Veleros que aguantan el mal tiempo y los que nunca lo haran
  • Re: Veleros que aguantan el mal tiempo y los que nunca lo haran
    Intersantisimo hilo del cofrade Mariñel con video incluido. Vais a ver que pasa en caso de vuelco y vais a entender por que un barco debe ser seguro para que no pase eso
    Cedemont
      Farr 40 en tiempo duro
      Farr es Farr
      Cedemont
        Swan 45 en tiempo duro hacia Bermudas
        Swan es Swan
        Cedemont
          Fornells(Menorca) en invierno
          El mal tiempo se pilla en todos sitios
          Cedemont
            Aqui teneis algo que os va a gustar:
            NEPTUN 32
            INPUT
            Lh = 9,60 m
            Lwl = 7,50 m
            Bmax = 3,00 m
            Bwl = 2,70 m (?)
            Draught T = 1,60 m
            Body draught Tc = 0,50 m (?)
            Moulded depth H = 1,75 m (?)
            Disp = 3500 kg
            Ballast = 1500 kg
            Sail area = 40 m2
            Mast height = 11 m (?)
            Heeling Arm = 5,04 m (?)
            Power = 15 KW
            OUTPUT
            Length/Beam Ratio (2Lwl + Lh)/3B = 2,73
            Lwl/Bwl Ratio Lwl/Bwl = 2,78
            Ballast/Disp Ratio W/Disp = 0,43
            Displacement/Length Ratio D/L = 231,40
            Sail Area/Disp. Ratio SA/D = 11,46
            Power/ Disp. Ratio HP/D = 2,64 HP/ton
            Hull speed HSPD = 6,65 Kn
            Velocity Ratio VR = 0,98
            Capsize Safety Factor CSF = 1,99
            Motion Comfort Ratio MCR = 21,12
            Roll Period T = 2,18 Sec
            Roll Acceleration Acc = 0,15 G's
            Stability Index SI = 0,81
            Angle of Vanishing Stability AVS = 125 º
            Estimated STIX = +/- 37
            PUMA 34
            INPUT
            Lh = 10,35 m
            Lwl = 8,20 m
            Bmax = 3,35 m
            Bwl = 3,02 m
            Draught T = 1,85 m
            Body draught Tc = 0,63 m
            Disp = 5400 kg
            Ballast = 2400 kg
            Sail area = 55 m2 (WILD GUESS)
            Mast height = 15.5 m (WILD GUESS)
            Heeling Arm = 6.94 m (WILD GUESS)
            Power = 13,5 KW
            OUTPUT
            Length/Beam Ratio (2Lwl + Lh)/3B = 2,66
            Lwl/Bwl Ratio Lwl/Bwl = 2,72
            Length/Draught Ratio Lh/T = 5,59
            Beam/Draught Ratio Bmax/T = 1,81
            WL beam/Body draught Bwl/Tc = 4,79
            Ballast/Disp Ratio W/Disp = 0,44
            Displacement/Length Ratio D/L = 273,17
            Sail Area/Disp. Ratio SA/D = 18,16
            Sail Area/Wetted surface SA/WS = 2,43
            Power/ Disp. Ratio HP/D = 1,54 HP/ton
            Hull speed HSPD = 6,95 Kn
            Potential Maximum Speed PMS = 7,82 Kn
            Velocity Ratio VR = 1,13
            Best motoring speed (1.1) CSPD = 5,71 Kn
            Capsize Safety Factor CSF = 1,93
            Motion Comfort Ratio MCR = 25,85
            Roll Period T = 2,96 Sec
            Roll Acceleration Acc = 0,10 G's
            Stability Index SI = 0,88
            Angle of Vanishing Stability AVS = 126 º
            Dellenbaugh Angle DA = 24,06 º (14 kn wind)
            Wind pressure coefficient WPC = 0,88
            Estimated STIX 37,14
            HALLBERG RASSY 34
            INPUTS
            Loa = 10,28 m
            Lh = 10,28 m
            Lwl = 8,73 m
            Bmax = 3,42 m
            Bwl = 3,08 m
            Draught T = 1,85 m
            Body draught Tc = 0,67 m
            Moulded depth H = 1,48 m
            Disp = 5300 kg (lightship)
            Ballast = 2100 kg
            Sail area = 55 m2
            Mast height = 15,01 m
            Heeling Arm = 6,74 m
            Power = 21 KW
            OUTPUTS
            Length/Beam Ratio (2Lwl + Lh)/3B = 2,70
            Lwl/Bwl Ratio Lwl/Bwl = 2,84
            Length/Draught Ratio Lh/T = 5,56
            Beam/Draught Ratio Bmax/T = 1,85
            WL beam/Body draught Bwl/Tc = 4,59
            Ballast/Disp Ratio W/Disp = 0,40
            Displacement/Length Ratio D/L = 222,18
            Sail Area/Disp. Ratio SA/D = 18,39
            Sail Area/Wetted surface SA/WS = 2,30
            Power/ Disp. Ratio HP/D = 2,44 HP/ton
            Hull speed HSPD = 7,17 Kn
            Potential Maximum Speed = 8,11 Kn
            Best motoring speed (1.1) CSPD = 5,89 Kn
            Capsize Safety Factor CSF = 1,98
            Motion Comfort Ratio MCR = 23,74
            Roll Period T = 2,74 Sec
            Roll Acceleration Acc = 0,12 G's
            Stability Index SI = 0,80
            Angle of Vanishing Stability AVS = 124 º
            Dellenbaugh Angle DA = 19,53 º (14 kn wind)
            Wind pressure coefficient WPC = 1,08
            Estimated STIX 39,82
            FIRST 345
            INPUT
            Loa = 11,00 m
            Lh = 10,55 m
            Lwl = 9,08 m
            Bmax = 3,49 m
            Bwl = 3,14 m
            Draught T = 1,45 m
            Body draught Tc = 0,57 m
            Disp = 5700 kg
            Ballast = 2050 kg
            Sail area = 50,73 m2
            Heeling Arm = 6,58 m
            Power = 21 KW
            OUTPUTS
            Length/Beam Ratio (2Lwl + Lh)/3B = 2,74
            Lwl/Bwl Ratio Lwl/Bwl = 2,89
            Length/Draught Ratio Lh/T = 7,28
            Beam/Draught Ratio Bmax/T = 2,41
            WL beam/Body draught Bwl/Tc = 4,69
            Ballast/Disp Ratio W/Disp = 0,36
            Displacement/Length Ratio D/L = 212,37
            Sail Area/Disp. Ratio SA/D = 16,16
            Sail Area/Wetted surface SA/WS = 2,05
            Power/ Disp. Ratio HP/D = 2,27 HP/ton
            Hull speed HSPD = 7,31 Kn
            Potential Maximum Speed PMS = 7,90 Kn
            Velocity Ratio VR = 1,08
            Best motoring speed (1.1) CSPD = 6,00 Kn
            Capsize Safety Factor CSF = 1,97
            Motion Comfort Ratio MCR = 24,00
            Roll Period T = 2,78 Sec
            Angle of Vanishing Stability AVS = 120 º
            Dellenbaugh Angle DA = 16,13 º (14 kn wind)
            Wind pressure coefficient WPC = 1,31
            Estimated STIX 38,68
            Cedemont
              Sin comentarios, antes puse chiquitines y ahora pongo un cachalote...velero al alcanace de muy pocos...pero vaya barco...el Hallberg-Rassy 62
              En su vuelta al mundo
              Su STIX se acerca a 80
              Cedemont
                Es un Open Ocean de 60 pies, su STIX se acerca a 60, y no es mas porque le peneliza su bajo desplazamiento. Tiene un potentisimo par adrizante, y ademas, tiene orza pivotante.
                Mirad cuantos segundos tarda en adrizarse
                Ahora imaginaos lo que tarda un STIX al limite de la categoria A o por debajo de su eslora de flotacion si esta es mayor de 35 pies y sobre todo llegando a 40. Pensad que el video esta con el barco sin palo ni trapo, que impide todavia mas dar la vuelta
                Que nunca se queden con vosotros aquellos que quieran hacer grandes aventuras, no necesitan gastarse mucho dinero, pero si muchas horas een escoger el barco mas seguro para navegar , no para fondear ni para hacer regatas
                Cedemont
                  Y los ex-mini como el Archambault COCO, que tal? Se supone que son categoria B, no?. Auqnue no llevan tambucho estanco.
                    solo decirte una cosa , acojonas al personal y eso no esta muy bien , que aqui no existen tantas condiciones duras como tu dices , y por cierto preguntale al bahia de las islas , si ha tenido algun problema
                    y puesto a recomendar ..te recomiendo leas ,
                    la aventura del paradisse , un buen libro y ademas con un narrador excepcional
                    merece la pena
                    ah se me olvidaba ...en unos de tus videos tan bonitos ,con musia espectacular
                    creo que llevas un patin roto de la vela mayor...es posible o es una ilusion optica...
                    tengas un buen dia
                    www.pleamaruno.com
                      Son Cat B por su desplazamiento pero si superaran los 3000 kgs serian A. Para mi un Coco es A
                      Cedemont
                        Originalmente publicado por custodio Ver Mensaje
                        merece la pena
                        tengas un buen día
                        En absoluto trato de asustar a nadie, cofrade. Cada uno es mayorcito para escoger su velero ideal
                        Birritas
                        Cedemont
                          Originalmente publicado por Cedemont Ver Mensaje
                          Birritas
                          hay alguna diferencia¡¡¡¡¡¡¡¡ entre el velero IDEAL .....y el velero REAL ...compadre???
                          un saludo y que tengas una buena tarde
                          Editado por última vez por custodio; 26/05/2011, 15:56:45.
                          www.pleamaruno.com
                            Velero ideal: Aquel que te permite afrontar con seguridad la navegacion que quieres hacer. Hay cofrades que les gusta la Cat C, otros la B, y otros la A. Y otros que les gustan las regatas.
                            Pero no debes navegar en Cat A con un clase B, en B con un clase C, etc.
                            Velero Real: Dicese aquel que es de S.M El Rey o navega en nombre de S.M bajo su patronazgo
                            Cafetito
                            Cedemont
                              Cafetito
                              hablar contigo ... es no aprovechar el tiempo...
                              y es muy valioso...
                              diviertete
                              en las tabernas no hay cafecitos....
                              quiza sabes de todo mucho y de esto sepas menos
                              www.pleamaruno.com
                                De los 37 últimos mensajes, 22 de Nube gris.
                                59,45%
                                Si esto no es mantener afán de protagonismo...
                                Si, si, ya lo se, me voy a otro jardín...
                                Nunca de tan poco ha salido tanto. Felicidades
                                del bueno.
