    Las medidas máximas del panel son 19 X 13,58, así que, en principio, no debe ser problema hacerlo incluso con una impresora pequeña.
    Y podrías retocar el fichero poniendo los rótulos en castellano o añadir un logo con el nombre de tu barco
    LSV - BARCO KAU-BÉ.
    MMSI: 261000743
    VER Mi canal en YOUTUBE
    VER TODOS MIS DISEÑOS 3D
      CONSEJO IMPORTANTE PARA TODOS:
      NO SIEMPRE LOS FICHEROS VIENEN TOTALMENTE BIEN, LA MAYOR PARTE SON HECHOS POR AFICIONADOS.
      ASÍ QUE ANTES DE HACER UNA PIEZA GRANDE COMO ESTA Y ARRIESGAR TIEMPO Y DINERO OS ACONSEJO:
      QUE TOMÉIS LAS MEDIDAS DEL FICHERO DE LA PIEZA Y HAGÁIS UN PATRÓN EN PAPEL O CARTÓN MUY EXACTO, POR EJEMPLO DE LA SUPERFICIE ENTERA DONDE VAN LOS RÓTULOS Y LUEGO PRESENTÉIS ESTE PATRÓN EN DONDE IRÁ DEFINITIVO.
      ASÍ LAS PEQUEÑAS DIFERENCIAS POSIBLES PUEDEN SER CORREGIDAS O MEJORADAS.
      SI TENÉIS IMPRESORA PODÉIS IMPRIMIR ESA SUPERFICIE COMO PATRÓN DE UN PAR DE mm DE GROSOR, EN MATERIAL "MALO" (PLA), ANTES DE HACER EL DEFINITIVO EN PETG O ASA.
      Editado por última vez por LSV; 01/03/2024, 11:11:00.
      LSV - BARCO KAU-BÉ.
      MMSI: 261000743
        DECORACIÓN ESCAFANDRA BUZO (A ver quién se anima)
        The printed components I used to make a costume of a MK.V US Navy diving helmet for a Hallowe'en party. The helmet itself (the dome and collar piece) was EVA foam. Best option is to paint the whole thing copper colour, then brush paint the seams with silver to simulate the soldering. I used a reflective tinting film on the windows to make it spookier. It'll need some nuts and bolts to make the hinges and to look authentic. A big wingnut for the front window is good as well, but I didn't have time to find one. I used the adjustment knob on the front to adjust a speed controller for an internal fan, pumping air in through the two hose connectors at the rear to keep myself from suffocating. It gets very stuffy inside, and ventilation is definitely needed. Don't build this without active ventilation!The main head dome is 270mm in outside diameter, and the neck connection is about 220mm diameter. I've included a .STEP file of my original drawing, and a pair of .STL files of the dome and collar, but these are untested and I can't vouch for them.I have also quickly created a DXF foam pattern for the EVA foam. When I made mine I did it more or less by eye, so I can't say this pattern is perfect, but it should be a good jumping off point. Use contact adhesive, and good luck!
        LSV - BARCO KAU-BÉ.
        MMSI: 261000743
          Lo tenía en espera para colgarlo aquí un día de estos.
          Te agradezco que lo hayas puesto y lo amplío con la imagen visible.
          Ojo porque el autor de este panel ya advierte de que lo ha hecho un poco más largo que el original, para que no le coincidieran los taladros antiguos que ya tenía el casco.
            Originalmente publicado por Alatul Ver Mensaje
            Muchas gracias por la información. No la había leido, justifica más aún el comentario sobre probar antes de hacer la pieza definitiva.
            Editado por última vez por LSV; 02/03/2024, 11:07:38.
            LSV - BARCO KAU-BÉ.
            MMSI: 261000743
              GoPro Scuba Mask Mount
              This is a mount to attach a GoPro camera to a scuba diving mask. None of the included mounts worked well for this purpose so I created my own! Gotta love 3D Printing!
              LSV - BARCO KAU-BÉ.
              MMSI: 261000743
                CARCASA RAYMARINE ST-40 BOX SIN ACABAR
                LSV - BARCO KAU-BÉ.
                MMSI: 261000743
                  BASE Velcro Strap Holder
                  Yesturday I helped a good friend to improve his Camper.Therefore I printed some Velcro holders to mount the Solar Panel & its Cable securely to a wall. The holders are for different widths of velcro and very strong. (I hang myself onto them as a test :D)There are 3 different sizes. Small: For Velcro Bands up to 14 mm width.Medium: For Velcro Bands up to 22 mm width.Large: For Velcro Bands up to 30 mm width.To mount the holder I recommend using 3,5 mm wooden screws. Always make sure not to not to overdo it when tightening the screws.In the Car I used ASA Filament, 0,3mm layer Height, 0,6 mm Nozzle, 3 Perimeter & 25% infill. Annother feature of this design is that the excess cable can be put in between the holder and the wall. So it will not open accidentally and look a lot cleaner. You also may take a very long strap and cycle it around several times this way.Also the design is not only designed for cable management but can also withstand heavier tasks like storing tools.Have fun and keep printin!BTW: I designed other holders too for the electricity that I will release soon.
                  LSV - BARCO KAU-BÉ.
                  MMSI: 261000743
                    SOPORTES Y MARCO Rail mount and frame for flexible solar panel
                    For mounting a flexible solar panel on a 1" tube that is part of the stanchion and lifeline system of a sailboat | Descargar modelos STL imprimibles en 3D gratuitos
                    LSV - BARCO KAU-BÉ.
                    MMSI: 261000743
                      VOLVO PENTA Engine control box
                      It was required to replace my Volvo Penta electronic engine box. The original box was way too expensive for me for this simple thing.I decided to build my own. It can be a simple electonic logic board, or up to an advanced board with Arduino nano on board, with build in web server and super bright LED`sFor example,I created a board with additional engine run time, start cycle and fault event counter .There are differnt design versions, so you can choose the one that will fit your needs.Best print results for me was to position the box flat on build plate.
                      LSV - BARCO KAU-BÉ.
                      MMSI: 261000743
                        Hilo Equivocado
                        Editado por última vez por LSV; 06/03/2024, 22:57:58.
                        LSV - BARCO KAU-BÉ.
                        MMSI: 261000743
                          SOPORTE CAÑA TIMÓN 3rd hand for tiller extension
                          Sometimes you are missing a hand on an Archambault Surprise 25!This thing allows you to fix the tiller extension and the rudder in case you quickly have to do something else. It is screwed on top of the hinge of the hatch.The noses cramping the tiller extension tend to break away in case you lean the hatch against them - so careful. Printing with TX-CF20 or something similar helps.
                          LSV - BARCO KAU-BÉ.
                          MMSI: 261000743
                            TAPONES CONECTORES Lowrance Cable Connector Covers
                            LSV - BARCO KAU-BÉ.
                            MMSI: 261000743
                              TAPONES CONECTORES Lowrance HDS Connector Covers
                              LSV - BARCO KAU-BÉ.
                              MMSI: 261000743
                                MIO- MANETA POMO PUERTA PERKO V1 DOOR KNOB HANDLE
                                Me resulta incómodo el tirador metálico de la cerradura original.
                                Así que lo he quitado y superpongo mi añadido a presión.
                                Para el que no quiera quitar el tirador plateado estoy haciendo una versión que se superpone a todo, pero aún tengo que tomar alguna medida en el barco.
                                También pondré un fichero con la maneta más grande.
                                LSV - BARCO KAU-BÉ.
                                MMSI: 261000743
