/thing:6438871To make my projector screen as stable and "childproof" as possible, I stretched it onto a plywood panel (10 mm). I designed and printed various clamping and holding elements for this.Of course, this wall mount also works with other projects and impresses with its simple assembly and special stability.Stability:All parts are printed in such a way that even a weaker layer adhesion can be compensated.Use PETG or other tough material to get a long lasting and durable holder! (PLA could deofrm over time)Assembly: Up to 3 x M5 screws can be fixed in the wall for each large part. I have provided holes for up to 10 x M4 screws for the two other halves. (There are 2 Halves to get clean and strong prints without supports! Also you can adapt the tolerances a little later on).If you can use longer screws, you don't necessarily need to use all the holes. However, I only had M4 x 10 screws available for my thin wooden panel. However, the main force is absorbed by the fact that the bracket was attached under a wooden strip and the screws therefore hardly have to absorb any more force.It is up to you whether you want to use 1 bracket, 2 brackets or even more. One bracket would have been enough for my project. However, to make it extra childproof, I attached two brackets.The installation itself should be self-explanatory. If not, please let me know in the comments!
            LSV - BARCO KAU-BÉ.
            MMSI: 261000743
              VELA PARA kayak sailing rig parts
              update: it is never done! made the pivoting outriger base stronger. it no longer pivots but it should support a higher load. took some pictures of a larger sail set up. added a regular cleat that fits on 3/4th inch pvc pipe and a sheet guide eye for those that like or need organised sheets. i used 3/16ths braided nylon rope for the larger sail. i anchored the sail to the mast and boom with a series of half hitches and bowline knots (i also ran the rope through the pivot point conecting the two) then and the remander of the rope through the mast pully and back down through the loops made by the bowlines to the cleat.Update: added a final assembly file just to have a reference till i take more pictures. (good luck viewing the file on here) till then i'm going to call this done. comment if a part fails or you have suggestions, i might fix it! [insert "it_is_done".gif here]Update: rounded off a lot of edges (it just looks better to me) and added files for a way to attach the beam to the mast. both a solid and folding version.side note; 90% of the things i've made for this are designed to be attached with rope. the only places rope isn't used is where the holes have a chamfer instead of a fillet. though in many of those places you could just as easily use screws or bolts.update: finally got around to making a sailing clam cleat for the genoa so i can stop using my foot to pin the sheet against the molded depression.update: new sail base files better suited to a 90` angle mainsail without cracking but still allowing the mainsail to fold down. added channel to the bottom of the sail base for those of you that don't have it molded into your water craft. i've been using 3/4" pvc so that's what i've been designing around.Update: new files for a main sail pully to allow the main sail to reef, a sort of removable outrigger mount that needs teasting still, and an edited version of the sail mount better suited to being rope mounted. making a new sail from a stronger material.Update: added a Genoa and edited the sail much faster sailing despite being only 15lbs away from the weight limit on my kayak. Next step, close hulled outrigers to pick the yak up out of the water a bit and keel boards to stop it from drifting sideways so much. Mounting plate and folding outriger mounts on hold till I have access to a 3D printer once again.recently decided to attach a sail to my CK 100 kayak. i wanted a sail that would fold down or fit in the molded depression if need be so i had to design a sail foot that would allow that. then i needed pully's and found a great soft mount design by https://www.thingiverse.com/Printerforever but the maker bot Z18 didn't recognize the file so i had to make my own which needs to be sanded on the edge a smidge to get the friction fit shaft to fit (I printed mine at 50% scale). I'm using the rope tensioner by https://www.thingiverse.com/WRonX to adjust the sheets when needed. im also using the cord holder by https://www.thingiverse.com/mistertech to hold the sail up. finally i'm using 6 mm thick plywood to mount everything in place and ratcheting it all down with some spare cloths line and a taut-line hitch. this isn't an entirely necessary step as the sail foot is strong enugh to be mounted to your kayak with just rope as seen above. the sail pictured is just a temp to make sure it all works properly.
              LSV - BARCO KAU-BÉ.
              MMSI: 261000743
                Repuesto escotilla Lewmar Hatch Friction Arm
                Friction hinge suffers from age and will break. The first design was one of nmy first ventures into 3D printing and was a bit frail. Also bent over time. so beefed up the second one and at the time of publication have not installed it.
                Editado por última vez por LSV; 14/03/2024, 22:29:34.
                LSV - BARCO KAU-BÉ.
                MMSI: 261000743
                  CIERRE TAMBUCHO ESCOTILLA Lewmar Hatch Compatible Locking Lever
                  LSV - BARCO KAU-BÉ.
                  MMSI: 261000743
                    MAPA IBIZA + FORMENTERA
                    LSV - BARCO KAU-BÉ.
                    MMSI: 261000743
                      GANCHO Cargo hook with quick release
                      It can be released from a remote position. The force needed for releasing is verry small and independent from the load! | Descargar modelos STL imprimibles en 3D gratuitos
                      LSV - BARCO KAU-BÉ.
                      MMSI: 261000743
                        CAJA ALMACENAMIENTO Bayliner 175XT storing case
                        Replacement storing case | Descargar modelos STL imprimibles en 3D gratuitos
                        LSV - BARCO KAU-BÉ.
                        MMSI: 261000743
                          Reten del acelerador Volvo Penta Throttle Retainer - PN 3852019
                          The throttle cable retainer clip for my 2003 Volvo Penta 3.0 GSP was was broken and causing power reduction at full throttle. The OEM part on eBay costs about $10 with shipping, but it will be a few days before it arrives. This simple make will suffice in the near term. Hopefully someone else here will find it useful.
                          LSV - BARCO KAU-BÉ.
                          MMSI: 261000743
                            TAPA Lowrance Hook 4/4x Cover Protective cap
                            LSV - BARCO KAU-BÉ.
                            MMSI: 261000743
                              INTERRUPTOR Boat Switch
                              LSV - BARCO KAU-BÉ.
                              MMSI: 261000743
                                CUBIERTA CON BISAGRA Cover with hinge for boat engine's panel
                                This is a cover to protect the engine's panel from sun and water sprays. It's size is for a small Volvo Penta MD2010 engine but can be suitable for MD2020, MD2030 and newer models. It's 22,5 cm wide.I printed it with the front cover touching the build plate. Supports only touching the build plate.Walls are 1mm wide so I used 3 perimeters to avoid infill. There will be a bit of infill in the base and in the transition between base and walls. Can be avoided adding more perimeters.THe hinge hole has the right diameter for a 1,75mm filament.
                                LSV - BARCO KAU-BÉ.
                                MMSI: 261000743
