Construcción Amateur
  • Re: Construcción Amateur
    Originalmente publicado por guillermogefaell Ver Mensaje
    Otros dos estupendos libros del mismo autor:
    Boat Strength for Builders, Designers and Owners
    "This work is significant. It is the first to include a method of assessing structural strength in the context of the modern marine environment." --Commander M. C. Cruder, U.S. Coast Guard Acclaimed author and naval architect Dave Gerr created this unique system of easy-to-use scantling rules and rules-of-thumb for calculating the necessary dimensions, or scantlings, of hulls, decks, and other boat parts, whether built of fiberglass, wood, wood-epoxy composite, steel, or aluminum. In addition to the rules themselves, The Elements of Boat Strength offers their context: an in-depth, plain-English discussion of boatbuilding materials, methods, and practices that will guide you through all aspects of boat construction. Now you can avoid wading through dense technical engineering manuals or tackling advanced mathematics. The Elements of Boat Strength has all the formulas, tables, illustrations, and charts you need to judge how heavy each piece of your boat should be in order to last and be safe. With this book, an inexpensive scientific calculator, and a pad of paper, you'll be able to design and specify all the components necessary to build a sound, long-lasting, rugged vessel. What reviewers have said about Dave Gerr's books: Propeller Handbook "By far the best book available on the subject."--Sailing "The best layman's guide we've ever read."--Practical Sailor Dave Gerr and International Marine made a complicated topic understandable and put it into a handbook that is easy to use."--WoodenBoat "Without doubt the definitive reference for selecting, installing, and understanding boat propellers."--Royal Navy Sailing Association Journal The Nature of Boats "If you are not nautically obsessed before reading this book, you will most certainly be afterward."--Sailing Fascinating potpourri of information about today's boats, modern and traditional."--WoodenBoat
    The Propeller Handbook
    http://books.google.es/books?id=8w09...page&q&f=false
    Me interesa el tema de élices!
    Tengo un pequeño fueraborda, y siempre he oído que es muy importante el paso y el diámetro de la élice para conseguir las prestaciones adecuadas. Después el problema es encontrar la élice deseada... voy a darle una mirada al libro, a ver que encuentro, ya que era uno de los temas de los que me tenía que ocupar en estas semanas. Muchas gracias
    "My boat is my island"
      hola Francisco,
      me alegra que pronto esté en el agua. Ya pasaré para ver como es el Micro al derecho (cuando lo ví estaba invertido...). Mis velas las hizo el Jaume de Velisa. Hace bastante tiempo que no se nada de él. Estaba en Premia de Dalt.
      Pere
        Originalmente publicado por PereCaracol Ver Mensaje
        hola Francisco,
        Pere
        Te quería preguntar por el velero, me viene bien que me lo recuerdes. Todos tus consejos han sido de utilidad! Muchas gracias... a ver si lo localizo.
        Te recuerdo mi mail para poder contactar directamente.
        astrolabio68@hotmail.com
          hola a todos-as y unas
          Encontre un libro gratis en Google sobre diseños americanos que hará las delicias a los aficionados de diseños "diferentes" (o los diferentes son los que se diseñan ahora...?): 100 Boat Designs Reviewed.
          Creo que está casi completo.
          Que lo disfruteis.
          http://books.google.es/books?id=TmoV...ed=0CEEQ6AEwBQ#
          Hola a todos, este libro lo podeis bajar completo y gratis aqui. Espero que os sea util.
          http://hotfile.com/dl/84286624/0bfbcdf/100_Boat_Designs_Reviewed.pdf.html
          http://www.filesonic.com/file/34581067/100_Boat_Designs_Reviewed.pdf
          Un saludo y unas
            hola Francisco,
            Pere
            Velisa ya no existe, pero Jaume sigue fabricando velas. Ya he contactado con él, y las primeras impresiones son muy positivas.
            Seguiremos informando
              Os presento un blog que puede que os interese, lo publica uno de los trabajadores de la Escola-Obradoiro Mar de Vigo, en esta escuela-taller llevan construídos una gamela, un galeón, una trainera, y algún otro barco, normalmente embarcaciones tradicionales y con técnicas propias de la carpintería de ribera. Aún está empezando, y tiene sólo un par de entradas, pero ya nos deja algunas fotos de la dorna de tope que están construyendo en estos momentos
              _
                Originalmente publicado por pinzote Ver Mensaje
                Aprovecho para abrir el hilo de la construcción amateur, mientras vemos qué pasa con lo que llevamos andado anteriormente.
                Os diré que estoy terminando la parte central de mi Sango. Falta terminar el techo, unir la cabina con la bañera y enmasillar, lijar, enmasillar, lijar, lijar, lijar...
                Unos tragos, que se me ha secado el gaznate de pensar en tanta lija.
                Hola pinzote como estas? Estoy mirando para construirme un barco de vela y veo que tu estas bien avanzado. Necesito consejo para la compra de materiales.
                pacharan fresco para todos que llega un nuevo pirata
                  Hola cofrade.
                  Acepto ese pacharán, aunque de fresco estoy servido...
                  Te mando privado
                  Pinzote
                    Saludos y birras a todos.
                    Despues de un inició lleno de mensajes, no es que haya desaparecido, pero estas setmanas las reparaciones de urgencia me han dejado agotado y despues de 10 horas de trabajo reparando barcos uno no tiene ganas de pensar en mas barcos aunque sea el suyo propio.
                    Ahora con un tiempo pasado estaba revisando mi diseño anterior y puede que sea necesario replantearse o al menos intentar conseguir algo mas sintetico, sencillo y funcional sin intentar ir siempre hacia las curvas clasicas.
                    Esta noche toca intentar dibujar algo de fondo plano o semiplano.
                    Ya os enseñare
                      Espero ansioso. Creo que los PDRACER o similares "evolucionados" tienen mucho que decir...
                      Originalmente publicado por antoniv Ver Mensaje
                      Ya os enseñare
                      Desde Navia, Asturias, navegando de prestado...
                        Hola, Antoniv!
                        Me alegro de volver a leerte. No te preocupes mucho por las interrupciones en tu proyecto, a veces son necesarias para reestructurar el pensamiento, tomar distancia y volver con fuerzas renovadas al cabo de un tiempo. Estaremos contentos de ver los dibujos que nos puedas enseñar.
                          Buenos dias a todos.
                          Os presento el resultado de ayer por la noche, como dice astrolabio, con algo mas de tiempo y prespectiva me permitio pensar en algunas simplificaciones a fin de facilitar la construcción.
                          Aquí el plano de formas.
                          Podeis ver que es un diseño con fondo casi plano y un pantoque mucho mas mascado, con un momento de adrizamiento inicial mucho mas elevado que el anterior diseño que era mucho mas redondo.
                          Con las opciones que tenia, he intentado unir y optimizar las ventajas frente a los requisitos de utilización. En ese sentido, el pantoque plano central sobre crugia tiene dos motivos importantes.
                          Uno es ofrecer una zona plana que facilita mucho el avaramiento en playa, almacenamiento en sego y manejo sobre el remolque. Todo esto con un fondo en UVE no lo conseguia.
                          El otro motivo es la simplificación en la construcción, aunque incorporamos una pieza mas, esta pieza plana sobre crugia es la primera que se monta y ejerce de espina vertebral de toda la estructura de mamparos y codillos para montar las otras dos tablas del casco, bueno yo me entiendo no se si me explico.
                          Me gustaria que los que entendeis me deis vuestra opinión, referente a como veis las características hidrodinamicas y de forma del casco. Como puede funcionar? Puede ser contraproduente tener el canto del pantoque superior bajo la linea de flotación?
                          Os pego los resultados del cálculo hidroniámico:
                          Código:
                          Eslora de trazado     :      5.300 m
                          Eslora total          :      5.291 m
                          Manga de trazado      :      1.760 m
                          Manga máxima          :      1.822 m
                          Calado de trazado     :      0.180 m
                          Posición Sccn. Media  :      2.648 m
                          Densidad del Agua     :      1.025 t/m3
                          Cfte. Apéndices       :     1.0000
                          Propiedades del Volumen:
                              Vol.:  Volumen desplazado                   :         0.585 m3
                              Dspl.: Desplazamiento                       :         0.600 tonnes
                              Lwl:   Eslora total del cuerpo sumergido    :         5.036 m
                              Bmáx:  Manga máxima del cuerpo sumergido    :         1.456 m
                              Cb:    Cfte. de Bloque                      :        0.4430
                              Cp:    Cfte. Prismático                     :        0.5784
                              Cpv:   Cfte. Prismático Vertical            :        0.6060
                              Sw:    Área de la superficie mojada         :         5.799 m2
                              LCB:   Pos.Long.Centro de Flotación         :         2.646 m
                              LCB:   Pos.Long.Centro de Flotación         :        -2.216 %
                              Centro de flotabilidad Transversal          :         0.000 m
                              KCB:   Pos.Vert.Centro de Flotación         :         0.114 m
                          Propiedades de la Sección Media:
                              Sm:    Área de la sección media             :         0.201 m2
                              Cm:    Cfte. de la maestra                  :        0.7660
                          Propiedades de la flotación:
                              Eslora en flotación                         :         5.036 m
                              Bwl:   Manga en flotación                   :         1.456 m
                              Swl:   Área de la Flotación                 :         5.362 m2
                              Cf:    Cfte. de la flotación                :        0.7311
                              XF:    Centro de Flotación de la Línea de agua :         2.503 m
                              Y coordinate of DWL area CoG                :         0.000 m
                              Beta:  Ángulo de entrada                    :        59.017 (º)
                              It:    Mto.Inercia Transversal              :         0.699 m4
                              Il:    Mto.Inercia Longitudinal             :         7.598 m4
                          Estabilidad Inicial:
                              KMt:   Altura Metacéntrica Transversal      :         1.309 m
                              Radio Metacéntrico Transversal              :         1.195 m
                              KMl:   Altura Metacéntrica Longitudinal     :        13.104 m
                              Radio Metacéntrico Longitudinal             :        12.990 m
                          La curva de áreas:
                          Y algunas imágenes del renderizado:
                          Con que versión os quedais?
                            @joabp
                            Si lo tuyo son los PDracers, te recomiendo que sigas el diseño de este minicruiser basado sobre el PD. Puedes ver mas en este post de Woodworkforum
                              sin duda, con esta última
                              aprovecho a enviarte un link, para que veas, algo similar a lo que estas dibujando, pero algo mas chico.
                              LU 9 DOM
                              Sail-ing: The fine art of getting wet and becoming ill while slowly going nowhere at great expense.
                              Navegación: el bello arte de conseguir mojarse y enfermar, mientras que lentamente va a ninguna parte con un gran costo.
                              NO PODEMOS DIRIGIR EL VIENTO, PERO PODEMOS AJUSTAR NUESTRAS VELAS !
                              We cannot direct the wind, but we can adjust our sails !
                              VENDO EL GABI !
                              Vela Ligera aleman de 4,6m, con remolque combi., muy divertido.
                                Bueno, dejo esta tarde el casco un poco aparcado para decidir las medidas de cubiertas, francobordos y interiores.
                                Por supuesto, lo que me gustaria es tener un barco con un perfil estilizado y bajo pero claro que con estas esloras reducidas si se quiere algo de habitabilidad es casi imposible mantener una relació estilizada.
                                Que altura sobre cabeza considerais mínima para que un espacio pueda ser utilizado como refugio, literas y almacenamiento?
