    LSV... Menuda currada te estás dando...
      Te agradezco muuuucho tu comentario.
      Solo recordar que de las posibles 700 piezas colocadas solo unas 80 son diseño mío.
      El resto es de la comunidad mundial de gente generosa con su conocimiento.
      LSV - BARCO KAU-BÉ.
      MMSI: 261000743
      VER Mi canal en YOUTUBE
      VER TODOS MIS DISEÑOS 3D
        Al final me comprare la impresora 3D,
          Casco de buceo HighPoly con base
          LSV - BARCO KAU-BÉ.
          MMSI: 261000743
            TAPA REGISTRO Porthole / deck hatch
            A porthole/deck hatch for kayaks, boats and other similar uses. Has an opening of around 155mm diameter. The thread may be a bit stiff at first, but should free up with some use. Update 23/12/17: Increased tolerance a bit to allow for movement/warping of the outer frame when put into a deck. Also added the countersunk holes for into the base frame (oops :D). Added an indent into the handle to make it easier to undo.
            LSV - BARCO KAU-BÉ.
            MMSI: 261000743
              TAPA Volvo Penta panel sun cover protection
              LSV - BARCO KAU-BÉ.
              MMSI: 261000743
                CONECTOR LONAS PVC Sail connector
                Connectors for sail with a 4mm rope in the edge.Used 6mm Push-In clip:https://nl.aliexpress.com/item/32957503203.html
                LSV - BARCO KAU-BÉ.
                MMSI: 261000743
                  PIEZAS ARANDELA Volvo-Penta Part #854294
                  LSV - BARCO KAU-BÉ.
                  MMSI: 261000743
                    Volvo Penta Printable Part #826341
                    LSV - BARCO KAU-BÉ.
                    MMSI: 261000743
                      TAPA Lowrance HOOK2 7'' cover
                      LSV - BARCO KAU-BÉ.
                      MMSI: 261000743
                        VELA PARA kayak sailing rig parts
                        update: it is never done! made the pivoting outriger base stronger. it no longer pivots but it should support a higher load. took some pictures of a larger sail set up. added a regular cleat that fits on 3/4th inch pvc pipe and a sheet guide eye for those that like or need organised sheets. i used 3/16ths braided nylon rope for the larger sail. i anchored the sail to the mast and boom with a series of half hitches and bowline knots (i also ran the rope through the pivot point conecting the two) then and the remander of the rope through the mast pully and back down through the loops made by the bowlines to the cleat.Update: added a final assembly file just to have a reference till i take more pictures. (good luck viewing the file on here) till then i'm going to call this done. comment if a part fails or you have suggestions, i might fix it! [insert "it_is_done".gif here]Update: rounded off a lot of edges (it just looks better to me) and added files for a way to attach the beam to the mast. both a solid and folding version.side note; 90% of the things i've made for this are designed to be attached with rope. the only places rope isn't used is where the holes have a chamfer instead of a fillet. though in many of those places you could just as easily use screws or bolts.update: finally got around to making a sailing clam cleat for the genoa so i can stop using my foot to pin the sheet against the molded depression.update: new sail base files better suited to a 90` angle mainsail without cracking but still allowing the mainsail to fold down. added channel to the bottom of the sail base for those of you that don't have it molded into your water craft. i've been using 3/4" pvc so that's what i've been designing around.Update: new files for a main sail pully to allow the main sail to reef, a sort of removable outrigger mount that needs teasting still, and an edited version of the sail mount better suited to being rope mounted. making a new sail from a stronger material.Update: added a Genoa and edited the sail much faster sailing despite being only 15lbs away from the weight limit on my kayak. Next step, close hulled outrigers to pick the yak up out of the water a bit and keel boards to stop it from drifting sideways so much. Mounting plate and folding outriger mounts on hold till I have access to a 3D printer once again.recently decided to attach a sail to my CK 100 kayak. i wanted a sail that would fold down or fit in the molded depression if need be so i had to design a sail foot that would allow that. then i needed pully's and found a great soft mount design by https://www.thingiverse.com/Printerforever but the maker bot Z18 didn't recognize the file so i had to make my own which needs to be sanded on the edge a smidge to get the friction fit shaft to fit (I printed mine at 50% scale). I'm using the rope tensioner by https://www.thingiverse.com/WRonX to adjust the sheets when needed. im also using the cord holder by https://www.thingiverse.com/mistertech to hold the sail up. finally i'm using 6 mm thick plywood to mount everything in place and ratcheting it all down with some spare cloths line and a taut-line hitch. this isn't an entirely necessary step as the sail foot is strong enugh to be mounted to your kayak with just rope as seen above. the sail pictured is just a temp to make sure it all works properly.
                        LSV - BARCO KAU-BÉ.
                        MMSI: 261000743
                          MIO- 3D ISLA ES VEDRÁ BALEARES (IBIZA)
                          Editado por última vez por LSV; 01/04/2024, 10:21:27.
                          LSV - BARCO KAU-BÉ.
                          MMSI: 261000743
                            CONECTOR MANGUERA DESALINIZAR Yamaha flush hose and hose fitting to suit all models
                            Modeled from a Yamaha marine outboard flush hose adapter. I wanted one with a slightly longer shaft, and for a spare.The thread pitch was the hardest to replicate as it's not quite a standard thread (or at least in my Fusion 360 version). I tried every iteration in F360, BSP, inch, Metric and nothing fitted properly. The closest was Metric 27mm yet the only option was for a 2mm pitch. The measured thread pitch with my verniers was 2.2 and once scaled, and printed , the thread fitted at 2.2mm pitch.I created it use the 27mm x 2mm and then scaled Z direction only at 10% and it worksIt's prints in the vertical position, and doesn't need any supports due to everything beveled to create supporting overhangs. My PLA and ASA worked as well.
                            LSV - BARCO KAU-BÉ.
                            MMSI: 261000743
                              CONECTOR MANGUERA DESALINIZAR Flush adaptor for Mercury outboard motor
                              Adaptor for flushing fresh water in Mercury outboard boat motors. Thread fits with a standard European hose connector. A gasket can also be needed to make it waterthight. uses :- threads.scad from Dan Kirshner - dan_kirshner@yahoo.com must be in same directory. Link here https://dkprojects.net/openscad-threads/threads.scad Handle is from https://www.thingiverse.com/thing:1562501 Imported into this OpenSCAD as a STL file, so starKnob604024.stl must also be in the same directory.
                              LSV - BARCO KAU-BÉ.
                              MMSI: 261000743
                                Las cosas esas para colgar los cabos en bañera
                                En inglés le llaman line tamer
                                Mi versión imprimible:
                                Que es mi barco mi tesoro,
                                que es mi dios la libertad,
                                mi ley, la fuerza y el viento,
                                mi única patria, la mar.
                                https://www.facebook.com/pages/Juriola/214037382001173
                                Documentación y fotos de la construcción:
                                https://www.dropbox.com/sh/u7ktl11am...uOakJ4Y3a?dl=0
