    SOPORTE Baofeng UV-5R/F8HP Carabiner Clip
    I found a product like this from a small business a few years ago when I wasn't interested in radios. Now that I am using mine, I wanted to try the great idea I saw back then. After days of searching for the company, I decided to give up and create my own. If anyone knows of this company, please let me know. I want to purchase one since he gave me the idea!This should work with any radio that is 24mm from center to center of the screw holes. I made the ring to fit my LiteWire carabiner from Black Diamond, but it will also fit most carabiners you might want to use. I printed in TPU to allow a hold on the carabiner that does not let it move around on its own but easily moves intentionally.I learned some radios have shorter screws than mine, so I added a thin base version that should be okay to use, although I am not able to test it.This is great for clipping to a backpack, belt loop, or anything a carabiner can attach to. I clip mine to my backpack while hiking or somewhere out of the way when stationary.
    LSV - BARCO KAU-BÉ.
    MMSI: 261000743
    VER Mi canal en YOUTUBE
    VER TODOS MIS DISEÑOS 3D
      VENTILACIÓN Air vent, louver for Beneteau First 26
      Complete collection of air vents (3 models) in the companionway/cockpit area of Beneteau First 26 (1980s).Printing material PETG (240C/70C)
      LSV - BARCO KAU-BÉ.
      MMSI: 261000743
        Leopard 46 catamaran
        This is my boat. Not much small stuff for easy print. DETAILED VERSION IN REMIXES!
        1-
        2-
        Editado por última vez por LSV; 01/03/2025, 21:19:41.
        LSV - BARCO KAU-BÉ.
        MMSI: 261000743
          CAJA PARA CONECTORES RÁPIDOS Gehäuse für Kabelverbinder
          LSV - BARCO KAU-BÉ.
          MMSI: 261000743
            MIO- Beneteau 57 RETENES POPA STERN SEALS
            LSV - BARCO KAU-BÉ.
            MMSI: 261000743
              Genoa T-Track End Stop (25mm)
              Genoa track end stop for 25mm wide tracks, commonly used on sailboats around 25-30ft (e.g. Beneteau First 26)Print with UV and impact resistant materials (e.g. PETG, ASA) and high infill percentage.To be used with a 5mm flat head stainless steel screw. If needed, countersink to adjust the size of the hole to ensure the head of the screw is flush.Tags:Beneteau First 26, Genoa car, Genoa track, jib car, Sailboat, Sailing, T-Track end stop
              LSV - BARCO KAU-BÉ.
              MMSI: 261000743
                Sobremesa Raymarine ST60+ desk mount
                LSV - BARCO KAU-BÉ.
                MMSI: 261000743
                  MIO- ST60-ST6000 DECORACIÓN No los tires cuélgalos Don't throw them hang
                  O PONLOS SOBREMESA
                  LSV - BARCO KAU-BÉ.
                  MMSI: 261000743
                    Buenas tardes, y disculpad mi ignorancia en este asunto.
                    Estoy reemplazando los altavoces en un velero, los altavoces que monta son unos boss marine muy guapos, de 133 mm (5,5"), la cuestión es que hay 2 altavoces que están bien, pero que la parrilla está reventada.
                    Me podeis indicar unas pinceladas de qué tendría que hacer para adaptar alguno de los diseños que he visto por thingverse, para que sirvan para un altavoz de 5.5 pulgadas?
                    Luego ya sería cuestión de enviarlo a alguna empresa de las que hay online para que lo coticen e impriman.
                    ¿alguna recomendación sbore el material?, es para poner en la bañera, y por tanto están expuestos al sol y a las inclemencias.
                    Gracias.
                    Pedrolo.
                    https://www.youtube.com/@pmotilla --> canal con contenido variado, mecánica nautica, electrónica, y cosas varias.
                    https://pedrolo.com/ --> documento las reparaciones y cosas que hago, tanto para otros, como para mi propia consulta...
                      Estos son de 133mm según la web, ¿son así los tuyos? https://www.a-alvarez.com/51858-alta...ss-marine-150w
                      Si quieres imprimirlos lo mejor es el PETG, resistente a todo.
                      Si tienes conocimientos de CAD 3d podrías ajustar algún modelo de por ahí, pero suele ser más fácil hacerlo nuevo entero.
                      Si tienes fotos adecuadas puedes colgarlas aquí y puedo hacerte el fichero, como todos los de aquí gratis: perfil, superior, inferior, bien hechas sin deformaciones y con una cinta métrica o alguna medida al lado.
                      Las fotos han de ser algo así:
                      LSV - BARCO KAU-BÉ.
                      MMSI: 261000743
                        Igualmente, por muy parecidos que salgan no quedarán nunca "indistinguibles" de los otros ya que las líneas se notarán más o menos y el brillo tampo será igual.
                        Si los pones por separado que so se puedan comparar juntos "colarán" bien.
                        (Si no son muy complicados de diseñar).
                        LSV - BARCO KAU-BÉ.
                        MMSI: 261000743
                          Editado por última vez por LSV; 10/03/2025, 12:58:12.
                          LSV - BARCO KAU-BÉ.
                          MMSI: 261000743
                            Muchas gracias por el ofrecimiento. Es exactamente el último diseño que has puesto. La rejilla la tengo en el barco, pero si puedo esta semana me acercaré y sacaré fotos con medidas etc.
                            Si por temas laborales no me puedo acercar, el finde seguro que sí puedo, pero con la foto que mandas, ya es solo ajustar medidas, para asegurar que funciona bien.
                            Esto seguro que puede ayudar a otros cofrades, es una pena desechar altavoces tan buenos por algo tan absurdo.
                            Rondas para tí de la mejor destilería que haya...
                            En cuanto pueda paso por el pantalán.
                            Por cierto, hasta que he tropezado con este hilo, no he sido consciente del potencial de esta tecnología. Es realmente sorprendente.
                            Un saludo y muchas gracias.
                            Pedrolo.
                              Bien, pues esa última foto es de un diseño mío que ya tengo hecho.
                              No estoy seguro del todo de las medidas, ya que lo he sacado de un par de fotos.
                              Mañana lo tendrás colgado aquí para que te lo bajes y hagas alguna prueba.
                              Igualmente, antes de imprimirlo pon aquí las medidas de la distancia entre agujeros de los tornillos y su diámetro, yo he puesto 5 mm.
                              También la distancia de las bases de los tornillos al altavoz, es decir el grosor del altavoz que entra dentro de la tapa, para ajustar lo haga falta.
                              (Recuerda en PETG es más que suficiente y te saldrá a cuenta imprimir un par y tener uno como repuesto).
                              Si lo imprimes dime después qué tal encaja y puedes colgar una fotillo colocado.
                              Editado por última vez por LSV; 10/03/2025, 12:59:51.
                              LSV - BARCO KAU-BÉ.
                              MMSI: 261000743
                                Poninendo además una telilla negra fina pegada detrás te quedará precioso y protegerá del polvo y los salpicones.
                                LSV - BARCO KAU-BÉ.
                                MMSI: 261000743
